09-10-2019, 16:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Can't init device, Reason: CMD Index Error Found 5 serial devices COM1 ACPI\PNP0501 Nuvoton Communications Port (COM1) COM2 ACPI\PNP0501 Nuvoton Communications Port (COM2) COM31 root\rimports RIM Virtual Serial Port v2 (COM31) COM4 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM4) COM33 root\rimports RIM Virtual Serial Port v2 (COM33) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 832mV pin connected ok command: 1090mV pin connected ok data0: 1134mV pin connected ok data1: 1148mV pin connected ok data2: 976mV pin connected ok data3: 1037mV pin connected ok data4: 1179mV pin connected ok data5: 1199mV pin connected ok data6: 1196mV pin connected ok data7: 1195mV pin connected ok Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.48 Box IO Level:1800 mV CLK Rate:1000 kHz Bus Width:8bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 827mV pin connected ok command: 1029mV pin connected ok data0: 1126mV pin connected ok data1: 1132mV pin connected ok data2: 1149mV pin connected ok data3: 1184mV pin connected ok data4: 1102mV pin connected ok data5: 1196mV pin connected ok data6: 1203mV pin connected ok data7: 1203mV pin connected ok Box S/N: 026862FABF5A25EA, ,FW Ver.: 02.48 Box IO Level:1800 mV CLK Rate:1000 kHz Bus Width:8bit,SDR HiPower mode is off! Can't init device, Reason: CMD Index Error Done. all points are showing connected to socket but still the above error, tried many bga 169, bga 221, but still same error, and after taking out emmc from socket emmc getting heated automatically, please suggest |
09-11-2019, 07:39 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | CMD Tiomeout error - bad CMD lines connection or dead eMMC and you use very low clock freq (all devices fine work with ~10-21Mhz) also you can try to Disable/Enabel "eMMC hi-speed timing" at settings |
09-11-2019, 10:02 | #4 (permalink) |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | tried all the above settings but still cmd timeout error maybe got back to back 4 dead emmc, but i was able to flash mtk dead phones with usb, flashing also completed successfully, but still not connecting with easy jtag |
