J100h dead boot repair fail eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 0DFF8012C2EBA278 Card Serial = AAAF3D57 EasyJTAG Box Firmware = 1.6300 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report HiPower mode is ON Error: Previous operation is not finished yet. Setting frequence to 21 MHz CMD Pullup Level: 1691 mV CMD Active Level: 1742 mV Can't init device. Reason: CMD CRC Error Error: First select the Pit-file HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 1691 mV CMD Active Level: 1742 mV Can't init device. Reason: CMD CRC Error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 2145 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 90014A4834473262110146908E9F821C EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 46908E9F , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_46908E9F_20201101_153115.extcsd EMMC Init completed. Opening file: J13G.pit Pit: J13G.pit Entry count: 29 The size of the last section has been updated BL_J100HXXS0API6_CL980967_QB11067466_REV01_user_lo w_ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 65535 mV CMD Active Level: 65535 mV Can't init device. Reason: -12 Unknown error HiPower mode is ON Setting frequence to 21 MHz CMD Pullup Level: 2588 mV CMD Active Level: 3207 mV EMMC Device Information : EMMC CID: 90014A4834473262110146908E9F821C EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 46908E9F , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_46908E9F_20201101_153159.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2 Error writing at address: 000000000000 , error: -8 , DATA SND CRC Error(Small ROM Size, maybe) ... Retry #3 Too many errors. Writing has been stopped |
Here is Your , "Error writing at address: 000000000000" solution . |
