n9005 reactivation lock via direct isp Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 01FF701775F468A7, ,FW Ver.: 01.58 CMD Pullup Level:2041 mV CMD Active Level:2382 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004D424734474300F9EEB4839000 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x0 EMMC NAME: MBG4GC , S/N: 4193170563 EMMC NAME (HEX): 4D424734474300 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 GPT Entries Count = 128 Searching for FRP Data... FRP/Persistent Data is not found! Searching for KillSwitch Specific FRP Data... LG Custom Data is not found! Done. Z3X EasyJtag Software ver. 2.5.0.8 Any solution.. |
Hi to all.. If i flash it with the z3x plus will it remove the reactivation lock ? Regards |
Hi You can remove by Z3x SamPro |
I could not found in the samsung_pro under the n9005 selection.. Can you explain me little more. Its samsung account.. not google account.. phone was rest/wipe. Regards |
Any one any idea ? br |
Hi, Solved.. delete /system/priv-app/samsungservice apk ... and done. :) Regards.. |
Via easy jtag box!? yes |
I think easy jtag has no option to delete any apk from eMMc partitions. |
