12-08-2019, 13:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Online Thanks Meter: 1,790 | cph1853 password reset done Code: Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.63 CMD Pullup Level:2010 mV CMD Active Level:2361 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206D97BD36BB558 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 3648770923 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 28462 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_3648770923_20191208_0841.extcsd ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x02] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xc7810000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x03] i.e. 20% - 30% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x03] i.e. 20% - 30% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x08] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x06 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x01d1f000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x14 Enable background operations handshake [BKOPS_EN]: 0x02 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0003a3 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190920.101036 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Done. Code: Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0500D01E3BC5A469, ,FW Ver.: 01.63 CMD Pullup Level:2010 mV CMD Active Level:2351 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206D97BD36BB558 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 3648770923 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 28462 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) , formatting... Done. Done. Done. |
