01-21-2014, 11:35 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | GT-N7100 GALAXT NOTE II Write Dump Done !!!! Write ROM1 AREA 512MB done... Z3X Easy-JTAG Really Profesional EMMC TOOL !!!! BR, Dicle_Gsm |
The Following 4 Users Say Thank You to dicle_gsm For This Useful Post: |
08-22-2014, 05:43 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | @Easy Jtag team i write files directly to EMMC ,before it was fully dead.Now it GO Download mode...BUT Blank Screen,and i write full firmware with ODIN,but no Luck no power on phone,and still i can enter download mode but blank screen,any idea how to solve...... |
08-22-2014, 05:47 | #4 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Code: <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1361 mV CMD Active Level:1856 mV eMMC Device Information EMMC CID : 15010056545530304DF10E3855149FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 238572820 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 238572820_20140704_1721.extcsd Done. <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1361 mV CMD Active Level:1856 mV Input file : D:\TORNADO\TOOL_BOXs\Z3X\9. Easy Jtag files\Samsung\N7100\EMMC_00000000_00200000.bin Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Speed: 1290 kB/s Done !!! <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:2805 mV CMD Active Level:2866 mV Can't init EMMC, Reason: CMD Timeout Error =================================== Done. <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1361 mV CMD Active Level:1835 mV eMMC Device Information EMMC CID : 15010056545530304DF10E3855149FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 238572820 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 238572820_20140704_1805.extcsd Done. <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1361 mV CMD Active Level:1835 mV Input file : D:\TORNADO\TOOL_BOXs\Z3X\9. Easy Jtag files\Samsung\N7100\N7100_Rom1_Alive_Dump_BN.bin Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 9015 kB/s Done !!! |
08-22-2014, 05:48 | #5 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Code: <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1567 mV CMD Active Level:1949 mV Can't init EMMC, Reason: CARD Operation Condition Timeout Error =================================== Done. <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1711 mV CMD Active Level:2299 mV eMMC Device Information EMMC CID : 15010056545530304DF10E3855149FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 238572820 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line !!! =================================== <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1701 mV CMD Active Level:2299 mV eMMC Device Information EMMC CID : 15010056545530304DF10E3855149FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 238572820 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line !!! =================================== <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1711 mV CMD Active Level:2299 mV eMMC Device Information EMMC CID : 15010056545530304DF10E3855149FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 238572820 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line !!! =================================== Running:SAMSUNG: MoviNAND Reset + Format... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1711 mV CMD Active Level:2299 mV Can't init EMMC, Reason: DATA RCV CRC Error =================================== Running:Change BOOT CONFIG... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1711 mV CMD Active Level:2299 mV Can't init EMMC, Reason: DATA RCV CRC Error =================================== Running:Change BOOT WIDTH... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1711 mV CMD Active Level:2299 mV Can't init EMMC, Reason: CMD CRC Error =================================== <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 2850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1701 mV CMD Active Level:2299 mV eMMC Device Information EMMC CID : 15010056545530304DF10E3855149FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 238572820 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line !!! =================================== <br> Z3X EasyJtag Software ver. 1.6.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1691 mV CMD Active Level:2299 mV eMMC Device Information EMMC CID : 15010056545530304DF10E3855149FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: <b>VTU00M</b> , S/N: 238572820 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_ 238572820_20140704_1709.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1691 mV CMD Active Level:2299 mV EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:1691 mV CMD Active Level:2299 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:Repair extCSD... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1691 mV CMD Active Level:2299 mV Writing... Can't open output file ! Running:Repair extCSD... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1691 mV CMD Active Level:2299 mV Writing... Done! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:Repair extCSD... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1691 mV CMD Active Level:2299 mV Writing... Done! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> Running:Repair extCSD... <br> Z3X EasyJtag Software ver. 1.6.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1691 mV CMD Active Level:2299 mV Writing... Done! Done. <font color="red">Please don't forget to repair extCSD from backup!!!</font> |
