i9082 [ROM2] [wrong title next time - deleting] EasyJtag Suite ver.: 1.0.64.0 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device. Initialising: SAMSUNG GT-I9082 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 17170D0B46E461E6 ,FW Ver.: 01.47 Connecting to Target... JTAG device: BCM28155 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Target Not Examined Previously set screen EMMC fix ROM1 and ROM2 ,now dead. |
Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x02] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00e90000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enable No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0009b5 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Successefuly connected to box on COM21 Box S/N: 17170D0B46E461E6, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2021 mV CMD Active Level:2526 mV EMMC CID 1501004D3847315741008908245B3119 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 2299012187 EMMC NAME: M8G1WA EMMC Capacity: 7456 MB (High Density Card) ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x1b] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x11] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x05] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x02] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00e90000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enable No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0009b5 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Reading dump to file...C:\Documents and Settings\liliu\My Documents\EMMC_00000000_00100000.bin Successefuly connected to box on COM21 Box S/N: 17170D0B46E461E6, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2021 mV CMD Active Level:2536 mV EMMC CID 1501004D3847315741008908245B3119 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 2299012187 EMMC NAME: M8G1WA EMMC Capacity: 7456 MB (High Density Card) Switching EMMC partition... Reading 00100000 bytes from 00000000 ...ROM1 Read Speed: 175 kB/s Done !!! |
i9082L Previously set screen ,can flash mode and can flash , EMMC fix ROM1 and ROM2 ,now dead. Writing file...D:\Z3X\i9082\ROM2.bin Successefuly connected to box on COM21 Box S/N: 17170D0B46E461E6, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2021 mV CMD Active Level:2536 mV EMMC CID 1501004D3847315741008908245B3119 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 2299012187 EMMC NAME: M8G1WA EMMC Capacity: 7456 MB (High Density Card) Writing 00200000 bytes to 00000000 ...ROM2 Write Speed: 66 kB/s Done !!! Writing file...D:\Z3X\i9082\128MB.bin Successefuly connected to box on COM21 Box S/N: 17170D0B46E461E6, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2021 mV CMD Active Level:2536 mV EMMC CID 1501004D3847315741008908245B3119 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 2299012187 EMMC NAME: M8G1WA EMMC Capacity: 7456 MB (High Density Card) Writing 08000000 bytes to 00000000 ...ROM1 Write Speed: 179 kB/s Done !!! |
flash IC :KLM8G1WE4A GT-i9082/0_REV1.0 2012.12.06 |
Successefuly connected to box on COM21 Box S/N: xxxxxxxxx, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2031 mV CMD Active Level:2588 mV EMMC CID 1501004D3847315741008908245B3119 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 2299012187 EMMC NAME: M8G1WA EMMC Capacity: 7456 MB (High Density Card) ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Background operations status [BKOPS_STATUS: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x1b] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x11] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x05] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x02] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00e90000] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] Card Type [CARD_TYPE: 0x07] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enable No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] ============================================= Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked ============================================= User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0009b5 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 EMMC Thread don't support such command type. (eID_EMMC_NAND_SERVICE) |
my i9082 not flash mode ?????????/ Writing file...D:\Z3X\i9082\ROM2.bin Successefuly connected to box on COM21 Box S/N: 17170D0B46E461E6, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2021 mV CMD Active Level:2567 mV EMMC CID 1501004D3847315741008908245B3119 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 2299012187 EMMC NAME: M8G1WA EMMC Capacity: 7456 MB (High Density Card) Writing 00200000 bytes to 00000000 ...ROM2 Write Speed: 59 kB/s Done !!! Writing file...D:\Z3X\i9082\128MB.bin Successefuly connected to box on COM21 Box S/N: 17170D0B46E461E6, ,FW Ver.: 01.47 Loading eMMC Addon Firmware... CMD Pullup Level:2010 mV CMD Active Level:2609 mV EMMC CID 1501004D3847315741008908245B3119 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufactorer ID: 15 EMMC OEM ID: 0100 EMMC Date: 03/1998 FW rev.0x0 HW rev.0x0 EMMC Serial #: 2299012187 EMMC NAME: M8G1WA |
