Kmdx60018m firmware update failed 3 Attachment(s) https://forum.gsmhosting.com/vbb/f67...0018m-2987401/ i got this firmware from easy jtag folder but cannot update to emmc. but if i try to update firmware with ufi its updated but phone only detected as exynos eMMC CID : 150100303030303030562016061354D1 eMMC CSD : 902701320F5903FFF6DB7FE08A40403B eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2017 Rev.0x56 eMMC NAME: 000000 , S/N: 538314259 eMMC NAME (HEX): 303030303030 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB Counter failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 538314259_20211219_1048.extcsd Blocks Reading Error (0x0 , 1 , Reason: DATA RCV Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. fw update failed https://forum.gsmhosting.com/vbb/att...1&d=1639904160 and https://forum.gsmhosting.com/vbb/att...1&d=1639904160 and https://forum.gsmhosting.com/vbb/att...1&d=1639904259 Running:SAMSUNG: eMMC firmware update... Chip Init OK... Downloading FFU:C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KMDX60018M-B425_DX68MB.bin Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Checking firmware type... OK; Skip loading eMMC Addon Firmware Box S/N: 553E579F73FF53EF, ,FW Ver.: 02.53 CMD Pullup Level:2088 mV CMD Active Level:2272 mV Box IO Level:3000 mV CLK Rate:14000 kHz Using firmware file : C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KMDX60018M-B425_DX68MB.bin Update Firmware ID Hash: Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Can't send eMMC firmware, Reason: DATA RCV CRC Error Done. |
Dear team how can I fix this problem |
any update on this fix? |
this firmware again no solution easy jtag not fix this file KMDX60018M |
