09-20-2021, 13:48 | #18 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 79 | Quote:
Connection: UNKNOWN SOCKET TYPE So do i have to change those resistors one time for all UFS Chips or every time i get that error? | |
09-23-2021, 02:48 | #20 (permalink) |
Member: 2267293 Status: Offline Thanks Meter: 79 | I have not removed the chip from motherboard, i just soldered isp pinout on the socket, the bga254 ufs socket. It's oPPO a53 i want to remove password. The isp connection is okay because the phone is detected but giving errors when reading some partitions. See the log below.. ========================================= 19.09.2021 20:50:05> Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started.. 19.09.2021 20:50:13> Box API Version: 3401 19.09.2021 20:50:13> FS Driver Version: 29062020 19.09.2021 20:50:13> SQLite Version: 3.32.0 19.09.2021 20:50:13> FSCK Engine Version: 29062020 19.09.2021 20:50:13> ESE DB Version: 29062020 19.09.2021 20:50:13> System Util Version: 29062020 19.09.2021 20:50:13> System: Windows NT 6.2 (Build 9200) / 64 BIT 19.09.2021 20:50:13> CPU: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz 19.09.2021 20:50:13> Total RAM: 3.88 GB 19.09.2021 20:50:13> Telegram Support: https://t.me/z3xefm 19.09.2021 20:50:13> FRP Apps: Z3X FRP Files 19.09.2021 20:50:13> 19.09.2021 20:50:15> Z3X Card Serial: AA254341 19.09.2021 20:50:15> EasyJtag Plus Box Found at: COM3 19.09.2021 20:50:15> EasyJtag Plus Box Firmware: 2.53.2 19.09.2021 20:50:16> 19.09.2021 20:50:45> Source: EasyJtag Port [UFS] 19.09.2021 20:50:45> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 20:50:45> UFS Power Mode: LOW 19.09.2021 20:50:45> Scanner Thread Created.. 19.09.2021 20:50:45> 19.09.2021 20:50:45> Running EasyJtag UFS Mode... 19.09.2021 20:50:45> UFS ISP Mode: ON 19.09.2021 20:50:45> UFS Safe Mode: ON 19.09.2021 20:50:45> 19.09.2021 20:50:59> Init UFS Engine: 0/OK 19.09.2021 20:50:59> 19.09.2021 20:51:00> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 20:51:00> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 20:51:00> Box Hardware = EasyJtag 2nd Generation 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: Socket Info: 19.09.2021 20:51:00> S/N: 0x0123089213029CF5EE 19.09.2021 20:51:00> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 20:51:00> Type: EasyJtag UFS Socket BGA-254 19.09.2021 20:51:00> ID: 6194 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: Voltage Info: 19.09.2021 20:51:00> Mode: LOW 19.09.2021 20:51:00> VCC : 3332 mV, VCCQ2: 1931 mV 19.09.2021 20:51:00> 3v3 : 3383 mV, 1v2: 1228 mV 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: Memory Info: 19.09.2021 20:51:00> Connection: UNKNOWN SOCKET TYPE 19.09.2021 20:51:00> Vendor: SAMSUNG 19.09.2021 20:51:00> Name: KM5H7001DM-B424 19.09.2021 20:51:00> S/N: 486a5948e30c 19.09.2021 20:51:00> OEM ID: SAMSUNG_OEM_ID 19.09.2021 20:51:00> Firm Version: 6.00 19.09.2021 20:51:00> Size: 0x000EE6800000/59.60 GB 19.09.2021 20:51:00> Max LUNs: 8 19.09.2021 20:51:00> LUNs Cnt: 6 19.09.2021 20:51:00> W-LUNs Cnt: 1 19.09.2021 20:51:00> LUNs ReConfig: Enabled 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS Health Info: 19.09.2021 20:51:00> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 20:51:00> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 20:51:00> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: LUNs Info: 19.09.2021 20:51:00> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 20:51:00> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 20:51:00> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 20:51:00> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 20:51:00> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 20:51:00> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 20:51:00> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS Init OK 19.09.2021 20:51:00> Scanning Data From UFS Chip. Please wait.. 19.09.2021 20:51:00> 19.09.2021 20:51:00> Scanning GUID Partition Table from LUN 0 19.09.2021 20:51:00> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:00> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:00> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 20:51:00> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:00> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:00> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:00> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:00> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 20:51:00> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 20:51:00> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 20:51:00> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 20:51:00> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 20:51:00> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 20:51:00> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 20:51:00> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:00> Reading Table Completed 19.09.2021 20:51:00> Scanning GUID Partition Table from LUN 1 19.09.2021 20:51:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:01> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 20:51:01> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:01> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 20:51:01> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:01> Reading Table Completed 19.09.2021 20:51:01> Scanning GUID Partition Table from LUN 2 19.09.2021 20:51:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:01> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 20:51:01> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:01> Reading Table Completed 19.09.2021 20:51:01> Scanning GUID Partition Table from LUN 3 19.09.2021 20:51:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:01> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 20:51:01> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:01> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:01> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:01> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:01> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 20:51:01> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:01> Reading Table Completed 19.09.2021 20:51:01> Scanning GUID Partition Table from LUN 4 19.09.2021 20:51:02> GUID Partition Table is Found. Max Parts: 64 19.09.2021 20:51:02> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:02> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 20:51:02> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 20:51:02> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 20:51:02> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 20:51:02> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:02> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:02> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 20:51:02> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:02> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 20:51:02> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 20:51:02> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 20:51:02> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 20:51:02> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:02> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:02> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 20:51:02> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 20:51:02> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 20:51:02> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:02> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 20:51:02> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 20:51:02> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 20:51:02> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:02> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 20:51:02> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:02> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:02> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 20:51:02> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 20:51:02> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 20:51:02> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 20:51:02> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 20:51:02> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 20:51:02> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 20:51:02> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 20:51:02> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:02> Reading Table Completed 19.09.2021 20:51:02> Scanning GUID Partition Table from LUN 5 19.09.2021 20:51:03> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:03> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:03> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 20:51:03> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 20:51:03> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 20:51:03> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:03> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:03> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:03> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:03> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:03> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:03> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 20:51:03> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:03> Reading Table Completed 19.09.2021 20:51:03> 19.09.2021 20:51:03> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 20:51:03> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 20:51:04> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 20:51:04> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 20:51:05> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 20:51:05> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 20:51:05> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 20:51:07> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 20:52:48> 19.09.2021 20:52:48> Error Reading Sector: 181191, Count: 5, Err: -108/UNKN_ERR 19.09.2021 20:52:48> Try Again #1 19.09.2021 20:52:49> 19.09.2021 20:52:49> Error Reading Sector: 181191, Count: 5, Err: -101/UNKN_ERR 19.09.2021 20:52:49> Try Again #2 19.09.2021 20:52:49> 19.09.2021 20:52:49> Error Reading Sector: 181191, Count: 5, Err: -103/UNKN_ERR 19.09.2021 20:52:49> Try Again #3 19.09.2021 20:52:49> 19.09.2021 20:52:49> Too Many Errors. Stopped. Err: -103/UNKN_ERR 19.09.2021 20:52:49> Error While Reading. Exit. Code: -103 19.09.2021 20:52:49> 19.09.2021 20:52:49> Scanner Thread Terminated 19.09.2021 20:52:49> Elapsed: 00:02:04:334 19.09.2021 20:52:49> Found 98 Partition(s).. 19.09.2021 20:52:49> Scan Done. Init Main Engine... 19.09.2021 20:52:49> 19.09.2021 20:52:49> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 20:52:49> 19.09.2021 20:52:49> Reader Engine Initialized.. 0/OK 19.09.2021 20:52:49> Source: EasyJtag Port [UFS] 19.09.2021 20:52:49> Power Mode: LOW 19.09.2021 20:52:49> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 20:52:49> Config: 1011111111101111 19.09.2021 20:52:49> Operation Done: [Init Engine], Elapsed: 00:00:00:047 19.09.2021 20:52:49> 19.09.2021 20:52:50> Error While Switch LUN: -103 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #1 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #2 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #3 19.09.2021 20:52:50> 19.09.2021 20:52:50> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 20:52:50> Error While Switch LUN: -103 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #1 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #2 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #3 19.09.2021 20:52:50> 19.09.2021 20:52:50> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:04:20> Session is Closed.. 19.09.2021 21:04:20> 19.09.2021 21:04:43> Source: EasyJtag Port [UFS] 19.09.2021 21:04:43> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:04:43> UFS Power Mode: HIGH 19.09.2021 21:04:43> Scanner Thread Created.. 19.09.2021 21:04:43> 19.09.2021 21:04:43> Running EasyJtag UFS Mode... 19.09.2021 21:04:43> UFS ISP Mode: ON 19.09.2021 21:04:43> UFS Safe Mode: ON 19.09.2021 21:04:43> 19.09.2021 21:04:57> Init UFS Engine: 0/OK 19.09.2021 21:04:57> 19.09.2021 21:04:58> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 21:04:58> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 21:04:58> Box Hardware = EasyJtag 2nd Generation 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: Socket Info: 19.09.2021 21:04:58> S/N: 0x0123089213029CF5EE 19.09.2021 21:04:58> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 21:04:58> Type: EasyJtag UFS Socket BGA-254 19.09.2021 21:04:58> ID: 6194 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: Voltage Info: 19.09.2021 21:04:58> Mode: HIGH 19.09.2021 21:04:58> VCC : 3332 mV, VCCQ2: 1929 mV 19.09.2021 21:04:58> 3v3 : 3383 mV, 1v2: 1228 mV 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: Memory Info: 19.09.2021 21:04:58> Connection: UNKNOWN SOCKET TYPE 19.09.2021 21:04:58> Vendor: SAMSUNG 19.09.2021 21:04:58> Name: KM5H7001DM-B424 19.09.2021 21:04:58> S/N: 486a5948e30c 19.09.2021 21:04:58> OEM ID: SAMSUNG_OEM_ID 19.09.2021 21:04:58> Firm Version: 6.00 19.09.2021 21:04:58> Size: 0x000EE6800000/59.60 GB 19.09.2021 21:04:58> Max LUNs: 8 19.09.2021 21:04:58> LUNs Cnt: 6 19.09.2021 21:04:58> W-LUNs Cnt: 1 19.09.2021 21:04:58> LUNs ReConfig: Enabled 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS Health Info: 19.09.2021 21:04:58> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:04:58> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:04:58> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: LUNs Info: 19.09.2021 21:04:58> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 21:04:58> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:04:58> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:04:58> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 21:04:58> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 21:04:58> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 21:04:58> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS Init OK 19.09.2021 21:04:58> Scanning Data From UFS Chip. Please wait.. 19.09.2021 21:04:58> 19.09.2021 21:04:58> Scanning GUID Partition Table from LUN 0 19.09.2021 21:04:58> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:04:58> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:04:58> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 21:04:58> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 21:04:58> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 21:04:58> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 21:04:58> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 21:04:58> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 21:04:58> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 21:04:58> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 21:04:59> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 21:04:59> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 21:04:59> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 21:04:59> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 21:04:59> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:04:59> Reading Table Completed 19.09.2021 21:04:59> Scanning GUID Partition Table from LUN 1 19.09.2021 21:04:59> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:04:59> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:04:59> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 21:04:59> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:04:59> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 21:04:59> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:04:59> Reading Table Completed 19.09.2021 21:04:59> Scanning GUID Partition Table from LUN 2 19.09.2021 21:04:59> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:04:59> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:04:59> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 21:04:59> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:04:59> Reading Table Completed 19.09.2021 21:04:59> Scanning GUID Partition Table from LUN 3 19.09.2021 21:04:59> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:05:00> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:05:00> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:05:00> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:00> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 21:05:00> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:05:00> Reading Table Completed 19.09.2021 21:05:00> Scanning GUID Partition Table from LUN 4 19.09.2021 21:05:00> GUID Partition Table is Found. Max Parts: 64 19.09.2021 21:05:00> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:05:00> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:05:00> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 21:05:00> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 21:05:00> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:05:00> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:00> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:00> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 21:05:00> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 21:05:00> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 21:05:00> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 21:05:00> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 21:05:00> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:00> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 21:05:00> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 21:05:00> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 21:05:00> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:00> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 21:05:00> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 21:05:00> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 21:05:00> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:00> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 21:05:00> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:00> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 21:05:00> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 21:05:00> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 21:05:00> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 21:05:00> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:05:00> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:05:00> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 21:05:00> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 21:05:00> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:05:00> Reading Table Completed 19.09.2021 21:05:01> Scanning GUID Partition Table from LUN 5 19.09.2021 21:05:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:05:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:05:01> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:05:01> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 21:05:01> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 21:05:01> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:01> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:01> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:01> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:01> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:01> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:01> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 21:05:01> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:05:01> Reading Table Completed 19.09.2021 21:05:01> 19.09.2021 21:05:01> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 21:05:01> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 21:05:02> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 21:05:02> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 21:05:03> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 21:05:03> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 21:05:03> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 21:05:04> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 21:05:04> Partition #77 mount as [/my_custom] - 256.00 MB 19.09.2021 21:05:05> Partition #79 mount as [/special_preload] - 768.00 MB 19.09.2021 21:05:05> Partition #92 mount as [/mnt/vendor/opporeserve] - 128.00 MB 19.09.2021 21:05:08> 19.09.2021 21:05:08> EmptyCheck: 19.09.2021 21:05:08> EMPTY - #2 - [SSD] 19.09.2021 21:05:08> EMPTY - #5 - [KEYSTORE] 19.09.2021 21:06:50> 19.09.2021 21:06:50> Error Reading Sector: 1670, Count: 64, Err: -108/UNKN_ERR 19.09.2021 21:06:50> Try Again #1 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 1670, Count: 64, Err: -504/UNKN_ERR 19.09.2021 21:06:56> Try Again #2 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 1670, Count: 64, Err: -504/UNKN_ERR 19.09.2021 21:06:56> Try Again #3 19.09.2021 21:06:56> 19.09.2021 21:06:56> Too Many Errors. Stopped. Err: -504/UNKN_ERR 19.09.2021 21:06:56> Error While Reading. Exit. Code: -504 19.09.2021 21:06:56> 19.09.2021 21:06:56> EmptyCheck: Fail.. 19.09.2021 21:06:56> EmptyCheck: Done 19.09.2021 21:06:56> 19.09.2021 21:06:56> Scanner Thread Terminated 19.09.2021 21:06:56> Elapsed: 00:02:13:379 19.09.2021 21:06:56> Found 98 Partition(s).. 19.09.2021 21:06:56> Scan Done. Init Main Engine... 19.09.2021 21:06:56> 19.09.2021 21:06:56> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 21:06:56> 19.09.2021 21:06:56> Reader Engine Initialized.. 0/OK 19.09.2021 21:06:56> Source: EasyJtag Port [UFS] 19.09.2021 21:06:56> Power Mode: HIGH 19.09.2021 21:06:56> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:06:56> Config: 1011111111101111 19.09.2021 21:06:56> Operation Done: [Init Engine], Elapsed: 00:00:00:085 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error While Switch LUN: -504 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #1 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #2 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #3 19.09.2021 21:06:56> 19.09.2021 21:06:56> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:06:56> Error While Switch LUN: -504 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #1 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #2 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #3 19.09.2021 21:06:56> 19.09.2021 21:06:56> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:07:53> Universal Wipe User Data v1.0 19.09.2021 21:07:53> 19.09.2021 21:07:55> Wiping MISC Partition.. 19.09.2021 21:07:55> Partition #5 is '/MISC'. Erasing.. 19.09.2021 21:07:55> Wipe Mode: Oppo/Vivo Factory Reset 19.09.2021 21:07:55> Error While Switch LUN: -504 19.09.2021 21:07:55> 19.09.2021 21:07:55> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:55> Try Again #1 19.09.2021 21:07:55> 19.09.2021 21:07:55> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:55> Try Again #2 19.09.2021 21:07:55> 19.09.2021 21:07:55> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:55> Try Again #3 19.09.2021 21:07:55> 19.09.2021 21:07:55> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:07:56> Error While Switch LUN: -504 19.09.2021 21:07:56> 19.09.2021 21:07:56> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:56> Try Again #1 19.09.2021 21:07:56> 19.09.2021 21:07:56> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:56> Try Again #2 19.09.2021 21:07:56> 19.09.2021 21:07:56> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:56> Try Again #3 19.09.2021 21:07:56> 19.09.2021 21:07:56> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:07:56> Error While Writing Data. Exit. Code: -700 19.09.2021 21:07:56> Operation Failure: [Universal Wipe Data], Code: -1, Elapsed: 00:00:00:250 19.09.2021 21:07:56> 19.09.2021 21:09:29> Source: EasyJtag Port [UFS] 19.09.2021 21:09:29> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:09:29> UFS Power Mode: HIGH 19.09.2021 21:09:29> Scanner Thread Created.. 19.09.2021 21:09:29> 19.09.2021 21:09:30> Running EasyJtag UFS Mode... 19.09.2021 21:09:30> UFS ISP Mode: ON 19.09.2021 21:09:30> UFS Safe Mode: ON 19.09.2021 21:09:30> 19.09.2021 21:09:44> Init UFS Engine: 0/OK 19.09.2021 21:09:44> 19.09.2021 21:09:44> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 21:09:44> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 21:09:44> Box Hardware = EasyJtag 2nd Generation 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: Socket Info: 19.09.2021 21:09:44> S/N: 0x0123089213029CF5EE 19.09.2021 21:09:44> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 21:09:44> Type: EasyJtag UFS Socket BGA-254 19.09.2021 21:09:44> ID: 6194 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: Voltage Info: 19.09.2021 21:09:44> Mode: HIGH 19.09.2021 21:09:44> VCC : 3333 mV, VCCQ2: 1928 mV 19.09.2021 21:09:44> 3v3 : 3382 mV, 1v2: 1228 mV 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: Memory Info: 19.09.2021 21:09:44> Connection: UNKNOWN SOCKET TYPE 19.09.2021 21:09:44> Vendor: SAMSUNG 19.09.2021 21:09:44> Name: KM5H7001DM-B424 19.09.2021 21:09:44> S/N: 486a5948e30c 19.09.2021 21:09:44> OEM ID: SAMSUNG_OEM_ID 19.09.2021 21:09:44> Firm Version: 6.00 19.09.2021 21:09:44> Size: 0x000EE6800000/59.60 GB 19.09.2021 21:09:44> Max LUNs: 8 19.09.2021 21:09:44> LUNs Cnt: 6 19.09.2021 21:09:44> W-LUNs Cnt: 1 19.09.2021 21:09:44> LUNs ReConfig: Enabled 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS Health Info: 19.09.2021 21:09:44> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:09:44> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:09:44> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: LUNs Info: 19.09.2021 21:09:44> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 21:09:44> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:09:44> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:09:45> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 21:09:45> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 21:09:45> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 21:09:45> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 21:09:45> 19.09.2021 21:09:45> UFS Init OK 19.09.2021 21:09:45> Scanning Data From UFS Chip. Please wait.. 19.09.2021 21:09:45> 19.09.2021 21:09:45> Scanning GUID Partition Table from LUN 0 19.09.2021 21:09:45> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:45> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:45> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 21:09:45> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:45> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:45> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:45> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:45> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 21:09:45> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 21:09:45> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 21:09:45> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 21:09:45> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 21:09:45> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 21:09:45> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 21:09:45> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:45> Reading Table Completed 19.09.2021 21:09:45> Scanning GUID Partition Table from LUN 1 19.09.2021 21:09:45> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:45> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:45> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 21:09:45> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:45> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 21:09:45> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:45> Reading Table Completed 19.09.2021 21:09:45> Scanning GUID Partition Table from LUN 2 19.09.2021 21:09:46> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:46> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:46> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 21:09:46> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:46> Reading Table Completed 19.09.2021 21:09:46> Scanning GUID Partition Table from LUN 3 19.09.2021 21:09:46> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:46> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:46> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:09:46> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:46> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 21:09:46> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:46> Reading Table Completed 19.09.2021 21:09:46> Scanning GUID Partition Table from LUN 4 19.09.2021 21:09:46> GUID Partition Table is Found. Max Parts: 64 19.09.2021 21:09:46> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:46> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:09:46> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 21:09:46> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 21:09:46> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:09:46> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:46> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:46> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 21:09:46> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 21:09:46> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 21:09:46> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 21:09:46> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 21:09:46> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:46> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 21:09:46> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 21:09:47> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 21:09:47> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:47> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 21:09:47> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 21:09:47> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:47> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 21:09:47> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 21:09:47> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:47> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:47> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 21:09:47> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 21:09:47> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:47> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 21:09:47> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:47> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:47> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 21:09:47> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:09:47> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:09:47> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 21:09:47> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 21:09:47> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:47> Reading Table Completed 19.09.2021 21:09:47> Scanning GUID Partition Table from LUN 5 19.09.2021 21:09:47> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:47> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:47> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:09:47> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 21:09:47> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 21:09:47> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:47> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:47> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:47> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 21:09:47> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:47> Reading Table Completed 19.09.2021 21:09:47> 19.09.2021 21:09:48> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 21:09:48> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 21:09:48> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 21:09:48> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 21:09:49> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 21:09:49> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 21:09:49> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 21:09:50> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 21:09:51> Partition #77 mount as [/my_custom] - 256.00 MB 19.09.2021 21:09:51> Partition #79 mount as [/special_preload] - 768.00 MB 19.09.2021 21:09:52> Partition #92 mount as [/mnt/vendor/opporeserve] - 128.00 MB 19.09.2021 21:09:55> 19.09.2021 21:09:55> EmptyCheck: 19.09.2021 21:09:55> EMPTY - #2 - [SSD] 19.09.2021 21:09:55> EMPTY - #5 - [KEYSTORE] 19.09.2021 21:09:56> EMPTY - #19 - [LAST_PARTI] 19.09.2021 21:09:56> EMPTY - #23 - [LAST_PARTI] 19.09.2021 21:09:56> EMPTY - #27 - [ALIGN_TO_128K_1] 19.09.2021 21:09:57> EMPTY - #28 - [CDT] 19.09.2021 21:09:57> EMPTY - #41 - [MDTPSECAPP] 19.09.2021 21:09:57> EMPTY - #42 - [MDTP] 19.09.2021 21:09:58> EMPTY - #56 - [DEVINFO] 19.09.2021 21:09:58> EMPTY - #57 - [DIP] 19.09.2021 21:09:58> EMPTY - #59 - [APDP_FULL] 19.09.2021 21:09:58> EMPTY - #60 - [SPUNVM] 19.09.2021 21:09:58> EMPTY - #62 - [LIMITS] 19.09.2021 21:09:59> EMPTY - #63 - [TOOLSFV] 19.09.2021 21:09:59> EMPTY - #65 - [CATELOADER] 19.09.2021 21:09:59> EMPTY - #66 - [RAWDUMP] 19.09.2021 21:09:59> EMPTY - #67 - [LOGDUMP] 19.09.2021 21:09:59> EMPTY - #69 - [MULTIIMGOEM] 19.09.2021 21:11:40> 19.09.2021 21:11:40> Error Reading Sector: 180920, Count: 8, Err: -108/UNKN_ERR 19.09.2021 21:11:40> Try Again #1 19.09.2021 21:11:41> 19.09.2021 21:11:41> Error Reading Sector: 180920, Count: 8, Err: -101/UNKN_ERR 19.09.2021 21:11:41> Try Again #2 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 180920, Count: 8, Err: -103/UNKN_ERR 19.09.2021 21:11:42> Try Again #3 19.09.2021 21:11:42> 19.09.2021 21:11:42> Too Many Errors. Stopped. Err: -103/UNKN_ERR 19.09.2021 21:11:42> Error While Reading. Exit. Code: -103 19.09.2021 21:11:42> 19.09.2021 21:11:42> EmptyCheck: Fail.. 19.09.2021 21:11:42> EmptyCheck: Done 19.09.2021 21:11:42> 19.09.2021 21:11:42> Scanner Thread Terminated 19.09.2021 21:11:42> Elapsed: 00:02:12:199 19.09.2021 21:11:42> Found 98 Partition(s).. 19.09.2021 21:11:42> Scan Done. Init Main Engine... 19.09.2021 21:11:42> 19.09.2021 21:11:42> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 21:11:42> 19.09.2021 21:11:42> Reader Engine Initialized.. 0/OK 19.09.2021 21:11:42> Source: EasyJtag Port [UFS] 19.09.2021 21:11:42> Power Mode: HIGH 19.09.2021 21:11:42> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:11:42> Config: 1011111111101111 19.09.2021 21:11:42> Operation Done: [Init Engine], Elapsed: 00:00:00:032 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error While Switch LUN: -103 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #1 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #2 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #3 19.09.2021 21:11:42> 19.09.2021 21:11:42> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:11:42> Error While Switch LUN: -103 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #1 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #2 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #3 19.09.2021 21:11:42> 19.09.2021 21:11:42> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:12:00> Universal Wipe User Data v1.0 19.09.2021 21:12:00> 19.09.2021 21:12:02> Wiping MISC Partition.. 19.09.2021 21:12:02> Partition #5 is '/MISC'. Erasing.. 19.09.2021 21:12:02> Wipe Mode: Oppo/Vivo Factory Reset 19.09.2021 21:12:02> Error While Switch LUN: -103 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #1 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #2 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #3 19.09.2021 21:12:02> 19.09.2021 21:12:02> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:12:02> Error While Switch LUN: -103 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #1 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #2 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #3 19.09.2021 21:12:02> 19.09.2021 21:12:02> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:12:02> Error While Writing Data. Exit. Code: -700 19.09.2021 21:12:02> Operation Failure: [Universal Wipe Data], Code: -1, Elapsed: 00:00:00:310 19.09.2021 21:12:02> 19.09.2021 21:12:24> Source: EasyJtag Port [UFS] 19.09.2021 21:12:24> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:12:24> UFS Power Mode: HIGH 19.09.2021 21:12:24> Scanner Thread Created.. 19.09.2021 21:12:24> 19.09.2021 21:12:24> Running EasyJtag UFS Mode... 19.09.2021 21:12:24> UFS ISP Mode: ON 19.09.2021 21:12:24> UFS Safe Mode: ON 19.09.2021 21:12:24> 19.09.2021 21:12:38> Init UFS Engine: 0/OK 19.09.2021 21:12:38> 19.09.2021 21:12:39> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 21:12:39> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 21:12:39> Box Hardware = EasyJtag 2nd Generation 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: Socket Info: 19.09.2021 21:12:39> S/N: 0x0123089213029CF5EE 19.09.2021 21:12:39> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 21:12:39> Type: EasyJtag UFS Socket BGA-254 19.09.2021 21:12:39> ID: 6194 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: Voltage Info: 19.09.2021 21:12:39> Mode: HIGH 19.09.2021 21:12:39> VCC : 3334 mV, VCCQ2: 1928 mV 19.09.2021 21:12:39> 3v3 : 3382 mV, 1v2: 1225 mV 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: Memory Info: 19.09.2021 21:12:39> Connection: UNKNOWN SOCKET TYPE 19.09.2021 21:12:39> Vendor: SAMSUNG 19.09.2021 21:12:39> Name: KM5H7001DM-B424 19.09.2021 21:12:39> S/N: 486a5948e30c 19.09.2021 21:12:39> OEM ID: SAMSUNG_OEM_ID 19.09.2021 21:12:39> Firm Version: 6.00 19.09.2021 21:12:39> Size: 0x000EE6800000/59.60 GB 19.09.2021 21:12:39> Max LUNs: 8 19.09.2021 21:12:39> LUNs Cnt: 6 19.09.2021 21:12:39> W-LUNs Cnt: 1 19.09.2021 21:12:39> LUNs ReConfig: Enabled 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS Health Info: 19.09.2021 21:12:39> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:12:39> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:12:39> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: LUNs Info: 19.09.2021 21:12:39> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 21:12:39> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:12:39> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:12:39> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 21:12:39> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 21:12:39> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 21:12:39> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS Init OK 19.09.2021 21:12:39> Scanning Data From UFS Chip. Please wait.. 19.09.2021 21:12:39> 19.09.2021 21:12:39> Scanning GUID Partition Table from LUN 0 19.09.2021 21:12:39> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:39> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:39> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 21:12:39> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:39> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:39> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:39> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:39> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 21:12:39> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 21:12:39> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 21:12:39> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 21:12:39> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 21:12:39> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 21:12:39> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 21:12:39> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:39> Reading Table Completed 19.09.2021 21:12:39> Scanning GUID Partition Table from LUN 1 19.09.2021 21:12:40> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:40> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:40> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 21:12:40> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:40> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 21:12:40> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:40> Reading Table Completed 19.09.2021 21:12:40> Scanning GUID Partition Table from LUN 2 19.09.2021 21:12:40> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:40> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:40> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 21:12:40> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:40> Reading Table Completed 19.09.2021 21:12:40> Scanning GUID Partition Table from LUN 3 19.09.2021 21:12:40> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:40> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:40> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:12:40> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:40> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:40> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:40> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:40> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 21:12:40> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:40> Reading Table Completed 19.09.2021 21:12:40> Scanning GUID Partition Table from LUN 4 19.09.2021 21:12:41> GUID Partition Table is Found. Max Parts: 64 19.09.2021 21:12:41> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:41> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:12:41> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 21:12:41> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 21:12:41> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:12:41> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:41> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:41> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 21:12:41> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:41> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 21:12:41> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 21:12:41> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 21:12:41> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 21:12:41> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:41> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:41> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 21:12:41> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 21:12:41> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 21:12:41> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:41> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 21:12:41> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 21:12:41> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 21:12:41> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:41> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 21:12:41> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:41> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:41> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 21:12:41> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 21:12:41> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 21:12:41> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 21:12:41> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:12:41> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:12:41> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 21:12:41> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 21:12:41> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:41> Reading Table Completed 19.09.2021 21:12:41> Scanning GUID Partition Table from LUN 5 19.09.2021 21:12:42> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:42> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:42> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:12:42> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 21:12:42> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 21:12:42> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:42> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:42> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:42> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:42> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:42> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:42> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 21:12:42> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:42> Reading Table Completed 19.09.2021 21:12:42> 19.09.2021 21:12:42> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 21:12:42> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 21:12:42> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 21:12:43> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 21:12:44> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 21:12:44> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 21:12:44> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 21:12:45> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 21:12:45> Partition #77 mount as [/my_custom] - 256.00 MB 19.09.2021 21:12:45> Partition #79 mount as [/special_preload] - 768.00 MB 19.09.2021 21:12:46> Partition #92 mount as [/mnt/vendor/opporeserve] - 128.00 MB 19.09.2021 21:12:49> 19.09.2021 21:12:49> EmptyCheck: 19.09.2021 21:12:49> EMPTY - #2 - [SSD] 19.09.2021 21:12:49> EMPTY - #5 - [KEYSTORE] 19.09.2021 21:12:50> EMPTY - #19 - [LAST_PARTI] 19.09.2021 21:12:50> EMPTY - #23 - [LAST_PARTI] 19.09.2021 21:12:51> EMPTY - #27 - [ALIGN_TO_128K_1] 19.09.2021 21:12:51> EMPTY - #28 - [CDT] 19.09.2021 21:12:51> EMPTY - #41 - [MDTPSECAPP] 19.09.2021 21:12:51> EMPTY - #42 - [MDTP] 19.09.2021 21:12:52> EMPTY - #56 - [DEVINFO] 19.09.2021 21:12:52> EMPTY - #57 - [DIP] 19.09.2021 21:12:52> EMPTY - #59 - [APDP_FULL] 19.09.2021 21:12:52> EMPTY - #60 - [SPUNVM] 19.09.2021 21:12:52> EMPTY - #62 - [LIMITS] 19.09.2021 21:12:53> EMPTY - #63 - [TOOLSFV] 19.09.2021 21:12:53> EMPTY - #65 - [CATELOADER] 19.09.2021 21:12:53> EMPTY - #66 - [RAWDUMP] 19.09.2021 21:12:53> EMPTY - #67 - [LOGDUMP] 19.09.2021 21:12:53> EMPTY - #69 - [MULTIIMGOEM] 19.09.2021 21:12:53> EMPTY - #70 - [MULTIIMGQTI] 19.09.2021 21:12:53> EMPTY - #71 - [UEFIVARSTORE] 19.09.2021 21:12:53> EMPTY - #72 - [SECDATA] 19.09.2021 21:12:54> EMPTY - #73 - [CATEFV] 19.09.2021 21:12:54> EMPTY - #74 - [CATECONTENTFV] 19.09.2021 21:12:54> EMPTY - #79 - [LAST_PARTI] 19.09.2021 21:12:54> EMPTY - #83 - [ALIGN_TO_128K_2] 19.09.2021 21:12:55> EMPTY - #88 - [FSG] 19.09.2021 21:12:55> EMPTY - #89 - [FSC] 19.09.2021 21:12:55> EMPTY - #92 - [OPPORESERVE3] 19.09.2021 21:12:55> EMPTY - #93 - [OPPORESERVE4] 19.09.2021 21:12:55> EMPTY - #94 - [OPPORESERVE5] 19.09.2021 21:12:56> EMPTY - #96 - [LAST_PARTI] 19.09.2021 21:12:56> EmptyCheck: Done 19.09.2021 21:12:56> 19.09.2021 21:12:56> ================================= 19.09.2021 21:12:56> Warning! Device Blocked by FRP 19.09.2021 21:12:56> For Reset FRP Try to Tools Tab 19.09.2021 21:12:56> Press Reset FRP Button 19.09.2021 21:12:56> Partition #7 - FRP 19.09.2021 21:12:56> ================================= 19.09.2021 21:13:04> 19.09.2021 21:13:04> Scanner Thread Terminated 19.09.2021 21:13:04> Elapsed: 00:00:40:472 19.09.2021 21:13:04> Found 98 Partition(s).. 19.09.2021 21:13:04> Scan Done. Init Main Engine... 19.09.2021 21:13:04> 19.09.2021 21:13:04> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 21:13:04> 19.09.2021 21:13:04> Reader Engine Initialized.. 0/OK 19.09.2021 21:13:04> Source: EasyJtag Port [UFS] 19.09.2021 21:13:04> Power Mode: HIGH 19.09.2021 21:13:04> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:13:04> Config: 1011111111101111 19.09.2021 21:13:04> Operation Done: [Init Engine], Elapsed: 00:00:00:038 19.09.2021 21:13:04> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 57, Err: -108/UNKN_ERR 19.09.2021 21:14:45> Try Again #1 19.09.2021 21:14:45> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 57, Err: -102/UNKN_ERR 19.09.2021 21:14:45> Try Again #2 19.09.2021 21:14:45> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 57, Err: -102/UNKN_ERR 19.09.2021 21:14:45> Try Again #3 19.09.2021 21:14:45> 19.09.2021 21:14:45> Too Many Errors. Stopped. Err: -102/UNKN_ERR 19.09.2021 21:14:45> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 1, Err: -102/UNKN_ERR 19.09.2021 21:14:45> Try Again #1 19.09.2021 21:14:51> 19.09.2021 21:14:51> Error Reading Sector: 0, Count: 1, Err: -504/UNKN_ERR 19.09.2021 21:14:51> Try Again #2 19.09.2021 21:14:51> 19.09.2021 21:14:51> Error Reading Sector: 0, Count: 1, Err: -504/UNKN_ERR 19.09.2021 21:14:51> Try Again #3 19.09.2021 21:14:51> 19.09.2021 21:14:51> Too Many Errors. Stopped. Err: -504/UNKN_ERR 19.09.2021 21:15:11> Session is Closed.. 19.09.2021 21:15:11> ========================================= Thanks. |
09-26-2021, 19:57 | #21 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 79 | Beautifull..... Quote:
Now it's okay.. ----------------------------------------- Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started.. Box API Version: 3401 FS Driver Version: 29062020 SQLite Version: 3.32.0 FSCK Engine Version: 29062020 ESE DB Version: 29062020 System Util Version: 29062020 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz Total RAM: 3.88 GB Telegram Support: https://t.me/z3xefm FRP Apps: Z3X FRP Files Z3X Card Serial: AA254341 EasyJtag Plus Box Found at: COM3 EasyJtag Plus Box Firmware: 2.53.2 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: A0ABE638EDD3A90E EasyJtag Plus Box FirmWare: 2.53 Box Hardware = EasyJtag 2nd Generation UFS: Socket Info: S/N: 0x0123089213029CF5EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 Type: EasyJtag UFS Socket BGA-254 ID: 6194 UFS: Voltage Info: Mode: LOW VCC : 3332 mV, VCCQ2: 1929 mV 3v3 : 3382 mV, 1v2: 1226 mV UFS: Memory Info: Connection: UNKNOWN SOCKET TYPE Vendor: SAMSUNG Name: KM5H7001DM-B424 S/N: 486a5948e30c OEM ID: SAMSUNG_OEM_ID Firm Version: 6.00 Size: 0x000EE6800000/59.60 GB Max LUNs: 8 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 14950400 Block(s)/57.03 GB LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB LUN 3 -> Size: 8192 Block(s)/32.00 MB LUN 4 -> Size: 542720 Block(s)/2.07 GB LUN 5 -> Size: 114688 Block(s)/448.00 MB W-LUN 0xC4 (REPORT LUNS) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 1 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 2 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 3 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 4 GUID Partition Table is Found. Max Parts: 64 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 5 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Partition #4 mount as [/mnt/vendor/persist] -> 32.00 MB Partition #9 mount as [/cache] -> 448.00 MB Partition #13 mount as [/metadata] -> 16.00 MB Partition #14 mount as [/USERDATA] -> 48.44 GB Partition #40 mount as [/MODEM] -> 195.00 MB Partition #41 mount as [/BLUETOOTH] -> 1.00 MB Partition #45 mount as [/dev_45] -> 64.00 MB Partition #65 mount as [/LOGFS] -> 8.00 MB Partition #77 mount as [/my_custom] -> 256.00 MB Partition #79 mount as [/special_preload] -> 768.00 MB Partition #92 mount as [/mnt/vendor/opporeserve] -> 128.00 MB EmptyCheck: EMPTY -> #2 - [SSD] EMPTY -> #5 - [KEYSTORE] EMPTY -> #19 - [LAST_PARTI] EMPTY -> #23 - [LAST_PARTI] EMPTY -> #27 - [ALIGN_TO_128K_1] EMPTY -> #28 - [CDT] EMPTY -> #41 - [MDTPSECAPP] EMPTY -> #42 - [MDTP] EMPTY -> #56 - [DEVINFO] EMPTY -> #57 - [DIP] EMPTY -> #59 - [APDP_FULL] EMPTY -> #60 - [SPUNVM] EMPTY -> #62 - [LIMITS] EMPTY -> #63 - [TOOLSFV] EMPTY -> #65 - [CATELOADER] EMPTY -> #66 - [RAWDUMP] EMPTY -> #67 - [LOGDUMP] EMPTY -> #69 - [MULTIIMGOEM] EMPTY -> #70 - [MULTIIMGQTI] EMPTY -> #71 - [UEFIVARSTORE] EMPTY -> #72 - [SECDATA] EMPTY -> #73 - [CATEFV] EMPTY -> #74 - [CATECONTENTFV] EMPTY -> #79 - [LAST_PARTI] EMPTY -> #83 - [ALIGN_TO_128K_2] EMPTY -> #88 - [FSG] EMPTY -> #89 - [FSC] EMPTY -> #92 - [OPPORESERVE3] EMPTY -> #93 - [OPPORESERVE4] EMPTY -> #94 - [OPPORESERVE5] EMPTY -> #96 - [LAST_PARTI] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition #7 -> FRP ================================= Scanner Thread Terminated Elapsed: 00:00:42:878 Found 98 Partition(s).. Scan Done. Init Main Engine... Use EasyJtag UFS Device: KM5H7001DM-B424 Reader Engine Initialized.. 0/OK Source: EasyJtag Port [UFS] Power Mode: LOW Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1011111111101111 Operation Done: [Init Engine], Elapsed: 00:00:00:116 Universal Wipe User Data v1.0 Wiping MISC Partition.. Partition #5 is '/MISC'. Erasing.. Wipe Mode: Oppo/Vivo Factory Reset Wipe 'MISC' Partition Done.. Wiping PARA Partition.. Partition PARA Not Found. Skip.. Done Wiping Data.. Elapsed Time: [00:00:00:214] Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:214 ----------------------------------------- | |
The Following 3 Users Say Thank You to madcom5 For This Useful Post: |
12-15-2022, 20:36 | #26 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Sir This Resistors Modification Solution For All UFS Chips? Or Have To Reverse On Some Models? Also People Claiming After R4 And R5 Shorting Adapter Working Good. Need More Help Please. Thanks Anticipation | |
04-06-2023, 03:51 | #29 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: JO-JO-JO Age: 40
Member: 576742 Status: Offline Thanks Meter: 20 | Quote:
