Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #18 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 71 | Quote:
Connection: UNKNOWN SOCKET TYPE So do i have to change those resistors one time for all UFS Chips or every time i get that error? | |
![]() | #20 (permalink) |
Member: 2267293 Status: Offline Thanks Meter: 71 | I have not removed the chip from motherboard, i just soldered isp pinout on the socket, the bga254 ufs socket. It's oPPO a53 i want to remove password. The isp connection is okay because the phone is detected but giving errors when reading some partitions. See the log below.. ========================================= 19.09.2021 20:50:05> Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started.. 19.09.2021 20:50:13> Box API Version: 3401 19.09.2021 20:50:13> FS Driver Version: 29062020 19.09.2021 20:50:13> SQLite Version: 3.32.0 19.09.2021 20:50:13> FSCK Engine Version: 29062020 19.09.2021 20:50:13> ESE DB Version: 29062020 19.09.2021 20:50:13> System Util Version: 29062020 19.09.2021 20:50:13> System: Windows NT 6.2 (Build 9200) / 64 BIT 19.09.2021 20:50:13> CPU: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz 19.09.2021 20:50:13> Total RAM: 3.88 GB 19.09.2021 20:50:13> Telegram Support: https://t.me/z3xefm 19.09.2021 20:50:13> FRP Apps: Z3X FRP Files 19.09.2021 20:50:13> 19.09.2021 20:50:15> Z3X Card Serial: AA254341 19.09.2021 20:50:15> EasyJtag Plus Box Found at: COM3 19.09.2021 20:50:15> EasyJtag Plus Box Firmware: 2.53.2 19.09.2021 20:50:16> 19.09.2021 20:50:45> Source: EasyJtag Port [UFS] 19.09.2021 20:50:45> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 20:50:45> UFS Power Mode: LOW 19.09.2021 20:50:45> Scanner Thread Created.. 19.09.2021 20:50:45> 19.09.2021 20:50:45> Running EasyJtag UFS Mode... 19.09.2021 20:50:45> UFS ISP Mode: ON 19.09.2021 20:50:45> UFS Safe Mode: ON 19.09.2021 20:50:45> 19.09.2021 20:50:59> Init UFS Engine: 0/OK 19.09.2021 20:50:59> 19.09.2021 20:51:00> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 20:51:00> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 20:51:00> Box Hardware = EasyJtag 2nd Generation 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: Socket Info: 19.09.2021 20:51:00> S/N: 0x0123089213029CF5EE 19.09.2021 20:51:00> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 20:51:00> Type: EasyJtag UFS Socket BGA-254 19.09.2021 20:51:00> ID: 6194 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: Voltage Info: 19.09.2021 20:51:00> Mode: LOW 19.09.2021 20:51:00> VCC : 3332 mV, VCCQ2: 1931 mV 19.09.2021 20:51:00> 3v3 : 3383 mV, 1v2: 1228 mV 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: Memory Info: 19.09.2021 20:51:00> Connection: UNKNOWN SOCKET TYPE 19.09.2021 20:51:00> Vendor: SAMSUNG 19.09.2021 20:51:00> Name: KM5H7001DM-B424 19.09.2021 20:51:00> S/N: 486a5948e30c 19.09.2021 20:51:00> OEM ID: SAMSUNG_OEM_ID 19.09.2021 20:51:00> Firm Version: 6.00 19.09.2021 20:51:00> Size: 0x000EE6800000/59.60 GB 19.09.2021 20:51:00> Max LUNs: 8 19.09.2021 20:51:00> LUNs Cnt: 6 19.09.2021 20:51:00> W-LUNs Cnt: 1 19.09.2021 20:51:00> LUNs ReConfig: Enabled 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS Health Info: 19.09.2021 20:51:00> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 20:51:00> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 20:51:00> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS: LUNs Info: 19.09.2021 20:51:00> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 20:51:00> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 20:51:00> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 20:51:00> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 20:51:00> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 20:51:00> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 20:51:00> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 20:51:00> 19.09.2021 20:51:00> UFS Init OK 19.09.2021 20:51:00> Scanning Data From UFS Chip. Please wait.. 19.09.2021 20:51:00> 19.09.2021 20:51:00> Scanning GUID Partition Table from LUN 0 19.09.2021 20:51:00> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:00> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:00> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 20:51:00> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:00> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:00> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:00> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:00> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 20:51:00> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 20:51:00> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 20:51:00> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 20:51:00> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 20:51:00> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 20:51:00> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 20:51:00> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:00> Reading Table Completed 19.09.2021 20:51:00> Scanning GUID Partition Table from LUN 1 19.09.2021 20:51:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:01> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 20:51:01> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:01> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 20:51:01> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:01> Reading Table Completed 19.09.2021 20:51:01> Scanning GUID Partition Table from LUN 2 19.09.2021 20:51:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:01> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 20:51:01> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:01> Reading Table Completed 19.09.2021 20:51:01> Scanning GUID Partition Table from LUN 3 19.09.2021 20:51:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:01> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 20:51:01> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:01> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:01> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:01> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:01> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 20:51:01> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:01> Reading Table Completed 19.09.2021 20:51:01> Scanning GUID Partition Table from LUN 4 19.09.2021 20:51:02> GUID Partition Table is Found. Max Parts: 64 19.09.2021 20:51:02> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:02> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 20:51:02> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 20:51:02> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 20:51:02> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 20:51:02> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:02> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:02> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 20:51:02> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:02> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 20:51:02> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 20:51:02> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 20:51:02> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 20:51:02> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:02> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:02> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 20:51:02> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 