after flash ROM2 phone can be detected by JTAG and repaired via RCP. after repair by jtag phone will be detected in download mode. and can be flashed via ODIN |
emmc ROM2 flash to ROM2 ---is ok,but not detected by jtag Connecting to Target... JTAG device: BCM28155 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Target Not Examined |
Its possible 9082L has another BRCMBOOT , we will look for difference |
I'm here with my assistance with the same problem ..... I record the ROM2 but is not detected via Jtag .... |
should work. i think you did any mistake or may be hardware problem of EMMC for phone pcb. |
phone detect Successfully connected to box on COM3 Box S/N: 1616131E1B0B03A0, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:2041 mV CMD Active Level:2103 mV EMMC CID 1501004D3847315741002C0DA59ACFE7 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0x0 EMMC NAME: M8G1WA , S/N: 739091866 EMMC ROM1 (Main User Data) Capacity: 7456 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x00. Backup saved: M8G1WA_ 739091866_20140302_1702.extcsd Done. write rom 2 Successfully connected to box on COM3 Box S/N: 1616131E1B0B03A0, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:2041 mV CMD Active Level:2093 mV EMMC CID 1501004D3847315741002C0DA59ACFE7 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2012 FW rev.0x0 EMMC NAME: M8G1WA , S/N: 739091866 EMMC ROM1 (Main User Data) Capacity: 7456 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x00. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 67 kB/s Done !!! |
not have time for games not this works or not ? I bought a box to make this type of repair and a liar step with my clients ! I'm posting again Logging you asked ... I hope this time u can tell how to recover this phone .... EasyJtag Suite view : . 1.0.108.0 / wxWidgets - 3.1.0 WU started . Operating system see : . Windows 7 (build 7601 , Service Pack 1 ) . Successefuly connected to box on COM3 Box S / N : 1616131E1B0B03A0 , FW Ver : 01:48 Box Working Mode: JTAG Box Box Drivers version: 3.0.0.0 , are OK Z3X Card Serial : AA53 - BF8A , see : 22 Successfully connected to box on COM3 Box S / N : 1616131E1B0B03A0 , FW Ver : 01:48 Z3X Software EasyJtag see . 1.0.108.0 Loading eMMC Addon Firmware ... CMD Pullup Level : 2041 mV CMD Active Level : 2072 mV EMMC CID 1501004D3847315741002C0DA59ACFE7 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufacturer ID : 0015 , OEM ID : 0100 EMMC Date : 12/2012 FW rev.0x0 EMMC NAME : M8G1WA , S / N : 739 091 866 EMMC ROM1 ( Main User Data ) Capacity : 7456 MB (High Density Card ) EMMC ROM2 ( Boot Partition 1 ) Capacity : 2048 kB EMMC ROM3 ( Boot Partition 2 ) Capacity : 2048 kB EMMC RPMB ( Replay Protected Memory Block) Capacity : 128 kB Extended rev CSD 1.5 ( MMC 4:41 ) Boot configuration [ PARTITION_CONFIG 0x00 ] No boot partition configured . Boot bus config [ 177 ] : 0x01 , width 4bits , Partition config [ 179 ] : 0x00 . Backup saved : M8G1WA_ 739091866_20140306_1731.extcsd Done . Writing file ... B : \ Jtag Easy \ I9082 \ Samsung_GT - i9082_dump_rom2_2mb \ Samsung_GT - i9082_dump_rom2_2mb.bin Successfully connected to box on COM3 Box S / N : 1616131E1B0B03A0 , FW Ver : 01:48 Z3X Software EasyJtag see . 1.0.108.0 Loading eMMC Addon Firmware ... CMD Pullup Level : 2031 mV CMD Active Level : 2083 mV EMMC CID 1501004D3847315741002C0DA59ACFE7 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufacturer ID : 0015 , OEM ID : 0100 EMMC Date : 12/2012 FW rev.0x0 EMMC NAME : M8G1WA , S / N : 739 091 866 EMMC ROM1 ( Main User Data ) Capacity : 7456 MB (High Density Card ) EMMC ROM2 ( Boot Partition 1 ) Capacity : 2048 kB EMMC ROM3 ( Boot Partition 2 ) Capacity : 2048 kB EMMC RPMB ( Replay Protected Memory Block) Capacity : 128 kB Extended rev CSD 1.5 ( MMC 4:41 ) Boot configuration [ PARTITION_CONFIG 0x00 ] No boot partition configured . Boot bus config [ 177 ] : 0x01 , width 4bits , Partition config [ 179 ] : 0x00 . Writing bytes to 00000000 000000200000 ... ROM2 Write Speed : 101 kB / s Done ! Writing file ... B : \ Jtag Easy \ I9082 \ Samsung_GT - i9082_dump_rom1_128mb \ Samsung_GT - i9082_dump_rom1_128mb.bin Successfully connected to box on COM3 Box S / N : 1616131E1B0B03A0 , FW Ver : 01:48 Z3X Software EasyJtag see . 1.0.108.0 Loading eMMC Addon Firmware ... CMD Pullup Level : 2031 mV CMD Active Level : 2072 mV EMMC CID 1501004D3847315741002C0DA59ACFE7 EMMC CSD D02701320F5903FFF6DBFFE18E404029 EMMC Manufacturer ID : 0015 , OEM ID : 0100 EMMC Date : 12/2012 FW rev.0x0 EMMC NAME : M8G1WA , S / N : 739 091 866 EMMC ROM1 ( Main User Data ) Capacity : 7456 MB (High Density Card ) EMMC ROM2 ( Boot Partition 1 ) Capacity : 2048 kB EMMC ROM3 ( Boot Partition 2 ) Capacity : 2048 kB EMMC RPMB ( Replay Protected Memory Block) Capacity : 128 kB Extended rev CSD 1.5 ( MMC 4:41 ) Boot configuration [ PARTITION_CONFIG 0x00 ] No boot partition configured . Boot bus config [ 177 ] : 0x01 , width 4bits , Partition config [ 179 ] : 0x00 . Writing bytes to 00000000 000008000000 ... ROM1 Write Speed : 351 kB / s Done ! jtag conection only show-me Halting CPU... Target Not Examined |
