LS777ZVG died phone after write carrier and modem died ual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA63-6424 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM32 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM32) COM4 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM4) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 10FFE00C1DB260E5, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:3073 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420311C7964C55F8 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 298292812 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 396 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_ 298292812_20200114_0904.extcsd Caution: invalid main GPT header, but valid a backup header! Warning: Invalid CRC on main header data; loaded backup partition table. EFI Table CRC Check FAIL. Warning! Main partition table CRC mismatch! Loaded backup Warning! One or more CRCs don't match. You should repair the disk! Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFDE sectors 14.6 GiB Disk identifier (GUID): 001E001D-001F-0020-2100-220023002400 Logical sector size: 0x200 bytes ,First/Last usable sector: 17,30535663 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x001F800000 (3.625GB) Short EXT fs info: Size: 3.568GB Block size: 4.0KB Inode size: 256 Inodes: 234320 Short Android info: Build ID: NRD90U Display Build ID: NRD90U Release Incremental ID: 1830510094c4a Release Base ID: 7.0 Security Path: 2018-11-01 Device Model: LG-LS777 Device Manufacturer: lge Device Name A: sf340_spr_us Device Name B: sf340 Device Board Name: msm8937_32 Architecture ABI: armeabi-v7a Device manufacturer: LGE Device Platform: msm8937 Product ID: sf340 Build Description: sf340_spr_us-user 7.0 NRD90U 1830510094c4a release-keys Target Carrier: SPR Target Country: US FRP Partition Path: /dev/block/bootdevice/by-name/persistent LGE SW Version: LS777ZVG LGE SW Version Short: ZVG LGE SW Revision: 00 LGE SW Version: LGLS777AT-00-ZVG-SPR-US-NOV-01-2018-ARB02+00 Backup saved: BuildProp_20200114_0904.txt |
If you only write modem and carrier partitions for unlock no posiblities of brick. You must check the components where you soldered, check clk resistor (must be shorted) and cmd resistor (10kohms) |
i write write modem and carrier in userdata imag now only qualcomm |