20:51:02> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 20:51:02> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:02> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 20:51:02> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 20:51:02> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 20:51:02> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:02> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 20:51:02> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:02> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:02> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 20:51:02> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 20:51:02> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 20:51:02> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 20:51:02> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 20:51:02> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 20:51:02> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 20:51:02> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 20:51:02> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 20:51:02> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 20:51:02> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:02> Reading Table Completed 19.09.2021 20:51:02> Scanning GUID Partition Table from LUN 5 19.09.2021 20:51:03> GUID Partition Table is Found. Max Parts: 32 19.09.2021 20:51:03> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 20:51:03> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 20:51:03> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 20:51:03> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 20:51:03> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:03> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:03> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 20:51:03> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 20:51:03> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:03> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 20:51:03> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 20:51:03> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 20:51:03> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 20:51:03> Reading Table Completed 19.09.2021 20:51:03> 19.09.2021 20:51:03> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 20:51:03> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 20:51:04> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 20:51:04> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 20:51:05> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 20:51:05> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 20:51:05> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 20:51:07> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 20:52:48> 19.09.2021 20:52:48> Error Reading Sector: 181191, Count: 5, Err: -108/UNKN_ERR 19.09.2021 20:52:48> Try Again #1 19.09.2021 20:52:49> 19.09.2021 20:52:49> Error Reading Sector: 181191, Count: 5, Err: -101/UNKN_ERR 19.09.2021 20:52:49> Try Again #2 19.09.2021 20:52:49> 19.09.2021 20:52:49> Error Reading Sector: 181191, Count: 5, Err: -103/UNKN_ERR 19.09.2021 20:52:49> Try Again #3 19.09.2021 20:52:49> 19.09.2021 20:52:49> Too Many Errors. Stopped. Err: -103/UNKN_ERR 19.09.2021 20:52:49> Error While Reading. Exit. Code: -103 19.09.2021 20:52:49> 19.09.2021 20:52:49> Scanner Thread Terminated 19.09.2021 20:52:49> Elapsed: 00:02:04:334 19.09.2021 20:52:49> Found 98 Partition(s).. 19.09.2021 20:52:49> Scan Done. Init Main Engine... 19.09.2021 20:52:49> 19.09.2021 20:52:49> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 20:52:49> 19.09.2021 20:52:49> Reader Engine Initialized.. 0/OK 19.09.2021 20:52:49> Source: EasyJtag Port [UFS] 19.09.2021 20:52:49> Power Mode: LOW 19.09.2021 20:52:49> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 20:52:49> Config: 1011111111101111 19.09.2021 20:52:49> Operation Done: [Init Engine], Elapsed: 00:00:00:047 19.09.2021 20:52:49> 19.09.2021 20:52:50> Error While Switch LUN: -103 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #1 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #2 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #3 19.09.2021 20:52:50> 19.09.2021 20:52:50> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 20:52:50> Error While Switch LUN: -103 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #1 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #2 19.09.2021 20:52:50> 19.09.2021 20:52:50> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 20:52:50> Try Again #3 19.09.2021 20:52:50> 19.09.2021 20:52:50> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:04:20> Session is Closed.. 19.09.2021 21:04:20> 19.09.2021 21:04:43> Source: EasyJtag Port [UFS] 19.09.2021 21:04:43> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:04:43> UFS Power Mode: HIGH 19.09.2021 21:04:43> Scanner Thread Created.. 19.09.2021 21:04:43> 19.09.2021 21:04:43> Running EasyJtag UFS Mode... 19.09.2021 21:04:43> UFS ISP Mode: ON 19.09.2021 21:04:43> UFS Safe Mode: ON 19.09.2021 21:04:43> 19.09.2021 21:04:57> Init UFS Engine: 0/OK 19.09.2021 21:04:57> 19.09.2021 21:04:58> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 21:04:58> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 21:04:58> Box Hardware = EasyJtag 2nd Generation 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: Socket Info: 19.09.2021 21:04:58> S/N: 0x0123089213029CF5EE 19.09.2021 21:04:58> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 21:04:58> Type: EasyJtag UFS Socket BGA-254 19.09.2021 21:04:58> ID: 6194 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: Voltage Info: 19.09.2021 21:04:58> Mode: HIGH 19.09.2021 21:04:58> VCC : 3332 mV, VCCQ2: 1929 mV 19.09.2021 21:04:58> 3v3 : 3383 mV, 1v2: 1228 mV 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: Memory Info: 19.09.2021 21:04:58> Connection: UNKNOWN SOCKET TYPE 19.09.2021 21:04:58> Vendor: SAMSUNG 19.09.2021 21:04:58> Name: KM5H7001DM-B424 19.09.2021 21:04:58> S/N: 486a5948e30c 19.09.2021 21:04:58> OEM ID: SAMSUNG_OEM_ID 19.09.2021 21:04:58> Firm Version: 6.00 19.09.2021 21:04:58> Size: 0x000EE6800000/59.60 GB 19.09.2021 21:04:58> Max LUNs: 8 19.09.2021 21:04:58> LUNs Cnt: 6 19.09.2021 21:04:58> W-LUNs Cnt: 1 19.09.2021 21:04:58> LUNs ReConfig: Enabled 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS Health Info: 19.09.2021 21:04:58> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:04:58> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:04:58> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS: LUNs Info: 19.09.2021 21:04:58> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 21:04:58> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:04:58> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:04:58> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 21:04:58> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 21:04:58> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 21:04:58> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 21:04:58> 19.09.2021 21:04:58> UFS Init OK 19.09.2021 21:04:58> Scanning Data From UFS Chip. Please wait.. 19.09.2021 21:04:58> 19.09.2021 21:04:58> Scanning GUID Partition Table from LUN 0 19.09.2021 21:04:58> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:04:58> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:04:58> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 