kothamamun | 07-30-2020 16:35 | Emmc are unusable final solution Fix it This emmc other device find partition but jtag+ not found partition Code:
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 36 MHz
CMD Pullup Level: 1810 mV
CMD Active Level: 1862 mV
EMMC Device Information :
EMMC CID: 65646F4D204D4F52128100000615444D
EMMC CSD: D07FFF320F59007FF6DB80001E40001D
EMMC Manufacture : , EMMC NAME: MMOR , HEX: 4D004D4F5200 , S/N: 00000615 , rev. 0x81
EMMC Manufacture ID: 0x65 , OEM ID: 0x6F , Device Type: Device (removable) , Date: 4/2017
EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG]: 0x78 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x03
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: MMOR_00000615_20200730_075357.extcsd
EMMC Init completed.
Warning: Maybe your emmc damaged
eMMC are unusable. Code:
Checking security ...
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.7.0.17
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: 4CC179F40BE74F5B, ,FW Ver.: 02.52
CMD Pullup Level:2281 mV
CMD Active Level:2744 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 65646F4D204D4F52128100000615444D
eMMC CSD : D07FFF320F59007FF6DB80001E40001D
eMMC Manufacturer ID: 0065 , OEM ID: 646F
eMMC Date: 04/2017 Rev.0x81
eMMC NAME: M MOR , S/N: 1557
eMMC NAME (HEX): 4D204D4F5220
EMMC ROM1 (Main User Data) Capacity: 2095982 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC RPMB is not yet programmed (clear) or RPMB Counter failure
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000400]
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: M_ 1557_20200730_0758.extcsd
Blocks Reading Error (0x0 , 1 , Reason: CMD Timeout Error )
Blocks Reading Error (0x200 , 1 , Reason: CMD Timeout Error )
Warning! Read error 0 strange behavior now likely!
Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: CMD Timeout Error )
Partition info not found
Done. Code:
CMD Pullup Level:2279 mV
CMD Active Level:2741 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 2095982 MB , 0xFFDB7000 pages , 0x1FFB6E00000 bytes
Backup saved: M_ 1557_20200730_0806.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x00]
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x00]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x00]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x15]
Secure Erase Multiplier [SEC_ERASE_MULT: 0x00]
Secure TRIM Multiplier [SEC_TRIM_MULT: 0x00]
Boot Information [BOOT_INFO: 0x01]
Device supports alternative boot method
Boot partition size [BOOT_SIZE_MULTI: 0x10]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x00]
Reliable write sector count [REL_WR_SEC_C: 0x08]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01]
Sleep current (VCC) [S_C_VCC: 0x00]
Sleep current (VCCQ) [S_C_VCCQ: 0x00]
Sleep/awake timeout [S_A_TIMEOUT: 0x00]
Sector Count [SEC_COUNT: 0x003ab800]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x00]
[MIN_PERF_R_8_52: 0x00]
[MIN_PERF_W_8_26_4_52: 0x00]
[MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x00]
[MIN_PERF_R_4_26: 0x00]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x00]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x00]
Card Type [CARD_TYPE: 0x03]
HS eMMC @52MHz - at rated device voltage(s)
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x78]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x00
Write reliability parameter register [WR_REL_PARAM]: 0x00
Enable background operations handshake [BKOPS_EN]: 0x00
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000100
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Done.
CLK Rate:36000 kHz
Bus Width:1bit,SDR
Backup saved: M_ 1557_20200730_0808.extcsd
Done.
CMD Pullup Level:2277 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
Backup saved: M_ 1557_20200730_0811.extcsd
Done.
