Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: africa Age: 52
Member: 22284 Status: Offline Thanks Meter: 79 | May someone explain if i can revive this a530f 2018 Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 463 mV CMD Active Level: 1375 mV EMMC Device Information : EMMC CID: 150100424A54443452000684ECE174F9 EMMC CSD: 902701320F5903FFF6DB7FE08A40403B EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 0684Exxx , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_0684ECE1_20210531_003055.extcsd EMMC Init completed. Scanning soft partitions Partition table not found PROBLEM IS :PARTITION TABLE NOT FOUND |
![]() | #2 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Abedi-GSM Age: 35
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 146 | Quote:
![]() | #3 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 79 | I try to write the emmc firmware and all went in fine but still same error partion not found,then i tried with eMMC tool version 2.0.10 (release date:05.05.2021) below is the log with Rom 2 error. Where can i get ROM2, ROM 3 and ROM 1 for this particular A8 2018 A530F DS Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting IO Levels to 3.3V Setting Frequence to 36 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 462 mV CMD Active Level: 1374 mV Setting HS Timing to Enabled EMMC Device Information : EMMC CID: 150100424A54443452000684ECE174F9 EMMC CSD: 902701320F5903FFF6DB7FE08A40403B Manufacturer: SAMSUNG , NAME: BJTD4R , HEX: 424A54443452 , S/N: 0684ECxx , Rev: 00 Manufacturer ID: 15 , OEM ID: 00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (0x000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (0x000000000000) EMMC RPMB Capacity: 0 KB (0x000000000000) , Counter: 0 , Response: Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot partition 1 enabled for boot , Boot ACK Boot Bus Config: 0x01 , x4 (sdr/ddr) bus width in boot operation mode H/W Reset Function [RST_N_FUNCTION]: 0x00 , RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition settings [PARTITION_SETTING_COMPLETED]: 0x00 EMMC Init completed Extcsd backup saved: BJTD4R_0684ECE1_20210529_213519.extcsd (old backup) Connected successfully Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write) Scanning soft partitions from ROM2 Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #1 Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #2 Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #3 Canceled |
