Old 09-10-2017, 12:17   #1 (permalink)
aikonmani's Avatar
Member: 304090
Thanks Meter: 210
samsung j100h boot repair problem.....
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 412 mV
CMD Active Level: 2423 mV
EMMC Device Information :
EMMC CID: 65646F4D204D4F521281000002400152
EMMC CSD: D07FFF320F59007FF6DB80001E40001C
EMMC Manufacture Name:
EMMC Manufacture ID: 0x65 , OEM ID: 646F
EMMC Manufacture Date: 0/2014 , Rev: 81
EMMC NAME: M MOR , S/N: 00000240 , rev. 81
EMMC NAME (HEX): 4D204D4F5212
EMMC ROM 1 (Main User Data) Capacity: 128 MB (000008000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG]: 0x78 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x03
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: M MOR_00000240_20170910_164301.extcsd
EMMC Init completed.
Warning: Maybe your emmc damaged
Opening file: J13G.pit
Pit: J13G.pit
Entry count: 29
Error: eMMC has a small size
The size of the last section was not updated
any solution?
Old 09-10-2017, 19:49   #2 (permalink)
ahmed koukou's Avatar
Member: 1981679
Thanks Meter: 86
Emmc damaged Capacity: 128 KB
تم الإرسال من HUAWEI Y625-U32 باستخدام Tapatalk
Old 09-11-2017, 07:15   #3 (permalink)
aikonmani's Avatar
Member: 304090
Thanks Meter: 210
Old 09-11-2017, 19:10   #4 (permalink)
Member: 2438408
Thanks Meter: 380
Samsung j100h phone successfully dead boot repair done ✅ but phone same case successfully write pit and boot loader
The Following User Says Thank You to alexid For This Useful Post:
Old 09-12-2017, 06:04   #5 (permalink)
Member: 2459405
Thanks Meter: 17
Bad emmc replace new one
Old 09-13-2017, 05:21   #6 (permalink)
Member: 2438408
Thanks Meter: 380
Dead after flash first samsung logo problem
Page generated in 0.14946 seconds with 8 queries
