08-06-2016, 10:10 | #1 (permalink) |
Freak Poster Join Date: Dec 2010 Location: India
Member: 1471997 Status: Offline Thanks Meter: 22 | Motorola Xt1022 Dead Repair But Not Success Check Please Team Connected With Emmc Point Then Write File Available On Support But Same Condition... Here Is Log.. Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: , ,FW Ver.: 01.55 CMD Pullup Level:2010 mV CMD Active Level:2444 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040503A1CC07519C EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 05/2014 Rev.0x5 EMMC NAME: <b>H4G1d </b> , S/N: 60935175 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 60935175_20160806_1303.extcsd Done. Running:Repair extCSD... Z3X EasyJtag Software ver. 2.3.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2010 mV CMD Active Level:2444 mV Box IO Level:2800 mV CLK Rate:14000 khz Writing... Done. Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 953 kB/s Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1386 kB/s Writing 0000200000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 1399 kB/s |
08-17-2016, 13:51 | #3 (permalink) |
Member: 1471997 Status: Offline Thanks Meter: 22 | How To Read Boot Partition One(Rom 2) And Two (Rom 3) Success To Read Rom1 JTAG Connection is not supported for this device Z3X EasyJtag Software ver. 2.3.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 16161317F77A2E59, ,FW Ver.: 01.55CMD Pullup Level:2010 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : FE014E50314A39344C12691FA16E71D6 EMMC CSD : D06E01320F5913FFFFFFFFE792400040 EMMC Manufacturer ID: 00FE , OEM ID: 014E EMMC Date: 07/2014 Rev.0x12 EMMC NAME: P1J94L , S/N: 1763680622 EMMC NAME (HEX): 50314A39344C00 EMMC ROM1 (Main User Data) Capacity: 3736 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 1024 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: P1J94L_1763680622_20160817_1631.extcsd Done. Z3X EasyJtag Software ver. 2.3.0.0Skip loading eMMC Addon Firmware CMD Pullup Level:2010 mVCMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:14000 khz Reading 0x000100000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Read Length has been corrected to 0x0000E9800000 bytes... Output file :C:\Users\CRM\Desktop\EMMC_ROM1_P1J94L_1763680622_ 00000000_E9800000.bin Done. Read Speed: 1238 kB/s Data partitions (firmware parts) count is 36 (dec) mmc_read_blocks(E97FFE00 > E9800000 ), Read address is invalid mmc_read_blocks(E97FBE00 > E9800000 ), Read address is invalid Meta partitions (partitions storing partition table) count is 1 (dec) Partitions are not found! Z3X EasyJtag Software ver. 2.3.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 16161317F77A2E59, ,FW Ver.: 01.55CMD Pullup Level:2010 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : FE014E50314A39344C12691FA16E71D6 EMMC CSD : D06E01320F5913FFFFFFFFE792400040 EMMC Manufacturer ID: 00FE , OEM ID: 014E EMMC Date: 07/2014 Rev.0x12 EMMC NAME: P1J94L , S/N: 1763680622 EMMC NAME (HEX): 50314A39344C00 EMMC ROM1 (Main User Data) Capacity: 3736 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 1024 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: P1J94L_1763680622_20160817_1727.extcsd Done. |
02-28-2017, 10:25 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I see your cpu is qualcomm so you don't need rom2/3 Also i have no idea about dump from shell.maybe it's old maybe it's new bootloader So best way is finding alive phone with latest fw then try root phone and take dump by adb tool and write to your phone |
