Old 03-24-2021, 13:14   #1 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 1,005
Arrow Vivo Y55L Hang on Logo Warning: Health report is very BAD
Vivo Y55L Hang on Logo Helf .....
Log Here
EasyJtag Suite Classic ver.: 3.7.0.20 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 8.1 (build 9600). Admin rights FAIL
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
EasyJTAG SPI Plugin ver:1.1.1.13
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AA1F-5E4A , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
For more information press F1 to open local help or visit our wiki
Found 2 serial devices
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
COM6 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM6)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.7.0.20
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0800201B5CDFEBC5, ,FW Ver.: 01.63
CMD Pullup Level:2041 mV
CMD Active Level:2990 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
Loading eMMC GEN1 Firmware... IO: 2800 mV
CMD Pullup Level:2031 mV
CMD Active Level:2557 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:2000 mV
CMD Active Level:1763 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:660 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Active Level:3011 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CMD Pullup Level:1835 mV
CMD Active Level:3000 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514531334D420DC7C7DA2EA3FA
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 10/2016 Rev.0xD
eMMC NAME: QE13MB , S/N: 3351763502
eMMC NAME (HEX): 514531334D42
EMMC ROM1 (Main User Data) Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is not yet programmed (clear) or RPMB General failure
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE13MB_3351763502_20210324_1729.extcsd
The protective MBR's 0xEE partition is oversized! Auto-repairing.
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0016000000 (3.0GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 195072
Short Android info:
Build ID: MMB29M
Display Build ID: MMB29M release-keys
Release Incremental ID: eng.compiler.20190306.175921
Release Base ID: 6.0.1
Security Path: 2018-08-01
Device Model: vivo 1603
Device Manufacturer: vivo
Device Name A: PD1613F_EX
Device Name B: PD1613F_EX
Device Board Name: QC_Reference_Phone
Architecture ABI: armeabi-v7a
Device manufacturer: vivo
Device Platform: msm8937
Product ID: msm8937_32
Build Description: msm8937_32-user 6.0.1 MMB29M eng.compiler.20190306.175921 release-keys
FRP Partition Path: /dev/block/bootdevice/by-name/config
Backup saved: BuildProp_20210324_1729.txt
Detected USERDATA USERDATA : 0x010AA82000 (10.393GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
0ABE799B 841B8F7F 13C5142B 0DD07C7D 7331C971 BFB62B40 BCB6BFBD 06E8AD86 .¾y›„....Å.+.Ð|}s1Éq¿¶+@¼¶¿½.è*†;
0EC511D9 02C4D4C6 C9FD11CB F87DEA25 C332A80A 43FE6A35 7EE96718 BA5151B8 .Å.Ù.ÄÔÆÉý.Ëø}ê%Ã2¨.Cþj5~ég.ºQQ¸;
A8931B58 83235F4B D1BC578D F756F902 9ADB7C6C 1DE7104F D5610F74 26D2FCA8 ¨“.Xƒ#_KѼW.÷Vù.šÛ|l.ç.OÕa.t&Òü¨;
BEBF4EA8 8FCDCCB4 3B49525D 4C8E2E76 946FE859 E17685C1 87CFBAA2 48E6C52E ¾¿N¨.ÍÌ´;IR]LŽ.v”oèYáv…Á‡Ïº¢HæÅ.;
A0618B01 9E9577A4 4EABF6BB 6540D9D5 3FB90DD9 58BB74DA 27BC1BE9 F468A265 a‹.ž•w¤N«ö»e@ÙÕ?¹.ÙX»tÚ'¼.éôh¢e;
EB8B50DE 71A2C5F8 A89A3A91 40A25CDB 06546B61 B420FDC5 D8202919 360F8E69 ë‹PÞq¢Åø¨š:‘@¢\Û****a´ ýÅØ ).6.Ži;
7E550658 2CE97833 ACB573B6 A895937D 88999F4F 9152772B 87D80110 9772B2D5 ~U.X,éx3¬µs¶¨•“}..ŸO‘Rw+‡Ø..—r²Õ;
6E1797CE 5566F906 413C3D8C D02EDE61 67BB07B0 ADB07776 74EE19E5 74F48F78 n.—ÎUfù.A<=ŒÐ.Þag».°*°wvtî.åtô.x;
Done.
eMMC_tool Suite ver. 1.6.4.0 (release date: 30.12.2020)
Microsoft Windows 8.1 (32 bit) build 9600 (6.3.9600.18217)
Looking for EasyJTAG box...
EasyJTAG API ver. 3403
EasyJTAG Box Serial = 0800201B5CDFEBC5
Card Serial = AA1F5E4A
EasyJTAG Box Firmware = 1.6300
Changelog:
30.12.2020 (ver 1.6.4.0)
Add: New keys for Oppo unpack
Fix: Fix LG Parser
Fix: Bugs that have been found through your crash report
Add: new version 2.0.0.0 (qualcomm, samsung)
HiPower mode is ON
Setting frequence to 21 MHz
CMD Pullup Level: 2052 mV
CMD Active Level: 3052 mV
EMMC Device Information :
EMMC CID: 150100514531334D420DC7C7DA2EA3FA
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: QE13MB , HEX: 514531334D42 , S/N: C7C7DA2E , rev. 0x0D
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2016
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE13MB_C7C7DA2E_20210324_173338.extcsd
EMMC Init completed.
Device Life Time Estimation (MLC) [269]: 0x08 70% - 80% device life time used
Device Life Time Estimation (SLC) [268]: 0x08 70% - 80% device life time used
Pre EOL information [267]: 0x01 Normal
The Following User Says Thank You to reset12345 For This Useful Post:
Old 03-25-2021, 08:15   #2 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
if you want repair then can repartition but set become faulty after some days .
now you need to change emmc for stable repair
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post:
Old 03-25-2021, 08:34   #3 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 1,005
Arrow
[B]Thanks Bro........................../B]
Page generated in 0.21757 seconds with 8 queries
