i9300 NO PRODUCT (S3) - successfully repair with easy jtag Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!! CMD Active Level:1650 mV EMMC CID 15010056545530304DF1985402D47FD7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2555642580 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2555642580_20140105_2045.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... Successfully connected to box on COM58 Box S/N: 0D01100B3AC50D82, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!! CMD Active Level:1639 mV EMMC CID 15010056545530304DF1985402D47FD7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2555642580 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2555642580_20140105_2047.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Format... Successfully connected to box on COM58 Box S/N: 0D01100B3AC50D82, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1206 mV CMD Active Level:1639 mV EMMC CID 15010056545530304DF1985402D47FD7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2555642580 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2555642580_20140105_2047.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_2555642580_20140 105_2045.extcsd Running:Repair extCSD... Successfully connected to box on COM58 Box S/N: 0D01100B3AC50D82, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!! CMD Active Level:1639 mV EMMC CID 15010056545530304DF1985402D47FD7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2555642580 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! Writing file...D:\SAMSUNG\z3x easy\i9300\EMMC_ROM2_00000000_00200000.bin Successfully connected to box on COM58 Box S/N: 0D01100B3AC50D82, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!! CMD Active Level:1639 mV EMMC CID 15010056545530304DF1985402D47FD7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2555642580 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 218 kB/s Done !!! Writing file...D:\SAMSUNG\z3x easy\i9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000 _20000000.bin Successfully connected to box on COM58 Box S/N: 0D01100B3AC50D82, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1185 mV) too low , check cables etc.!!! CMD Active Level:1639 mV EMMC CID 15010056545530304DF1985402D47FD7 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 2555642580 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 302 kB/s Done !!! |
well done . Sent from my iPhone using Tapatalk 2 |
Bro wish windows you users w7 or windows xp 3 |
windows xp 3 use No problem |
What the steps did you use? |
Step 1: Smart Factory Reset + Format Step 2: SAMSUNG: movinand Format Step 3: Repair extcsd Step 4: rom2 (Boot Partition 1) Select 2 MB Write Step 5: ROM1 (Main user data), select 512 MB Write work phone |
i9300 no product name error i have 24pcs i9300 without product name and i tried to flash emmc ic through easy jtag but every one showing this error EasyJtag Suite ver.: 1.0.100.0 started. Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Successefuly connected to box on COM90 Box S/N: 121202160D62CBA3, ,FW Ver.: 01.48 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AAA9-C0E9 , ver: 22 Successfully connected to box on COM90 Box S/N: 121202160D62CBA3, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1062 mV) too low , check cables etc.!!! CMD Active Level:1515 mV Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! i thing it may be bad emmc chip , am not sure if anybody know about the error plz help |
Hi, Give screenshot here when its download mode that screenshot, in download mode if it showing custom binary NO after that confirm EMMC damaged, but once again u need to check sold wires and power supply, if it will clear, replace emmc ic. BR, Srinivas Reddy. |
Step 2 wire control step 3 voltage control |
i9300 boot repair plase help! Successfully connected to box on COM91 Box S/N: --------------, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1082 mV) too low , check cables etc.!!! CMD Active Level:1041 mV Warning: CMD Active Level Low !!! EMMC CID 15010056545530304DF1CC5C4F826FBF EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3428601730 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Retry writing adress 0x00000000 Retry writing adress 0x00000000 Retry writing adress 0x00000000 Retry writing adress 0x00000000 |
I always get this error: Loading eMMC Addon Firmware... Warning: CMD Pullup Level (783 mV) too low , check cables etc.!!! CMD Active Level:1258 mV Warning: CMD Active Level Low !!! eMMC ACK Error ( Check Connection ) eMMC Card initialisation error! |
plase help I9300 no product Successfully connected to box on COM91 Box S/N: -----------------, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1670 mV CMD Active Level:1134 mV Warning: CMD Active Level Low !!! Can't Init EMMC !!! ( Ready Condition TIMEOUT! ) eMMC Card initialisation error! |
