12-18-2016, 22:39 | #1 (permalink) |
Freak Poster Join Date: Dec 2012 Location: Egypt Age: 28
Member: 1857256 Status: Offline Sonork: 1650338 Thanks Meter: 91 | i9060i repair boot problem supporters please in Code: Z3X EasyJtag Software ver. 2.5.0.3 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1300500EAF5E0EE8, ,FW Ver.: 01.56 CMD Pullup Level:2010 mV CMD Active Level:2516 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : FE014E50314A39354B13019B4187B274 EMMC CSD : D07F01320F5913FFFFFFFFEF924000A2 EMMC Manufacturer ID: 00FE , OEM ID: 014E EMMC Date: 11/2015 Rev.0x13 EMMC NAME: P1J95K , S/N: 26952071 EMMC NAME (HEX): 50314A39354B00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: P1J95K_ 26952071_20161218_2259.extcsd Done. Code: Checking NAND Image : C:\Users\A7MED\Desktop\Working I9060i Dump\i9060i_EMMC_ROM1_00000000_40000000.bin File successefuly loaded! Found ROM2 and automatically selected. Found ROM3 and automatically selected. Found EXT CSD and automatically selected. extCSD Are not selected , skip writing extCSD Processing file...C:\Users\A7MED\Desktop\Working I9060i Dump\i9060i_EMMC_ROM1_00000000_40000000.bin Processing file...C:\Users\A7MED\Desktop\Working I9060i Dump\I9060i_EMMC_ROM2_00000000_20000000.bin Processing file...C:\Users\A7MED\Desktop\Working I9060i Dump\i9060I_EMMC_ROM3_00000000_00400000.bin Z3X EasyJtag Software ver. 2.5.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:2010 mV CMD Active Level:2505 mV Can't access password locked device Please, use Erase MMC Password option Done. Z3X EasyJtag Software ver. 2.5.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:2010 mV CMD Active Level:2505 mV Can't access password locked device Please, use Erase MMC Password option Code: Running:MMC: Password force remove... Z3X EasyJtag Software ver. 2.5.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:2010 mV CMD Active Level:2505 mV Box IO Level:2800 mV CLK Rate:14000 khz Force erase SD/MMC password, wait up to 3 min... CARD Lock/Unlock Error Force erase SD/MMC password Failed. |
12-18-2016, 22:47 | #2 (permalink) | |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
Please, download latest Easy-Jtag 2.5.0.4. We solved some Erase MMC Pasword issues. Best Regards Last edited by vikboston; 12-18-2016 at 22:53. | |
The Following User Says Thank You to vikboston For This Useful Post: |
12-18-2016, 23:30 | #5 (permalink) | |
Member: 1857256 Status: Offline Sonork: 1650338 Thanks Meter: 91 | Quote:
Code: Running:MMC: Password force remove... Z3X EasyJtag Software ver. 2.5.0.4 Skip loading eMMC Addon Firmware CMD Pullup Level:2021 mV CMD Active Level:2505 mV Box IO Level:2800 mV CLK Rate:14000 khz Force erase SD/MMC password, wait up to 3 min... CARD Lock/Unlock Error Force erase SD/MMC password Failed. | |
12-19-2016, 21:29 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You have Micron eMMC and as i know many of this type eMMC have problem usually you need replace by new one like KMK7X000VM-B314 |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
12-20-2016, 08:20 | #8 (permalink) |
Member: 1857256 Status: Offline Sonork: 1650338 Thanks Meter: 91 | First thanks for your reply and Yes it is a Micron eMMC but i can't change it and i think it only need to unlock the password , if team can give me even a beta test ver to remove this password i will be so thankful |
03-16-2017, 17:58 | #11 (permalink) | |
Freak Poster Join Date: Jun 2014
Member: 2213928 Status: Offline Thanks Meter: 440 | Quote:
Rom1 rom2 rom3 extd https://drive.google.com/file/d/0BwQ...w?usp=drivesdk | |
The Following 2 Users Say Thank You to yuvraj9x2 For This Useful Post: |
