05-05-2018, 12:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306659 Status: Offline Sonork: 100.1608493 Thanks Meter: 32 | LG D290N emmc repair done with easy jtag Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 01FFD004D9F5A02E, ,FW Ver.: 01.62 CMD Pullup Level:1815 mV CMD Active Level:2578 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040501A1B0279144 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 09/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27373607 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 27373607_20180505_1610.extcsd Found Data areas (firmware parts) count is: 35 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x400000 0x4000000] Size: 64.0MB P1 (SBL1) [0x4400000 0x100000] Size: 1.0MB P2 (RPM) [0x4500000 0x80000] Size: 512.0KB P3 (TZ) [0x4580000 0x80000] Size: 512.0KB P4 (SDI) [0x4600000 0x80000] Size: 512.0KB P5 (ABOOT) [0x4680000 0x200000] Size: 2.0MB P6 (RPMB) [0x4880000 0x80000] Size: 512.0KB P7 (TZB) [0x4900000 0x80000] Size: 512.0KB P8 (ABOOTB) [0x4980000 0x200000] Size: 2.0MB P9 (PAD) [0x4b80000 0x200000] Size: 2.0MB P10 (MODEMST1) [0x4d80000 0x300000] Size: 3.0MB P11 (MODEMST2) [0x5080000 0x300000] Size: 3.0MB P12 (MISC) [0x5380000 0x1000000] Size: 16.0MB P13 (PERSIST) [0x6400000 0x2000000] Size: 32.0MB P14 (LAF) [0x8400000 0x1600000] Size: 22.0MB P15 (BOOT) [0x9c00000 0x1600000] Size: 22.0MB P16 (RECOVERY) [0xb200000 0x1600000] Size: 22.0MB P17 (FSG) [0xc800000 0x300000] Size: 3.0MB P18 (FSC) [0xcc00000 0x80000] Size: 512.0KB P19 (SSD) [0xcc80000 0x80000] Size: 512.0KB P20 (DDR) [0xd000000 0x80000] Size: 512.0KB P21 (ENCRYPT) [0xd400000 0x80000] Size: 512.0KB P22 (RCT) [0xd480000 0x80000] Size: 512.0KB P23 (DRM) [0xd800000 0x800000] Size: 8.0MB P24 (SNS) [0xe000000 0x800000] Size: 8.0MB P25 (FACTORY) [0xe800000 0x1400000] Size: 20.0MB P26 (FOTA) [0xfc00000 0x2000000] Size: 32.0MB P27 (SBL1B) [0x11c00000 0x100000] Size: 1.0MB P28 (MPT) [0x11d00000 0x2000000] Size: 32.0MB P29 (CUST) [0x14000000 0x3200000] Size: 50.0MB P30 (EKSST) [0x17400000 0x80000] Size: 512.0KB P31 (SYSTEM) [0x17800000 0x5db80000] Size: 1.463GB P32 (CACHE) [0x75380000 0xfa00000] Size: 250.0MB P33 (USERDATA) [0x84d80000 0x62000000] Size: 1.531GB P34 (GROW) [0xe7000000 0x1ffbe00] Size: 31.983MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0017800000 (1.463GB) Build ID: KOT49I.A1452595206 Display Build ID: KOT49I.A1452595206 Release ID: 4.4.2 Device Model: LG-D290 Device Name: l70pn_global_com Architecture ABI: armeabi-v7a Device manufacturer: LGE Device Platform: msm8610 Product ID: l70pn Build Description: l70pn_global_com-user 4.4.2 KOT49I.A1452595206 1452595206 release-keys --------------------------------------------- Done. Running:SAMSUNG: MoviNAND Firmware extraction... Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:2578 mV Box IO Level:3300 mV CLK Rate:21000 kHz This eMMC is not Samsung! Hold Shift during operation to skip this check Done. Running:SAMSUNG: MoviNAND Firmware extraction... Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:2578 mV Box IO Level:3300 mV CLK Rate:21000 kHz --- EasyJTAG Samsung eMMC Backup Tool --- EMMC CID : 90014A4834473164040501A1B0279144 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 09/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27373607 EMMC Part Number: Unknown EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1/2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Reading eMMC Boot Identification Data... BootLoader ID Hash:BB7DF04E1B0A2570657527A7E108AE23 Reading eMMC Firmware Identification Data... Firmware ID is wrong , changing mode... Reading eMMC Firmware Identification Data... Firmware alternate ID is wrong , contact support Reading eMMC Firmware Data... Processing firmware data... Firmware processing done... Done. Running:eMMC: Factory Format... Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:2578 mV Box IO Level:3300 mV CLK Rate:21000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. Z3X EasyJtag Software ver. 2.9.0.3 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:2578 mV Input file : C:\Users\MUHAMMAD\Downloads\LG_D290N_dump_rom1.bin Writing 0014880000 bytes to 0000000000... ROM1 (USER ROM) Done, time taken: 916 sec. Average Write Speed: 375 kB/s Z3X EasyJtag Software ver. 2.9.0.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 01FFD004D9F5A02E, ,FW Ver.: 01.62 CMD Pullup Level:1815 mV CMD Active Level:2578 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040501A1B0279144 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 09/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 27373607 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 27373607_20180505_1636.extcsd Found Data areas (firmware parts) count is: 35 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x400000 0x4000000] Size: 64.0MB P1 (SBL1) [0x4400000 0x100000] Size: 1.0MB P2 (RPM) [0x4500000 0x80000] Size: 512.0KB P3 (TZ) [0x4580000 0x80000] Size: 512.0KB P4 (SDI) [0x4600000 0x80000] Size: 512.0KB P5 (ABOOT) [0x4680000 0x200000] Size: 2.0MB P6 (RPMB) [0x4880000 0x80000] Size: 512.0KB P7 (TZB) [0x4900000 0x80000] Size: 512.0KB P8 (ABOOTB) [0x4980000 0x200000] Size: 2.0MB P9 (PAD) [0x4b80000 0x200000] Size: 2.0MB P10 (MODEMST1) [0x4d80000 0x300000] Size: 3.0MB P11 (MODEMST2) [0x5080000 0x300000] Size: 3.0MB P12 (MISC) [0x5380000 0x1000000] Size: 16.0MB P13 (PERSIST) [0x6400000 0x2000000] Size: 32.0MB P14 (LAF) [0x8400000 0x1600000] Size: 22.0MB P15 (BOOT) [0x9c00000 0x1600000] Size: 22.0MB P16 (RECOVERY) [0xb200000 0x1600000] Size: 22.0MB P17 (FSG) [0xc800000 0x300000] Size: 3.0MB P18 (FSC) [0xcc00000 0x80000] Size: 512.0KB P19 (SSD) [0xcc80000 0x80000] Size: 512.0KB P20 (DDR) [0xd000000 0x80000] Size: 512.0KB P21 (ENCRYPT) [0xd400000 0x80000] Size: 512.0KB P22 (RCT) [0xd480000 0x80000] Size: 512.0KB P23 (DRM) [0xd800000 0x800000] Size: 8.0MB P24 (SNS) [0xe000000 0x800000] Size: 8.0MB P25 (FACTORY) [0xe800000 0x1400000] Size: 20.0MB P26 (FOTA) [0xfc00000 0x2000000] Size: 32.0MB P27 (SBL1B) [0x11c00000 0x100000] Size: 1.0MB P28 (MPT) [0x11d00000 0x2000000] Size: 32.0MB P29 (CUST) [0x14000000 0x3200000] Size: 50.0MB P30 (EKSST) [0x17400000 0x80000] Size: 512.0KB P31 (SYSTEM) [0x17800000 0x5db80000] Size: 1.463GB P32 (CACHE) [0x75380000 0xfa00000] Size: 250.0MB P33 (USERDATA) [0x84d80000 0x62000000] Size: 1.531GB P34 (GROW) [0xe7000000 0x1ffbe00] Size: 31.983MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0017800000 (1.463GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Done. |