21:04:58> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 21:04:58> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 21:04:58> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 21:04:58> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 21:04:58> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 21:04:58> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 21:04:58> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 21:04:59> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 21:04:59> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 21:04:59> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 21:04:59> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 21:04:59> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:04:59> Reading Table Completed 19.09.2021 21:04:59> Scanning GUID Partition Table from LUN 1 19.09.2021 21:04:59> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:04:59> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:04:59> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 21:04:59> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:04:59> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 21:04:59> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:04:59> Reading Table Completed 19.09.2021 21:04:59> Scanning GUID Partition Table from LUN 2 19.09.2021 21:04:59> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:04:59> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:04:59> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 21:04:59> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:04:59> Reading Table Completed 19.09.2021 21:04:59> Scanning GUID Partition Table from LUN 3 19.09.2021 21:04:59> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:05:00> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:05:00> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:05:00> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:00> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 21:05:00> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:05:00> Reading Table Completed 19.09.2021 21:05:00> Scanning GUID Partition Table from LUN 4 19.09.2021 21:05:00> GUID Partition Table is Found. Max Parts: 64 19.09.2021 21:05:00> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:05:00> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:05:00> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 21:05:00> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 21:05:00> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:05:00> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:00> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:00> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 21:05:00> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 21:05:00> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 21:05:00> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 21:05:00> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 21:05:00> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:00> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 21:05:00> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 21:05:00> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 21:05:00> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:00> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 21:05:00> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 21:05:00> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 21:05:00> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:00> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 21:05:00> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:00> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:00> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 21:05:00> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 21:05:00> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 21:05:00> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 21:05:00> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 21:05:00> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 21:05:00> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:05:00> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:05:00> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 21:05:00> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 21:05:00> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:05:00> Reading Table Completed 19.09.2021 21:05:01> Scanning GUID Partition Table from LUN 5 19.09.2021 21:05:01> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:05:01> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:05:01> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:05:01> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 21:05:01> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 21:05:01> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:01> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:01> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:05:01> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 21:05:01> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:01> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:05:01> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:05:01> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 21:05:01> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:05:01> Reading Table Completed 19.09.2021 21:05:01> 19.09.2021 21:05:01> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 21:05:01> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 21:05:02> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 21:05:02> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 21:05:03> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 21:05:03> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 21:05:03> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 21:05:04> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 21:05:04> Partition #77 mount as [/my_custom] - 256.00 MB 19.09.2021 21:05:05> Partition #79 mount as [/special_preload] - 768.00 MB 19.09.2021 21:05:05> Partition #92 mount as [/mnt/vendor/opporeserve] - 128.00 MB 19.09.2021 21:05:08> 19.09.2021 21:05:08> EmptyCheck: 19.09.2021 21:05:08> EMPTY - #2 - [SSD] 19.09.2021 21:05:08> EMPTY - #5 - [KEYSTORE] 19.09.2021 21:06:50> 19.09.2021 21:06:50> Error Reading Sector: 1670, Count: 64, Err: -108/UNKN_ERR 19.09.2021 21:06:50> Try Again #1 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 1670, Count: 64, Err: -504/UNKN_ERR 19.09.2021 21:06:56> Try Again #2 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 1670, Count: 64, Err: -504/UNKN_ERR 19.09.2021 21:06:56> Try Again #3 19.09.2021 21:06:56> 19.09.2021 21:06:56> Too Many Errors. Stopped. Err: -504/UNKN_ERR 19.09.2021 21:06:56> Error While Reading. Exit. Code: -504 19.09.2021 21:06:56> 19.09.2021 21:06:56> EmptyCheck: Fail.. 19.09.2021 21:06:56> EmptyCheck: Done 19.09.2021 21:06:56> 19.09.2021 21:06:56> Scanner Thread Terminated 19.09.2021 21:06:56> Elapsed: 00:02:13:379 19.09.2021 21:06:56> Found 98 Partition(s).. 19.09.2021 21:06:56> Scan Done. Init Main Engine... 19.09.2021 21:06:56> 19.09.2021 21:06:56> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 21:06:56> 19.09.2021 21:06:56> Reader Engine Initialized.. 0/OK 19.09.2021 21:06:56> Source: EasyJtag Port [UFS] 19.09.2021 21:06:56> Power Mode: HIGH 19.09.2021 21:06:56> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:06:56> Config: 1011111111101111 19.09.2021 21:06:56> Operation Done: [Init Engine], Elapsed: 00:00:00:085 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error While Switch LUN: -504 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #1 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #2 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #3 19.09.2021 21:06:56> 19.09.2021 21:06:56> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:06:56> Error While Switch LUN: -504 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #1 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #2 19.09.2021 21:06:56> 19.09.2021 21:06:56> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:06:56> Try Again #3 19.09.2021 21:06:56> 19.09.2021 21:06:56> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:07:53> Universal Wipe User Data v1.0 19.09.2021 21:07:53> 19.09.2021 21:07:55> Wiping MISC Partition.. 19.09.2021 21:07:55> Partition #5 is '/MISC'. Erasing.. 19.09.2021 21:07:55> Wipe Mode: Oppo/Vivo Factory Reset 19.09.2021 21:07:55> Error While Switch LUN: -504 19.09.2021 21:07:55> 19.09.2021 21:07:55> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:55> Try Again #1 19.09.2021 21:07:55> 19.09.2021 21:07:55> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:55> Try Again #2 19.09.2021 21:07:55> 19.09.2021 21:07:55> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:55> Try Again #3 19.09.2021 21:07:55> 19.09.2021 21:07:55> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:07:56> Error While Switch LUN: -504 19.09.2021 21:07:56> 19.09.2021 21:07:56> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:56> Try Again #1 19.09.2021 21:07:56> 19.09.2021 21:07:56> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:56> Try Again #2 19.09.2021 21:07:56> 19.09.2021 21:07:56> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:07:56> Try Again #3 19.09.2021 21:07:56> 19.09.2021 21:07:56> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:07:56> Error While Writing Data. Exit. Code: -700 19.09.2021 21:07:56> Operation Failure: [Universal Wipe Data], Code: -1, Elapsed: 00:00:00:250 19.09.2021 21:07:56> 19.09.2021 21:09:29> Source: EasyJtag Port [UFS] 19.09.2021 21:09:29> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:09:29> UFS Power Mode: HIGH 19.09.2021 21:09:29> Scanner Thread Created.. 19.09.2021 21:09:29> 19.09.2021 21:09:30> Running EasyJtag UFS Mode... 19.09.2021 21:09:30> UFS ISP Mode: ON 19.09.2021 21:09:30> UFS Safe Mode: ON 19.09.2021 21:09:30> 19.09.2021 21:09:44> Init UFS Engine: 0/OK 19.09.2021 21:09:44> 19.09.2021 21:09:44> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 21:09:44> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 21:09:44> Box Hardware = EasyJtag 2nd Generation 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: Socket Info: 19.09.2021 21:09:44> S/N: 0x0123089213029CF5EE 19.09.2021 21:09:44> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 21:09:44> Type: EasyJtag UFS Socket BGA-254 19.09.2021 21:09:44> ID: 6194 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: Voltage Info: 19.09.2021 21:09:44> Mode: HIGH 19.09.2021 21:09:44> VCC : 3333 mV, VCCQ2: 1928 mV 19.09.2021 21:09:44> 3v3 : 3382 mV, 1v2: 1228 mV 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: Memory Info: 19.09.2021 21:09:44> Connection: UNKNOWN SOCKET TYPE 19.09.2021 21:09:44> Vendor: SAMSUNG 19.09.2021 21:09:44> Name: KM5H7001DM-B424 19.09.2021 21:09:44> S/N: 486a5948e30c 19.09.2021 21:09:44> OEM ID: SAMSUNG_OEM_ID 19.09.2021 21:09:44> Firm Version: 6.00 19.09.2021 21:09:44> Size: 0x000EE6800000/59.60 GB 19.09.2021 21:09:44> Max LUNs: 8 19.09.2021 21:09:44> LUNs Cnt: 6 19.09.2021 21:09:44> W-LUNs Cnt: 1 19.09.2021 21:09:44> LUNs ReConfig: Enabled 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS Health Info: 19.09.2021 21:09:44> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:09:44> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:09:44> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 21:09:44> 19.09.2021 21:09:44> UFS: LUNs Info: 19.09.2021 21:09:44> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 21:09:44> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:09:44> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:09:45> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 21:09:45> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 21:09:45> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 21:09:45> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 21:09:45> 19.09.2021 21:09:45> UFS Init OK 19.09.2021 21:09:45> Scanning Data From UFS Chip. Please wait.. 19.09.2021 21:09:45> 19.09.2021 21:09:45> Scanning GUID Partition Table from LUN 0 19.09.2021 21:09:45> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:45> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:45> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 21:09:45> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:45> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:45> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:45> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:45> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 21:09:45> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 21:09:45> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 21:09:45> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 21:09:45> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 21:09:45> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 21:09:45> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 21:09:45> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:45> Reading Table Completed 19.09.2021 21:09:45> Scanning GUID Partition Table from LUN 1 19.09.2021 21:09:45> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:45> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:45> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 21:09:45> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:45> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 21:09:45> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:45> Reading Table Completed 19.09.2021 21:09:45> Scanning GUID Partition Table from LUN 2 19.09.2021 21:09:46> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:46> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:46> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 21:09:46> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:46> Reading Table Completed 19.09.2021 21:09:46> Scanning GUID Partition Table from LUN 3 19.09.2021 21:09:46> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:46> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:46> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:09:46> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:46> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 21:09:46> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:46> Reading Table Completed 19.09.2021 21:09:46> Scanning GUID Partition Table from LUN 4 19.09.2021 21:09:46> GUID Partition Table is Found. Max Parts: 64 19.09.2021 21:09:46> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:46> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:09:46> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 21:09:46> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 