10-08-2021, 12:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Kyocera KYT31 Au Qua Tab 01Pattern Remove Done Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/21MHz/8BIT EasyJtag Plus Box Found! Result: 0/OK EasyJtag Plus S/N: 3E409736B08DFD8F EasyJtag Plus Box FirmWare: 2.53 Box Bus Width = 8 BIT Box Hardware = EasyJtag 2nd Generation Search EMMC Chip... Testing Box Interface PIN CLK : 1467 mV -> Pin OK PIN CMD : 1673 mV -> Pin OK PIN DAT0: 1677 mV -> Pin OK PIN DAT1: 1672 mV -> Pin OK PIN DAT2: 1672 mV -> Pin OK PIN DAT3: 1677 mV -> Pin OK PIN DAT4: 1674 mV -> Pin OK PIN DAT5: 1671 mV -> Pin OK PIN DAT6: 1673 mV -> Pin OK PIN DAT7: 1673 mV -> Pin OK Test End EMMC Chip Found! 0/OK EMMC CID: 15010041474E443352026E6EBA2A52A3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC VENDOR: SAMSUNG EMMC NAME: AGND3R EMMC SERIAL: 6E6EBA2A EMMC REVISION: 02 EMMC ROM1 Size: 30777344 Block(s)/15028 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 8192 Block(s)/4096 KB EMMC RPMB Counter: 129 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.7 (for MMC v5.0, v5.01) EMMC VER: MMC 5.0 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x03 -> 20% - 30% Life Time Used EMMC SLC Life Time: 0x03 -> 20% - 30% Life Time Used EMMC Boot Config: 0x00/0x00/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 44 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: MODEM [000000100000 - 000004000000] Size: 64.00 MB GPT: SBL1 [000004100000 - 000000100000] Size: 1.00 MB GPT: SBL1BAK [000004200000 - 000000100000] Size: 1.00 MB GPT: TZ [000004300000 - 000000080000] Size: 512.00 KB GPT: TZBAK [000004380000 - 000000080000] Size: 512.00 KB GPT: RPM [000004400000 - 000000080000] Size: 512.00 KB GPT: RPMBAK [000004480000 - 000000080000] Size: 512.00 KB GPT: HYP [000004500000 - 000000080000] Size: 512.00 KB GPT: HYPBAK [000004580000 - 000000080000] Size: 512.00 KB GPT: ABOOT [000004600000 - 000000200000] Size: 2.00 MB GPT: ABOOTBAK [000004800000 - 000000200000] Size: 2.00 MB GPT: BOOT [000004A00000 - 000002000000] Size: 32.00 MB GPT: RECOVERY [000006A00000 - 000002000000] Size: 32.00 MB GPT: FOTA [000008A00000 - 000002000000] Size: 32.00 MB GPT: FOTABK [00000AA00000 - 000002000000] Size: 32.00 MB GPT: SPLASH [00000CA00000 - 000001000000] Size: 16.00 MB GPT: RESERVE1 [00000DA00000 - 000000100000] Size: 1.00 MB GPT: SYSTEM [00000DB00000 - 0000A6500000] Size: 2.60 GB GPT: DEVINFO [0000B4000000 - 000000800000] Size: 8.00 MB GPT: CACHE [0000B4800000 - 00003D180000] Size: 977.50 MB GPT: USERDATA [0000F1980000 - 0002B2D00000] Size: 10.79 GB GPT: RESERVE2 [0003A4680000 - 000000080000] Size: 512.00 KB GPT: DDR [0003A4700000 - 000000080000] Size: 512.00 KB GPT: MISC [0003A4780000 - 000000100000] Size: 1.00 MB GPT: FSG [0003A4880000 - 000000200000] Size: 2.00 MB GPT: FSC [0003A4A80000 - 000000080000] Size: 512.00 KB GPT: SSD [0003A4B00000 - 000000080000] Size: 512.00 KB GPT: KEYSTORE [0003A4B80000 - 000000080000] Size: 512.00 KB GPT: CONFIG [0003A4C00000 - 000000080000] Size: 512.00 KB GPT: OEM [0003A4C80000 - 000000080000] Size: 512.00 KB GPT: LOG [0003A4D00000 - 