motorola xt1022 qualco drivers only detected is it possible to repaire? if yes need procedure |
[CENTER] World's 1st MOTO E XT1022 eMMC Repair with Guide for all GsmHosting[IMG] [/COLOR][/B][/B][/SIZE] [U]So many Peoples waiting this solution. I give Surprise to our Family[IMG] Follow Step by Step: 1.Download Rom files (Extract to in your PC)and Pinout image, 2.Solder Pinout carefully on board and eMMC adopter and insert adopter in easy jtag box, 3.Open Easy jtag tool goto eMMC Tool section, 4.Press Detect eMMC Card after detect eMMC Tick all eMMC Regions at once, 5.Select Rom1 where are Extract Rom files, 6.When select Rom1 easy jtag was auto select all roms, 7.After select roms Press Write all ROMs, 8.After write roms disconnect board from adopter and normally flash your mobile with tool or cmd process.[IMG Rom Files Download Here: MOTO XT1022 ROMS |
2 Attachment(s) here is pin out all pinout try this................. |
can you share with me dump file |
Moto-E System Dump Here CLICK ME |
This Solution Not Working... |
Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: , ,FW Ver.: 01.55 CMD Pullup Level:2010 mV CMD Active Level:2444 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040503A1CC07519C EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 05/2014 Rev.0x5 EMMC NAME: <b>H4G1d </b> , S/N: 60935175 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 60935175_20160806_1303.extcsd Done. Running:Repair extCSD... Z3X EasyJtag Software ver. 2.3.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2010 mV CMD Active Level:2444 mV Box IO Level:2800 mV CLK Rate:14000 khz Writing... Done. Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 953 kB/s Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1386 kB/s Writing 0000200000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 1399 kB/s |
yes not working .phone stiil dead boot |
Pls give me solution of moto xt1022 |
sucess full repair Boot write ! BUT still DEAD ! Plz help z3x team this solution not working properly !!!! |
u can write stock firmware via easy jtag Direct eMMC Qualcomm Flasher |
try use Direct eMMC Qualcomm Flasher |
plz tell me steps. how to do this XT1022_Retail_DualSim_51_Stock_Untouched.zip in software it asks XML file |
