09-21-2016, 09:55 | #1 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: cold place
Member: 1316900 Status: Offline Sonork: none Thanks Meter: 30 | lg d295 boot certfication error after write full dump dead need help Operating system ver.: Windows XP (build 2600, Service Pack 3). undefined Android Explorer ver.: 1.0.0.6 eMMC ODIN ver.: 1.0.0.8 Successfully connected to box on COM76 Box S/N: 0800A01BD85CE15B, ,FW Ver.: 01.55 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA21-E41A , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.3.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0800A01BD85CE15B, ,FW Ver.: 01.55CMD Pullup Level:505 mV CMD Active Level:2093 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 2.3.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0800A01BD85CE15B, ,FW Ver.: 01.55CMD Pullup Level:2701 mV CMD Active Level:2753 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 90014A4834473164040502A1C5199186 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 09/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 44156185 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 44156185_20160921_1031.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Warning: Entries Count = 36 MMCBLK0P0 (MODEM) Range: [0X400000,0X43FFE00] ,Len: 4000000 MMCBLK0P1 (SBL1) Range: [0X4400000,0X44FFE00] ,Len: 100000 MMCBLK0P2 (RPM) Range: [0X4500000,0X457FE00] ,Len: 80000 MMCBLK0P3 (TZ) Range: [0X4580000,0X45FFE00] ,Len: 80000 MMCBLK0P4 (SDI) Range: [0X4600000,0X467FE00] ,Len: 80000 MMCBLK0P5 (ABOOT) Range: [0X4680000,0X487FE00] ,Len: 200000 MMCBLK0P6 (RPMB) Range: [0X4880000,0X48FFE00] ,Len: 80000 MMCBLK0P7 (TZB) Range: [0X4900000,0X497FE00] ,Len: 80000 MMCBLK0P8 (ABOOTB) Range: [0X4980000,0X4B7FE00] ,Len: 200000 MMCBLK0P9 (PAD) Range: [0X4B80000,0X4D7FE00] ,Len: 200000 MMCBLK0P10 (MODEMST1) Range: [0X4D80000,0X507FE00] ,Len: 300000 MMCBLK0P11 (MODEMST2) Range: [0X5080000,0X537FE00] ,Len: 300000 MMCBLK0P12 (MISC) Range: [0X5380000,0X637FE00] ,Len: 1000000 MMCBLK0P13 (PERSIST) Range: [0X6400000,0X83FFE00] ,Len: 2000000 MMCBLK0P14 (LAF) Range: [0X8400000,0X99FFE00] ,Len: 1600000 MMCBLK0P15 (BOOT) Range: [0X9C00000,0XB1FFE00] ,Len: 1600000 MMCBLK0P16 (RECOVERY) Range: [0XB200000,0XC7FFE00] ,Len: 1600000 MMCBLK0P17 (FSG) Range: [0XC800000,0XCAFFE00] ,Len: 300000 MMCBLK0P18 (FSC) Range: [0XCC00000,0XCC7FE00] ,Len: 80000 MMCBLK0P19 (SSD) Range: [0XCC80000,0XCCFFE00] ,Len: 80000 MMCBLK0P20 (DDR) Range: [0XD000000,0XD07FE00] ,Len: 80000 MMCBLK0P21 (ENCRYPT) Range: [0XD400000,0XD47FE00] ,Len: 80000 MMCBLK0P22 (RCT) Range: [0XD480000,0XD4FFE00] ,Len: 80000 MMCBLK0P23 (DRM) Range: [0XD800000,0XDFFFE00] ,Len: 800000 MMCBLK0P24 (SNS) Range: [0XE000000,0XE7FFE00] ,Len: 800000 MMCBLK0P25 (FACTORY) Range: [0XE800000,0XFBFFE00] ,Len: 1400000 MMCBLK0P26 (FOTA) Range: [0XFC00000,0X11BFFE00] ,Len: 2000000 MMCBLK0P27 (SBL1B) Range: [0X11C00000,0X11CFFE00] ,Len: 100000 MMCBLK0P28 (MPT) Range: [0X11D00000,0X13CFFE00] ,Len: 2000000 MMCBLK0P29 (CUST) Range: [0X14000000,0X171FFE00] ,Len: 3200000 MMCBLK0P30 (EKSST) Range: [0X17400000,0X1747FE00] ,Len: 80000 MMCBLK0P31 (SYSTEM) Range: [0X17800000,0X7537FE00] ,Len: 5DB80000 MMCBLK0P32 (CACHE) Range: [0X75380000,0X84D7FE00] ,Len: FA00000 MMCBLK0P33 (USERDATA) Range: [0X84D80000,0XE6D7FE00] ,Len: 62000000 MMCBLK0P34 (GROW) Range: [0XE7000000,0XE8FFBC00] ,Len: 1FFBE00 Done...Presets has been updated... Done. Checking NAND Image : C:\Documents and Settings\tech\Desktop\LG_D295_emmc_direct_dump\LG_ D295_emmc_direct_dump\ext_csd.bin File successefuly loaded! Found ROM2 and automatically selected. Found ROM1 and automatically selected. Found ROM3 and automatically selected. Processing file...C:\Documents and Settings\tech\Desktop\LG_D295_emmc_direct_dump\LG_ D295_emmc_direct_dump\ext_csd.bin Processing file...C:\Documents and Settings\tech\Desktop\LG_D295_emmc_direct_dump\LG_ D295_emmc_direct_dump\EMMC_ROM1.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 2.3.0.0 Skip loading eMMC Addon Firmware Processing file...C:\Documents and Settings\tech\Desktop\LG_D295_emmc_direct_dump\LG_ D295_emmc_direct_dump\EMMC_ROM2.bin Processing file...C:\Documents and Settings\tech\Desktop\LG_D295_emmc_direct_dump\LG_ D295_emmc_direct_dump\EMMC_ROM3.bin CMD Pullup Level:2701 mVCMD Active Level:2753 mV Box IO Level:2800 mV CLK Rate:21000 khz Writing... Done. Writing 00E9000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 1642 kB/s Writing 0000100000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1491 kB/s Writing 0000100000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 1266 kB/s |
09-21-2016, 10:24 | #2 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Quote:
