05-11-2019, 02:13 | #1 (permalink) |
No Life Poster Join Date: May 2017 Location: Tajikistan Age: 30
Member: 2715751 Status: Offline Thanks Meter: 242 | LG H811 BOOT REPAIR Error Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0E008019CA179EA0, ,FW Ver.: 01.63 CMD Pullup Level:1949 mV CMD Active Level:3248 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 110100303332473734001077B7992304 eMMC CSD : D02700320F5903FFFFFFFFE78640009A eMMC Manufacturer ID: 0011 , OEM ID: 0100 eMMC Date: 02/2016 Rev.0x0 eMMC NAME: 032G74 , S/N: 276281241 eMMC NAME (HEX): 303332473734 IC Name: TOSHIBA , eSD_THGBMFG8C4LBAIR/32GB @FBGA153 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or NO Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 032G74_ 276281241_20190511_0405.extcsd Done. Processing file...C:\Users\admin\Desktop\InfinityBox\LG_H811_ dump_rom1.bin Writing as RAW data Z3X EasyJtag Software ver. 3.5.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1949 mV CMD Active Level:3248 mV Input file : C:\Users\admin\Desktop\InfinityBox\LG_H811_dump_ro m1.bin Writing 0011800000 bytes to 0000000000... ROM1 (USER ROM) Error writing address 0x00000000 Error Code:-15 Reason :CMD Ready Timeout Error [Box Internal Failure] Retry writing address 0x0000000000 (Attempt #1)... Retry Success! Verify failed at address 0x00000000 Error Code:512 Reason :Unknown error (512) Verify Block Failed , address: 0x0000000000 |
05-12-2019, 08:20 | #3 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Pune (Daund) Maharashtra Age: 34
Member: 787710 Status: Offline Sonork: not using Thanks Meter: 771 | Quote:
