12-27-2020, 10:54 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: pakistan Age: 40
Member: 189855 Status: Offline Thanks Meter: 31 | j600f dead after try reset pin/password/pattern Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 05008013505C55C9, ,FW Ver.: 01.63 CMD Pullup Level:360 mV CMD Active Level:2248 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100424A5444345200CD0158D3556C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2018 Rev.0x0 eMMC NAME: BJTD4R , S/N: 3439417555 eMMC NAME (HEX): 424A54443452 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 2 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: BJTD4R_3439417555_20201227_1228.extcsd Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000E800000 (3.710GB) Short EXT fs info: Size: 3.678GB Block size: 4.0KB Inode size: 256 Inodes: 241440 Short Android info: Build ID: R16NW Display Build ID: R16NW.J600FXXU3ASA1 Release Incremental ID: J600FXXU3ASA1 Release Base ID: 8.0.0 Security Path: 2019-01-01 Device Model: SM-J600F Device Manufacturer: samsung Product ID: j6lte Device Name A: j6ltecis Device Name B: j6lte Architecture ABI: armeabi-v7a Device manufacturer: samsung Build Description: j6ltecis-user 8.0.0 R16NW J600FXXU3ASA1 release-keys PDA ver.: J600FXXU3ASA1 Samsung CPU: exynos7870 Backup saved: BuildProp_20201227_1228.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0146B00000 (24.11GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: E800B195 51824C86 4C231BCD 91FB436C 223EF891 799D073F 931E51AA 3488742A è.±•Q‚L†L#.Í‘ûCl">ø‘y..?“.Qª4.t*; 8DEC9D22 9438B656 DA6EB504 451AD3A3 A188E3F6 EB2E6490 BD479E31 4E86CD77 .ì."”8¶VÚnµ.E.Ó£¡.ãöë.d.½Gž1N†Íw; 9AFB04D8 304354E8 C2C8EE84 BF9962C6 D4BADCB3 F3629408 D5A04D8F 36FF1E74 šû.Ø0CTèÂÈî„¿.bÆԺܳób”.Õ*M.6ÿ.t; E461535E BC51CC56 0A74254A 3BA2CD70 A3567E55 41EDF15F 74F31815 2A068AF7 äaS^¼QÌV.t%J;¢Íp£V~UAíñ_tó..*.Š÷; E7E17AAA 60E09026 4A4802BA D304707D 227D966A A6CE0D66 4F5688E7 5A016858 çázª`à.&JH.ºÓ.p}"}–j¦Î.fOV.çZ.hX; F74DC992 B096979C 0BD494B9 A3D0C832 4F87C704 183B9AA3 A48568C4 A193F90D ÷MÉ’°–—œ.Ô”¹£ÐÈ2O‡Ç..;š£¤…hÄ¡“ù.; D8C88977 7E48917E 49D598E4 A5150AA6 42994909 708994BA EFE521AD D5B038E3 Øȉw~H‘~IÕ.ä¥..¦B.I p‰”ºïå!*Õ°8ã; D6B12E3C D32F0F38 AB0DAC41 64D81D3C C801283D 4C41380F 45BE1FFF FAD96CB7 Ö±.<Ó/.8«.¬AdØ.<È.(=LA8.E¾.ÿúÙl·; Done. Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 05008013505C55C9, ,FW Ver.: 01.63 CMD Pullup Level:360 mV CMD Active Level:2258 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100424A5444345200CD0158D3556C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2018 Rev.0x0 eMMC NAME: BJTD4R , S/N: 3439417555 eMMC NAME (HEX): 424A54443452 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 2 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x0146B00000 (24.11GB) Mount EXT4 fs... Unable to mount USER , code : 95 --------------------------------------------- Done. |
12-28-2020, 23:04 | #4 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Make short with solder clk and check result ✔ mostly clk become when we soldering iron low quality many other reason but you test it and post report with success |