000001400000] Size: 20.00 MB GPT: LOGWORK [0003A6100000 - 000001400000] Size: 20.00 MB GPT: BOOTWORK [0003A7500000 - 000000400000] Size: 4.00 MB GPT: SEC [0003A7900000 - 000000080000] Size: 512.00 KB GPT: CHKCODE [0003A7980000 - 000000080000] Size: 512.00 KB GPT: FOTAMNG [0003A7A00000 - 000000100000] Size: 1.00 MB GPT: DNAND [0003A7B00000 - 000000800000] Size: 8.00 MB GPT: SYSPROP [0003A8300000 - 000000800000] Size: 8.00 MB GPT: PERSIST [0003A8B00000 - 000001000000] Size: 16.00 MB GPT: MODEMST1 [0003A9B00000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [0003A9D00000 - 000000200000] Size: 2.00 MB GPT: BFSS1 [0003A9F00000 - 000000400000] Size: 4.00 MB GPT: BFSS2 [0003AA300000 - 000000800000] Size: 8.00 MB GPT: RESERVE3 [0003AAB00000 - 000000800000] Size: 8.00 MB GPT Backup Header Not Found Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Partition #5 mount as [/MODEM] -> 64.00 MB Partition #22 mount as [/dev_22] -> 2.60 GB Partition #24 mount as [/cache] -> 977.50 MB Partition #25 mount as [/data] -> 10.79 GB Partition #42 mount as [/pstore] -> 8.00 MB Partition #43 mount as [/persist] -> 16.00 MB EmptyCheck: EMPTY -> #6 - [SBL1BAK] EMPTY -> #8 - [TZBAK] EMPTY -> #10 - [RPMBAK] EMPTY -> #12 - [HYPBAK] EMPTY -> #14 - [ABOOTBAK] EMPTY -> #18 - [FOTABK] EMPTY -> #20 - [RESERVE1] EMPTY -> #22 - [DEVINFO] EMPTY -> #25 - [RESERVE2] EMPTY -> #27 - [MISC] EMPTY -> #28 - [FSG] EMPTY -> #29 - [FSC] EMPTY -> #30 - [SSD] EMPTY -> #31 - [KEYSTORE] EMPTY -> #33 - [OEM] EMPTY -> #47 - [RESERVE3] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition #33 -> CONFIG ================================= Android Info: Brand = KDDI Vendor = KYOCERA Device = KYT31 Model = KYT31 Product = KYT31 Platform = msm8916 CPU ABI = arm64-v8a Android Version = 5.1 Firm Version = 101.0.2120 Inc. Version = 101.0.2120 Firm Date = Fri Jun 24 10:24:04 JST 2016 Security Patch = 2015-08-01 Scanner Thread Terminated Elapsed: 00:00:05:198 Found 48 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Bus Mode: 8BIT Operation Done: [Init Engine], Elapsed: 00:00:01:901 Wipe User Data v1.0 Wiping Misc Partition.. Partition #28 is '/misc'. Erasing.. Wipe Misc Partition Done.. Wiping Cache Partition.. Partition #24 is '/cache' Start Sector: 5914624, Size: 2001920/977.50 MB Start Formatting Cache Partition.. Please Wait.. Readed Data: 16.00 KB / Written Data: 16.69 MB Formatting Cache is Completed.. Wiping UserData Partition.. Partition #25 is '/UserData' Start Sector: 7916544, Size: 22636544/10.79 GB Start Formatting UserData Partition.. Please Wait.. Readed Data: 16.00 KB / Written Data: 68.34 MB Formatting UserData is Completed.. Done Wiping Data.. Elapsed Time: [00:00:24:455] Operation Done: [Wipe User Data], Elapsed: 00:00:24:480 Reset Google FRP v1.0 Search FRP Partition.. Partition #33 -> 'CONFIG' is FRP. Erasing Partition. Please Wait.. Erasing Done Backup Saved as: C:\Program Files\Z3X\EmmcManager\Backup\FRP_BACKUP_0x0003A4C0 0000_0x000000080000_20211008_161642.bin Reset FRP Done Elapsed Time: [00:00:23:744] Operation Done: [RESET FRP], Elapsed: 00:00:23:747 Dr.Ah$an. |
