09-29-2022, 11:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | A305f dead after flash please help OS ver.: Windows 10 (build 19043), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.19041.1202 Z3X Card Serial : AAA1-489F , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 1 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BD30371148A42D21, ,FW Ver.: 02.53 CMD Pullup Level:2180 mV CMD Active Level:2325 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BD30371148A42D21, ,FW Ver.: 02.53 CMD Pullup Level:2178 mV CMD Active Level:2325 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BD30371148A42D21, ,FW Ver.: 02.53 CMD Pullup Level:2266 mV CMD Active Level:2407 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100445836384D4200B845909A2963 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2006 Rev.0x0 eMMC NAME: DX68MB , S/N: 3091566746 eMMC NAME (HEX): 445836384D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 65315 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DX68MB_3091566746_20220929_1253.extcsd Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) system : 0x001F100000 (3.307GB) Short EXT fs info: Size: 3.254GB Block size: 4.0KB Inode size: 256 Inodes: 4752 Short Android info: Backup saved: BuildProp_20220929_1253.txt --------------------------------------------- ------ Android information ------ Detected LINUX(Android) system_ext : 0x00F2D00000 (120.437MB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Detected USERDATA USERDATA : 0x01D4E00000 (21.793GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Running:SAMSUNG: eMMC firmware update... Chip Init OK... Operation cancelled by user! Operation canceled by user! Running:SAMSUNG: eMMC firmware dump... Init OK... Firmware file...C:\Users\abu imran\Music\eMMC_Firmware_Unknown.bin Checking security ... Running:SAMSUNG: MoviNAND Firmware extraction... Z3X EasyJtag Software ver. 3.7.0.24 Skip loading eMMC Addon Firmware CMD Pullup Level:2275 mV CMD Active Level:2410 mV Box IO Level:2800 mV CLK Rate:14000 kHz Checking eMMC BootROM mode Skip loading eMMC Addon Firmware CMD Pullup Level:2272 mV CMD Active Level:2410 mV Box IO Level:2800 mV CLK Rate:14000 kHz --- EasyJTAG Samsung eMMC Backup Tool --- EMMC CID : 150100445836384D4200B845909A2963 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 02/2006 Rev.0x0 EMMC NAME: DX68MB , S/N: 3091566746 EMMC Part Number: Unknown EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1/2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB Reading eMMC Boot Identification Data... EMMC FW Read Failed, Reason: CMD Timeout Error Done. Done with error(s) Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: BD30371148A42D21, ,FW Ver.: 02.53 CMD Pullup Level:2235 mV CMD Active Level:2376 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100445836384D4200B845909A2963 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2006 Rev.0x0 eMMC NAME: DX68MB , S/N: 3091566746 eMMC NAME (HEX): 445836384D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 65315 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DX68MB_3091566746_20220929_1256.extcsd Caution: invalid main GPT header, but valid a backup header! Caution! After loading partitions, the CRC doesn't check out! Warning: Invalid CRC on main header data; loaded backup partition table. EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Warning! One or more CRCs don't match. You should repair the disk! Invalid partition data! Partition info not found Done. eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) Microsoft Windows 10 (64 bit) build 19043 (10.0.19041.1741) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = BD30371148A42D21 Card Serial = AAA1489F EasyJTAG Box Firmware = 2.5302 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1849 mV CMD Active Level: 1856 mV EMMC Device Information : EMMC CID: 150100445836384D4200B845909A2963 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: DX68MB , HEX: 445836384D42 , S/N: B845909A , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2022 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 65315 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DX68MB_B845909A_20220929_125929.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version |
