Old 04-23-2021, 10:14   #1 (permalink)
newfoundghori's Avatar
Member: 575597
Sonork: 100.1590575
Thanks Meter: 535
Mi 9T pro ufs 2.1 824a
hi team,
i try to chip off ufs 824a and put in adapter cant detect. this adapter work for ufs 2.1 chip or not..thanks.
i plan to erase persist file and bypass via vpn..
but it cant connect to adapter.
Old 04-23-2021, 10:27   #2 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 535
this pinout work if i manually soldered the chip..???
Old 04-26-2021, 10:58   #3 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 535
hi sir layder,,
i found pinout of the chip but cannot connect,,.
File Type: jpg 177663058_885358638709706_8316816863940760536_n.jpg (107.2 KB, 28 views)
Old 04-27-2021, 17:41   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,521
Originally Posted by newfoundghori View Post
hi sir layder,,
Attachment 380630
read this, please
https://forum.gsmhosting.com/vbb/f67.../#post14270531
Old 04-28-2021, 04:43   #5 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 535
Originally Posted by layder View Post
Solder all GND, all VCC, all VCCQ, all VCCQ2 pins if ufs not connect, and 3 Vddi capacitor from datashet of this chip
what you mean all sir...ex: in socket 1 ground and in chip solder all ground
Old 04-28-2021, 04:46   #6 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 535
i see this video that he solder only 8 connection in socket that connect to chip.
https://www.youtube.com/watch?v=Rfob_fWH-hw&fs=1" width="644" height="390">https://www.youtube.com/watch?v=Rfob_fWH-hw&fs=1" />https://www.youtube.com/watch?v=Rfob_fWH-hw">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=Rfob_fWH-hw
Old 04-29-2021, 12:38   #7 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,521
at what socket 1 ground? at moorc? - it's a moorc problem
UFS chips need use many GND/VCC/VCCQ pins
Old 04-29-2021, 12:41   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,521
you can ask video author for solve you problem
z3x team is reccomended use only our adapters for correct work with UFS chips
Old 04-30-2021, 04:08   #9 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 535
i use easy jtag 254 socket.
Old 05-01-2021, 09:35   #10 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,521
ISP pins at socket is make to connect chips on PCB!!!!!!!!!!!
Old 05-01-2021, 10:07   #11 (permalink)
Member: 575597
Sonork: 100.1590575
Thanks Meter: 535
theres no isp ufs pinout for mi 9t pro..only chip pinout.
Old 05-02-2021, 16:57   #12 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,521
You can solder to the UFS chip however you want.
I explained above that only some of the chips will work with one pin of the ground or power of the chip.
Our team is trying to convey this to the users of the form, because they will repeat and approve after you, as you are doing now, that it should work.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.29807 seconds with 8 queries
