11-10-2020, 14:28 | #1 (permalink) |
Freak Poster Join Date: May 2012 Location: Turkey Age: 35
Member: 1754273 Status: Offline Thanks Meter: 32 | KM8V7001JM-B810 Solution Device is work, only Lock Screen Please help. Code: UFS: Memory Info: Connection: UNKNOWN SOCKET TYPE Vendor: SAMSUNG Name: KM8V7001JM-B810 S/N: 3c50095f1902 OEM ID: SAMSUNG_OEM_ID Firm Version: 1.2.0.0 Size: 0x001DCC800000/119,20 GB Max LUNs: 8 LUNs Cnt: 3 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 (Boot A) -> Size: 1024 Block(s)/4,00 MB LUN 1 (Boot B) -> Size: 1024 Block(s)/4,00 MB LUN 2 -> Size: 31240192 Block(s)/119,17 GB W-LUN 0xC4 (REPORT LUNS) -> Size: 65536 Block(s)/16,00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 Error Reading Sector: 0, Count: 6, Err: -108/UNKN_ERR Try Again #1 Error Reading Sector: 0, Count: 6, Err: -504/UNKN_ERR Last edited by layder; 12-01-2020 at 12:48. Reason: change topic name |
The Following 3 Users Say Thank You to Asiatic Rebel For This Useful Post: |
11-10-2020, 17:47 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
11-11-2020, 13:13 | #5 (permalink) | |
Member: 1754273 Status: Offline Thanks Meter: 32 | Connection with Socket BGA 254 This chip realme, not detect. Software frezee Quote:
11-11-2020, 15:07 | #6 (permalink) |
Member: 1754273 Status: Offline Thanks Meter: 32 | KM5V7001DM-B621 and KM8V7001JM-B810 UFS Chip not support? please give me an answer, should I return it to the customer? Last edited by layder; 11-12-2020 at 15:39. Reason: merge posts |
11-12-2020, 16:29 | #7 (permalink) | |
short this pins and post results p.s I was remove picture - it is a temp solution Solution is: https://forum.gsmhosting.com/vbb/f67.../#post14277775 Last edited by layder; 12-15-2020 at 08:05. | |
The Following 4 Users Say Thank You to layder For This Useful Post: |
11-13-2020, 07:44 | #8 (permalink) | |
Member: 1754273 Status: Offline Thanks Meter: 32 | Now connect OK. I can press key 'Reset Oppo', do you approve? Quote:
11-17-2020, 21:17 | #10 (permalink) |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Hi, layder Please Move this thread Sticky and Remove unwanted post for better understand this topic and close this thread. Or Make it Your own Tutorial about this Job and make it new sticky thread. This will help many users. Thank you layder for Your Kind support. |
The Following User Says Thank You to sree krishna For This Useful Post: |
11-18-2020, 12:16 | #11 (permalink) | |
We need info from topicstarter for R11 soldering and other resistors nominal | |
The Following User Says Thank You to layder For This Useful Post: |
11-27-2020, 05:44 | #12 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | KM8V7001JM-B810 Code: -108 can fix??? Very many KM8V7001JM-B810 IC can fix??? EasyJtag Suite Classic ver.: 3.7.0.20 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 17763), 64-bit edition. Admin rights OK Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6671.7138 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AACC-XXX , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM1 ACPI\VEN_PNP&DEV_0501 通信端口 (C COM14 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM14) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 UFS Socket Info. Serial: 0123571XXXXXXXXX Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 16.01.20 Identify UFS Chip. UFS Chip Voltage: Low Can't init device, Code: -108, Reason: UTP: response timeout VCC: 3302mV VCCQ2: 1916mV Chip Info: Manufacturer: SAMSUNG ProductName: KM8V7001JM-B810 SerialNumber: 28edb6c0d30b OemID: SAMSUNG_OEM_ID Firmware Version: 6.10 UFS Version: 2.1 Done. |
12-01-2020, 12:38 | #13 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | KM8V7001JM-B810 solution 22R resistors can buy here: https://aliexpress.com/item/32530914...640x640Q90.jpg Last edited by layder; 12-01-2020 at 12:50. |
The Following 10 Users Say Thank You to layder For This Useful Post: |
02-25-2021, 10:19 | #14 (permalink) |
Member: 1754273 Status: Offline Thanks Meter: 32 | Hi, layder. I am all Resistor change with 22 Ohm. Now Read good. But R11 47 Ohm, this change 22 Ohm? Thank you layder for Your Kind support. |
The Following User Says Thank You to Asiatic Rebel For This Useful Post: |