21:09:46> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:09:46> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:46> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:46> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 21:09:46> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:46> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 21:09:46> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 21:09:46> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 21:09:46> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 21:09:46> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:46> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:46> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 21:09:46> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:46> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 21:09:47> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 21:09:47> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:47> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 21:09:47> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 21:09:47> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:47> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 21:09:47> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 21:09:47> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:47> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:47> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 21:09:47> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 21:09:47> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:47> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 21:09:47> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 21:09:47> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 21:09:47> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 21:09:47> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:09:47> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:09:47> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 21:09:47> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 21:09:47> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:47> Reading Table Completed 19.09.2021 21:09:47> Scanning GUID Partition Table from LUN 5 19.09.2021 21:09:47> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:09:47> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:09:47> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:09:47> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 21:09:47> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 21:09:47> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:09:47> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 21:09:47> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:47> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:09:47> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:09:47> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 21:09:47> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:09:47> Reading Table Completed 19.09.2021 21:09:47> 19.09.2021 21:09:48> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 21:09:48> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 21:09:48> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 21:09:48> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 21:09:49> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 21:09:49> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 21:09:49> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 21:09:50> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 21:09:51> Partition #77 mount as [/my_custom] - 256.00 MB 19.09.2021 21:09:51> Partition #79 mount as [/special_preload] - 768.00 MB 19.09.2021 21:09:52> Partition #92 mount as [/mnt/vendor/opporeserve] - 128.00 MB 19.09.2021 21:09:55> 19.09.2021 21:09:55> EmptyCheck: 19.09.2021 21:09:55> EMPTY - #2 - [SSD] 19.09.2021 21:09:55> EMPTY - #5 - [KEYSTORE] 19.09.2021 21:09:56> EMPTY - #19 - [LAST_PARTI] 19.09.2021 21:09:56> EMPTY - #23 - [LAST_PARTI] 19.09.2021 21:09:56> EMPTY - #27 - [ALIGN_TO_128K_1] 19.09.2021 21:09:57> EMPTY - #28 - [CDT] 19.09.2021 21:09:57> EMPTY - #41 - [MDTPSECAPP] 19.09.2021 21:09:57> EMPTY - #42 - [MDTP] 19.09.2021 21:09:58> EMPTY - #56 - [DEVINFO] 19.09.2021 21:09:58> EMPTY - #57 - [DIP] 19.09.2021 21:09:58> EMPTY - #59 - [APDP_FULL] 19.09.2021 21:09:58> EMPTY - #60 - [SPUNVM] 19.09.2021 21:09:58> EMPTY - #62 - [LIMITS] 19.09.2021 21:09:59> EMPTY - #63 - [TOOLSFV] 19.09.2021 21:09:59> EMPTY - #65 - [CATELOADER] 19.09.2021 21:09:59> EMPTY - #66 - [RAWDUMP] 19.09.2021 21:09:59> EMPTY - #67 - [LOGDUMP] 19.09.2021 21:09:59> EMPTY - #69 - [MULTIIMGOEM] 19.09.2021 21:11:40> 19.09.2021 21:11:40> Error Reading Sector: 180920, Count: 8, Err: -108/UNKN_ERR 19.09.2021 21:11:40> Try Again #1 19.09.2021 21:11:41> 19.09.2021 21:11:41> Error Reading Sector: 180920, Count: 8, Err: -101/UNKN_ERR 19.09.2021 21:11:41> Try Again #2 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 180920, Count: 8, Err: -103/UNKN_ERR 19.09.2021 21:11:42> Try Again #3 19.09.2021 21:11:42> 19.09.2021 21:11:42> Too Many Errors. Stopped. Err: -103/UNKN_ERR 19.09.2021 21:11:42> Error While Reading. Exit. Code: -103 19.09.2021 21:11:42> 19.09.2021 21:11:42> EmptyCheck: Fail.. 19.09.2021 21:11:42> EmptyCheck: Done 19.09.2021 21:11:42> 19.09.2021 21:11:42> Scanner Thread Terminated 19.09.2021 21:11:42> Elapsed: 00:02:12:199 19.09.2021 21:11:42> Found 98 Partition(s).. 19.09.2021 21:11:42> Scan Done. Init Main Engine... 19.09.2021 21:11:42> 19.09.2021 21:11:42> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 21:11:42> 19.09.2021 21:11:42> Reader Engine Initialized.. 0/OK 19.09.2021 21:11:42> Source: EasyJtag Port [UFS] 19.09.2021 21:11:42> Power Mode: HIGH 19.09.2021 21:11:42> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:11:42> Config: 1011111111101111 19.09.2021 21:11:42> Operation Done: [Init Engine], Elapsed: 00:00:00:032 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error While Switch LUN: -103 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #1 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #2 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #3 19.09.2021 21:11:42> 19.09.2021 21:11:42> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:11:42> Error While Switch LUN: -103 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #1 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #2 19.09.2021 21:11:42> 19.09.2021 21:11:42> Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:11:42> Try Again #3 19.09.2021 21:11:42> 19.09.2021 21:11:42> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:12:00> Universal Wipe User Data v1.0 19.09.2021 21:12:00> 19.09.2021 21:12:02> Wiping MISC Partition.. 19.09.2021 21:12:02> Partition #5 is '/MISC'. Erasing.. 19.09.2021 21:12:02> Wipe Mode: Oppo/Vivo Factory Reset 19.09.2021 21:12:02> Error While Switch LUN: -103 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #1 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #2 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Writing Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #3 19.09.2021 21:12:02> 19.09.2021 21:12:02> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:12:02> Error While Switch LUN: -103 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #1 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #2 19.09.2021 21:12:02> 19.09.2021 21:12:02> Error Reading Sector: 8200, Count: 1, Err: -700/UNKN_ERR 19.09.2021 21:12:02> Try Again #3 19.09.2021 21:12:02> 19.09.2021 21:12:02> Too Many Errors. Stopped. Err: -700/UNKN_ERR 19.09.2021 21:12:02> Error While Writing Data. Exit. Code: -700 19.09.2021 21:12:02> Operation Failure: [Universal Wipe Data], Code: -1, Elapsed: 00:00:00:310 19.09.2021 21:12:02> 19.09.2021 21:12:24> Source: EasyJtag Port [UFS] 19.09.2021 21:12:24> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:12:24> UFS Power Mode: HIGH 19.09.2021 21:12:24> Scanner Thread Created.. 19.09.2021 21:12:24> 19.09.2021 21:12:24> Running EasyJtag UFS Mode... 19.09.2021 21:12:24> UFS ISP Mode: ON 19.09.2021 21:12:24> UFS Safe Mode: ON 19.09.2021 21:12:24> 19.09.2021 21:12:38> Init UFS Engine: 0/OK 19.09.2021 21:12:38> 19.09.2021 21:12:39> EasyJtag Plus S/N: A0ABE638EDD3A90E 19.09.2021 21:12:39> EasyJtag Plus Box FirmWare: 2.53 19.09.2021 21:12:39> Box Hardware = EasyJtag 2nd Generation 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: Socket Info: 19.09.2021 21:12:39> S/N: 0x0123089213029CF5EE 19.09.2021 21:12:39> Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 19.09.2021 21:12:39> Type: EasyJtag UFS Socket BGA-254 19.09.2021 21:12:39> ID: 6194 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: Voltage Info: 19.09.2021 21:12:39> Mode: HIGH 19.09.2021 21:12:39> VCC : 3334 mV, VCCQ2: 1928 mV 19.09.2021 21:12:39> 3v3 : 3382 mV, 1v2: 1225 mV 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: Memory Info: 19.09.2021 21:12:39> Connection: UNKNOWN SOCKET TYPE 19.09.2021 21:12:39> Vendor: SAMSUNG 19.09.2021 21:12:39> Name: KM5H7001DM-B424 19.09.2021 21:12:39> S/N: 486a5948e30c 19.09.2021 21:12:39> OEM ID: SAMSUNG_OEM_ID 19.09.2021 21:12:39> Firm Version: 6.00 19.09.2021 21:12:39> Size: 0x000EE6800000/59.60 GB 19.09.2021 21:12:39> Max LUNs: 8 19.09.2021 21:12:39> LUNs Cnt: 6 19.09.2021 21:12:39> W-LUNs Cnt: 1 19.09.2021 21:12:39> LUNs ReConfig: Enabled 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS Health Info: 19.09.2021 21:12:39> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:12:39> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 19.09.2021 21:12:39> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS: LUNs Info: 19.09.2021 21:12:39> LUN 0 - Size: 14950400 Block(s)/57.03 GB 19.09.2021 21:12:39> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:12:39> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 19.09.2021 21:12:39> LUN 3 - Size: 8192 Block(s)/32.00 MB 19.09.2021 21:12:39> LUN 4 - Size: 542720 Block(s)/2.07 GB 19.09.2021 21:12:39> LUN 5 - Size: 114688 Block(s)/448.00 MB 19.09.2021 21:12:39> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 19.09.2021 21:12:39> 19.09.2021 21:12:39> UFS Init OK 19.09.2021 21:12:39> Scanning Data From UFS Chip. Please wait.. 19.09.2021 21:12:39> 19.09.2021 21:12:39> Scanning GUID Partition Table from LUN 0 19.09.2021 21:12:39> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:39> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:39> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 19.09.2021 21:12:39> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:39> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:39> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:39> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:39> GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB 19.09.2021 21:12:39> GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB 19.09.2021 21:12:39> GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB 19.09.2021 21:12:39> GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB 19.09.2021 21:12:39> GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB 19.09.2021 21:12:39> GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB 19.09.2021 21:12:39> GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB 19.09.2021 21:12:39> GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:39> Reading Table Completed 19.09.2021 21:12:39> Scanning GUID Partition Table from LUN 1 19.09.2021 21:12:40> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:40> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:40> GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB 19.09.2021 21:12:40> GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:40> GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB 19.09.2021 21:12:40> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:40> Reading Table Completed 19.09.2021 21:12:40> Scanning GUID Partition Table from LUN 2 19.09.2021 21:12:40> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:40> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:40> GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB 19.09.2021 21:12:40> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:40> Reading Table Completed 19.09.2021 21:12:40> Scanning GUID Partition Table from LUN 3 19.09.2021 21:12:40> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:40> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:40> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:12:40> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:40> GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:40> GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:40> GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:40> GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB 19.09.2021 21:12:40> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:40> Reading Table Completed 19.09.2021 21:12:40> Scanning GUID Partition Table from LUN 4 19.09.2021 21:12:41> GUID Partition Table is Found. Max Parts: 64 19.09.2021 21:12:41> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:41> GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:12:41> GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB 19.09.2021 21:12:41> GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB 19.09.2021 21:12:41> GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB 19.09.2021 21:12:41> GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:41> GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:41> GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB 19.09.2021 21:12:41> GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:41> GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB 19.09.2021 21:12:41> GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB 19.09.2021 21:12:41> GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB 19.09.2021 21:12:41> GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB 19.09.2021 21:12:41> GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:41> GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:41> GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB 19.09.2021 21:12:41> GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB 19.09.2021 21:12:41> GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB 19.09.2021 21:12:41> GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:41> GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB 19.09.2021 21:12:41> GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB 19.09.2021 21:12:41> GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB 19.09.2021 21:12:41> GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:41> GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB 19.09.2021 21:12:41> GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:41> GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:41> GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB 19.09.2021 21:12:41> GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB 19.09.2021 21:12:41> GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB 19.09.2021 21:12:41> GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB 19.09.2021 21:12:41> GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB 19.09.2021 21:12:41> GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB 19.09.2021 21:12:41> GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:12:41> GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB 19.09.2021 21:12:41> GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB 19.09.2021 21:12:41> GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB 19.09.2021 21:12:41> GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:41> Reading Table Completed 19.09.2021 21:12:41> Scanning GUID Partition Table from LUN 5 19.09.2021 21:12:42> GUID Partition Table is Found. Max Parts: 32 19.09.2021 21:12:42> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 19.09.2021 21:12:42> GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB 19.09.2021 21:12:42> GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB 19.09.2021 21:12:42> GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB 19.09.2021 21:12:42> GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:42> GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:42> GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB 19.09.2021 21:12:42> GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB 19.09.2021 21:12:42> GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:42> GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB 19.09.2021 21:12:42> GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB 19.09.2021 21:12:42> GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB 19.09.2021 21:12:42> GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB 19.09.2021 21:12:42> Reading Table Completed 19.09.2021 21:12:42> 19.09.2021 21:12:42> Partition #4 mount as [/mnt/vendor/persist] - 32.00 MB 19.09.2021 21:12:42> Partition #9 mount as [/cache] - 448.00 MB 19.09.2021 21:12:42> Partition #13 mount as [/metadata] - 16.00 MB 19.09.2021 21:12:43> Partition #14 mount as [/USERDATA] - 48.44 GB 19.09.2021 21:12:44> Partition #40 mount as [/MODEM] - 195.00 MB 19.09.2021 21:12:44> Partition #41 mount as [/BLUETOOTH] - 1.00 MB 19.09.2021 21:12:44> Partition #45 mount as [/dev_45] - 64.00 MB 19.09.2021 21:12:45> Partition #65 mount as [/LOGFS] - 8.00 MB 19.09.2021 21:12:45> Partition #77 mount as [/my_custom] - 256.00 MB 19.09.2021 21:12:45> Partition #79 mount as [/special_preload] - 768.00 MB 19.09.2021 21:12:46> Partition #92 mount as [/mnt/vendor/opporeserve] - 128.00 MB 19.09.2021 21:12:49> 19.09.2021 21:12:49> EmptyCheck: 19.09.2021 21:12:49> EMPTY - #2 - [SSD] 19.09.2021 21:12:49> EMPTY - #5 - [KEYSTORE] 19.09.2021 21:12:50> EMPTY - #19 - [LAST_PARTI] 19.09.2021 21:12:50> EMPTY - #23 - [LAST_PARTI] 19.09.2021 21:12:51> EMPTY - #27 - [ALIGN_TO_128K_1] 19.09.2021 21:12:51> EMPTY - #28 - [CDT] 19.09.2021 21:12:51> EMPTY - #41 - [MDTPSECAPP] 19.09.2021 21:12:51> EMPTY - #42 - [MDTP] 19.09.2021 21:12:52> EMPTY - #56 - [DEVINFO] 19.09.2021 21:12:52> EMPTY - #57 - [DIP] 19.09.2021 21:12:52> EMPTY - #59 - [APDP_FULL] 19.09.2021 21:12:52> EMPTY - #60 - [SPUNVM] 19.09.2021 21:12:52> EMPTY - #62 - [LIMITS] 19.09.2021 21:12:53> EMPTY - #63 - [TOOLSFV] 19.09.2021 21:12:53> EMPTY - #65 - [CATELOADER] 19.09.2021 21:12:53> EMPTY - #66 - [RAWDUMP] 19.09.2021 21:12:53> EMPTY - #67 - [LOGDUMP] 19.09.2021 21:12:53> EMPTY - #69 - [MULTIIMGOEM] 19.09.2021 21:12:53> EMPTY - #70 - [MULTIIMGQTI] 19.09.2021 21:12:53> EMPTY - #71 - [UEFIVARSTORE] 19.09.2021 21:12:53> EMPTY - #72 - [SECDATA] 19.09.2021 21:12:54> EMPTY - #73 - [CATEFV] 19.09.2021 21:12:54> EMPTY - #74 - [CATECONTENTFV] 19.09.2021 21:12:54> EMPTY - #79 - [LAST_PARTI] 19.09.2021 21:12:54> EMPTY - #83 - [ALIGN_TO_128K_2] 19.09.2021 21:12:55> EMPTY - #88 - [FSG] 19.09.2021 21:12:55> EMPTY - #89 - [FSC] 19.09.2021 21:12:55> EMPTY - #92 - [OPPORESERVE3] 19.09.2021 21:12:55> EMPTY - #93 - [OPPORESERVE4] 19.09.2021 21:12:55> EMPTY - #94 - [OPPORESERVE5] 19.09.2021 21:12:56> EMPTY - #96 - [LAST_PARTI] 19.09.2021 21:12:56> EmptyCheck: Done 19.09.2021 21:12:56> 19.09.2021 21:12:56> ================================= 19.09.2021 21:12:56> Warning! Device Blocked by FRP 19.09.2021 21:12:56> For Reset FRP Try to Tools Tab 19.09.2021 21:12:56> Press Reset FRP Button 19.09.2021 21:12:56> Partition #7 - FRP 19.09.2021 21:12:56> ================================= 19.09.2021 21:13:04> 19.09.2021 21:13:04> Scanner Thread Terminated 19.09.2021 21:13:04> Elapsed: 00:00:40:472 19.09.2021 21:13:04> Found 98 Partition(s).. 19.09.2021 21:13:04> Scan Done. Init Main Engine... 19.09.2021 21:13:04> 19.09.2021 21:13:04> Use EasyJtag UFS Device: KM5H7001DM-B424 19.09.2021 21:13:04> 19.09.2021 21:13:04> Reader Engine Initialized.. 0/OK 19.09.2021 21:13:04> Source: EasyJtag Port [UFS] 19.09.2021 21:13:04> Power Mode: HIGH 19.09.2021 21:13:04> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 19.09.2021 21:13:04> Config: 1011111111101111 19.09.2021 21:13:04> Operation Done: [Init Engine], Elapsed: 00:00:00:038 19.09.2021 21:13:04> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 57, Err: -108/UNKN_ERR 19.09.2021 21:14:45> Try Again #1 19.09.2021 21:14:45> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 57, Err: -102/UNKN_ERR 19.09.2021 21:14:45> Try Again #2 19.09.2021 21:14:45> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 57, Err: -102/UNKN_ERR 19.09.2021 21:14:45> Try Again #3 19.09.2021 21:14:45> 19.09.2021 21:14:45> Too Many Errors. Stopped. Err: -102/UNKN_ERR 19.09.2021 21:14:45> 19.09.2021 21:14:45> Error Reading Sector: 0, Count: 1, Err: -102/UNKN_ERR 19.09.2021 21:14:45> Try Again #1 19.09.2021 21:14:51> 19.09.2021 21:14:51> Error Reading Sector: 0, Count: 1, Err: -504/UNKN_ERR 19.09.2021 21:14:51> Try Again #2 19.09.2021 21:14:51> 19.09.2021 21:14:51> Error Reading Sector: 0, Count: 1, Err: -504/UNKN_ERR 19.09.2021 21:14:51> Try Again #3 19.09.2021 21:14:51> 19.09.2021 21:14:51> Too Many Errors. Stopped. Err: -504/UNKN_ERR 19.09.2021 21:15:11> Session is Closed.. 19.09.2021 21:15:11> ========================================= Thanks. |
![]() | #21 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 71 | Beautifull..... Quote:
Now it's okay.. ----------------------------------------- Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started.. Box API Version: 3401 FS Driver Version: 29062020 SQLite Version: 3.32.0 FSCK Engine Version: 29062020 ESE DB Version: 29062020 System Util Version: 29062020 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz Total RAM: 3.88 GB Telegram Support: https://t.me/z3xefm FRP Apps: Z3X FRP Files Z3X Card Serial: AA254341 EasyJtag Plus Box Found at: COM3 EasyJtag Plus Box Firmware: 2.53.2 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: A0ABE638EDD3A90E EasyJtag Plus Box FirmWare: 2.53 Box Hardware = EasyJtag 2nd Generation UFS: Socket Info: S/N: 0x0123089213029CF5EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.06.21 Type: EasyJtag UFS Socket BGA-254 ID: 6194 UFS: Voltage Info: Mode: LOW VCC : 3332 mV, VCCQ2: 1929 mV 3v3 : 3382 mV, 1v2: 1226 mV UFS: Memory Info: Connection: UNKNOWN SOCKET TYPE Vendor: SAMSUNG Name: KM5H7001DM-B424 S/N: 486a5948e30c OEM ID: SAMSUNG_OEM_ID Firm Version: 6.00 Size: 0x000EE6800000/59.60 GB Max LUNs: 8 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 14950400 Block(s)/57.03 GB LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB LUN 3 -> Size: 8192 Block(s)/32.00 MB LUN 4 -> Size: 542720 Block(s)/2.07 GB LUN 5 -> Size: 114688 Block(s)/448.00 MB W-LUN 0xC4 (REPORT LUNS) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB GPT: SUPER [000002208000 - 000200800000] Size: 8.01 GB GPT: CACHE [000202A08000 - 00001C000000] Size: 448.00 MB GPT: RECOVERY [00021EA08000 - 000006000000] Size: 96.00 MB GPT: VBMETA_SYSTEM [000224A08000 - 000000010000] Size: 64.00 KB GPT: VBMETA_VENDOR [000224A18000 - 000000010000] Size: 64.00 KB GPT: METADATA [000224A28000 - 000001000000] Size: 16.00 MB GPT: USERDATA [000225A28000 - 000C1C5D3000] Size: 48.44 GB GPT: BACKUP_GPT [000E41FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 1 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBL [000000006000 - 000000600000] Size: 6.00 MB GPT: XBL_CONFIG [000000606000 - 000000080000] Size: 512.00 KB GPT: LAST_PARTI [000000686000 - 000000175000] Size: 1.46 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 2 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: LAST_PARTI [000000006000 - 0000007F5000] Size: 7.96 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 3 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB GPT: DDR [000000040000 - 000000200000] Size: 2.00 MB GPT: ENGINEERING_CDT [000000240000 - 000000100000] Size: 1.00 MB GPT: OCDT [000000340000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [000000360000 - 000001C9B000] Size: 28.61 MB GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 4 GUID Partition Table is Found. Max Parts: 64 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB GPT: HYP [000000486000 - 000000800000] Size: 8.00 MB GPT: MODEM [000000C86000 - 00000C300000] Size: 195.00 MB GPT: BLUETOOTH [00000CF86000 - 000000100000] Size: 1.00 MB GPT: MDTPSECAPP [00000D086000 - 000000400000] Size: 4.00 MB GPT: MDTP [00000D486000 - 000002000000] Size: 32.00 MB GPT: ABL [00000F486000 - 000000100000] Size: 1.00 MB GPT: DSP [00000F586000 - 000004000000] Size: 64.00 MB GPT: KEYMASTER [000013586000 - 000000080000] Size: 512.00 KB GPT: BOOT [000013606000 - 000006000000] Size: 96.00 MB GPT: CMNLIB [000019606000 - 000000080000] Size: 512.00 KB GPT: CMNLIB64 [000019686000 - 000000080000] Size: 512.00 KB GPT: DEVCFG [000019706000 - 000000020000] Size: 128.00 KB GPT: QUPFW [000019726000 - 000000014000] Size: 80.00 KB GPT: VBMETA [00001973A000 - 000000010000] Size: 64.00 KB GPT: DTBO [00001974A000 - 000001800000] Size: 24.00 MB GPT: IMAGEFV [00001AF4A000 - 000000400000] Size: 4.00 MB GPT: UEFISECAPP [00001B34A000 - 000000200000] Size: 2.00 MB GPT: FEATENABLER [00001B54A000 - 000000020000] Size: 128.00 KB GPT: DEVINFO [00001B56A000 - 000000001000] Size: 4.00 KB GPT: DIP [00001B56B000 - 000000100000] Size: 1.00 MB GPT: APDP [00001B66B000 - 000000040000] Size: 256.00 KB GPT: APDP_FULL [00001B6AB000 - 000000040000] Size: 256.00 KB GPT: SPUNVM [00001B6EB000 - 000002000000] Size: 32.00 MB GPT: SPLASH [00001D6EB000 - 0000020A4000] Size: 32.64 MB GPT: LIMITS [00001F78F000 - 000000001000] Size: 4.00 KB GPT: TOOLSFV [00001F790000 - 000000100000] Size: 1.00 MB GPT: LOGFS [00001F890000 - 000000800000] Size: 8.00 MB GPT: CATELOADER [000020090000 - 000000200000] Size: 2.00 MB GPT: RAWDUMP [000020290000 - 000008000000] Size: 128.00 MB GPT: LOGDUMP [000028290000 - 000004000000] Size: 64.00 MB GPT: STORSEC [00002C290000 - 000000020000] Size: 128.00 KB GPT: MULTIIMGOEM [00002C2B0000 - 000000008000] Size: 32.00 KB GPT: MULTIIMGQTI [00002C2B8000 - 000000008000] Size: 32.00 KB GPT: UEFIVARSTORE [00002C2C0000 - 000000080000] Size: 512.00 KB GPT: SECDATA [00002C340000 - 000000007000] Size: 28.00 KB GPT: CATEFV [00002C347000 - 000000080000] Size: 512.00 KB GPT: CATECONTENTFV [00002C3C7000 - 000000100000] Size: 1.00 MB GPT: OPPO_SEC [00002C4C7000 - 000000A00000] Size: 10.00 MB GPT: CUSTOM [00002CEC7000 - 000010000000] Size: 256.00 MB GPT: ODM [00003CEC7000 - 000010000000] Size: 256.00 MB GPT: PRELOAD [00004CEC7000 - 000030000000] Size: 768.00 MB GPT: LAST_PARTI [00007CEC7000 - 000007934000] Size: 121.20 MB GPT: BACKUP_GPT [0000847FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 5 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB GPT: OPPODYCNVBK [000000020000 - 000001400000] Size: 20.00 MB GPT: OPPOSTANVBK [000001420000 - 000001400000] Size: 20.00 MB GPT: MODEMST1 [000002820000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [000002A20000 - 000000200000] Size: 2.00 MB GPT: FSG [000002C20000 - 000000200000] Size: 2.00 MB GPT: FSC [000002E20000 - 000000020000] Size: 128.00 KB GPT: OPPORESERVE1 [000002E40000 - 000000800000] Size: 8.00 MB GPT: OPPORESERVE2 [000003640000 - 000008000000] Size: 128.00 MB GPT: OPPORESERVE3 [00000B640000 - 000004000000] Size: 64.00 MB GPT: OPPORESERVE4 [00000F640000 - 000002000000] Size: 32.00 MB GPT: OPPORESERVE5 [000011640000 - 000004000000] Size: 64.00 MB GPT: DRIVER [000015640000 - 000002000000] Size: 32.00 MB GPT: LAST_PARTI [000017640000 - 0000049BB000] Size: 73.73 MB GPT: BACKUP_GPT [00001BFFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Partition #4 mount as [/mnt/vendor/persist] -> 32.00 MB Partition #9 mount as [/cache] -> 448.00 MB Partition #13 mount as [/metadata] -> 16.00 MB Partition #14 mount as [/USERDATA] -> 48.44 GB Partition #40 mount as [/MODEM] -> 195.00 MB Partition #41 mount as [/BLUETOOTH] -> 1.00 MB Partition #45 mount as [/dev_45] -> 64.00 MB Partition #65 mount as [/LOGFS] -> 8.00 MB Partition #77 mount as [/my_custom] -> 256.00 MB Partition #79 mount as [/special_preload] -> 768.00 MB Partition #92 mount as [/mnt/vendor/opporeserve] -> 128.00 MB EmptyCheck: EMPTY -> #2 - [SSD] EMPTY -> #5 - [KEYSTORE] EMPTY -> #19 - [LAST_PARTI] EMPTY -> #23 - [LAST_PARTI] EMPTY -> #27 - [ALIGN_TO_128K_1] EMPTY -> #28 - [CDT] EMPTY -> #41 - [MDTPSECAPP] EMPTY -> #42 - [MDTP] EMPTY -> #56 - [DEVINFO] EMPTY -> #57 - [DIP] EMPTY -> #59 - [APDP_FULL] EMPTY -> #60 - [SPUNVM] EMPTY -> #62 - [LIMITS] EMPTY -> #63 - [TOOLSFV] EMPTY -> #65 - [CATELOADER] EMPTY -> #66 - [RAWDUMP] EMPTY -> #67 - [LOGDUMP] EMPTY -> #69 - [MULTIIMGOEM] EMPTY -> #70 - [MULTIIMGQTI] EMPTY -> #71 - [UEFIVARSTORE] EMPTY -> #72 - [SECDATA] EMPTY -> #73 - [CATEFV] EMPTY -> #74 - [CATECONTENTFV] EMPTY -> #79 - [LAST_PARTI] EMPTY -> #83 - [ALIGN_TO_128K_2] EMPTY -> #88 - [FSG] EMPTY -> #89 - [FSC] EMPTY -> #92 - [OPPORESERVE3] EMPTY -> #93 - [OPPORESERVE4] EMPTY -> #94 - [OPPORESERVE5] EMPTY -> #96 - [LAST_PARTI] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition #7 -> FRP ================================= Scanner Thread Terminated Elapsed: 00:00:42:878 Found 98 Partition(s).. Scan Done. Init Main Engine... Use EasyJtag UFS Device: KM5H7001DM-B424 Reader Engine Initialized.. 0/OK Source: EasyJtag Port [UFS] Power Mode: LOW Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1011111111101111 Operation Done: [Init Engine], Elapsed: 00:00:00:116 Universal Wipe User Data v1.0 Wiping MISC Partition.. Partition #5 is '/MISC'. Erasing.. Wipe Mode: Oppo/Vivo Factory Reset Wipe 'MISC' Partition Done.. Wiping PARA Partition.. Partition PARA Not Found. Skip.. Done Wiping Data.. Elapsed Time: [00:00:00:214] Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:214 ----------------------------------------- | |
The Following 3 Users Say Thank You to madcom5 For This Useful Post: |
