Old 10-11-2018, 09:08   #1 (permalink)
Member: 1723271
Thanks Meter: 51
Software bug Easy jtag Plus?
can't completely detect using easy jtag plus but on other box fully detected
G532f and Oppo R831k not detected on Easy jtag plus Box
Urgent needed solution Thank you!
Old 10-11-2018, 11:55   #2 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
IO voltage should be @ 2.8v
Old 10-11-2018, 14:16   #3 (permalink)
Member: 2340647
Thanks Meter: 69
Use "EasyJTAG Plus" Window
Old 10-11-2018, 16:38   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Sometime need to add voltage to IO, up from 1.8 to 2.8v, or use HipowerCLK Mode (connect only CMD/CLK/Dat0/GND, and power from board via USB)
The Following User Says Thank You to layder For This Useful Post:
Old 10-12-2018, 03:35   #5 (permalink)
Member: 1723271
Thanks Meter: 51
Same Problem, Already check voltage 2.8v Ok and 1.8v ok got tested but same problem
Old 10-12-2018, 09:15   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Please try to add 20-30 omh resistor to CLK line, or solder CLK pin to another side or resistor on PCB
in the new box schematics the CLK signal has excessive current and becomes sensitive to interference.
therefore, when connecting via ISP, the following rules must be observed:
1) the length of the wire CLK/CMD/Dat0 should not different more than 1-2cm.
2) GND wire should not be thin
Page generated in 0.20691 seconds with 8 queries
