10-14-2020, 14:34 | #1 (permalink) |
Junior Member Join Date: Aug 2018 Location: india
Member: 2860728 Status: Offline Thanks Meter: 9 | Help Jio F120B Repartitioned and programmed still shows Qualcomm port no power on Jio f120b after flash set goes to dead condition. doing emmc repartition and flashing using easy jtag every thing ok but mobile not power on. it shows Qualcomm port only. please help. Code: ---------- eMMC Device Information ---------- eMMC CID : 90014A483447326111025988DAE194CB eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 09/2017 Rev.0x2 eMMC NAME: H4G2a , S/N: 1502141153 eMMC NAME (HEX): 483447326120 EMMC ROM1 (Main User Data) Capacity: 3728 MB , 0x748000 pages , 0xE9000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written -329872481 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: H4G2a_1502141153_20201014_1858.extcsd ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x64] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x64] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x10] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00748000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x03] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00 Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 748000 sectors 3.6 GiB Soft (Partitioned) Disk/Image size: 747FBC sectors 3.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,7634910 Partition info successfully found ------ Detected 30 partitions ------ P0 (MODEM) [0x4000000 0x4000000] Size: 64.0MB P1 (SBL1) [0x8000000 0x80000] Size: 512.0KB P2 (SBL1BAK) [0x8080000 0x80000] Size: 512.0KB P3 (ABOOT) [0x8100000 0x100000] Size: 1.0MB P4 (ABOOTBAK) [0x8200000 0x100000] Size: 1.0MB P5 (RPM) [0x8300000 0x80000] Size: 512.0KB P6 (RPMBAK) [0x8380000 0x80000] Size: 512.0KB P7 (TZ) [0x8400000 0xc0000] Size: 768.0KB P8 (TZBAK) [0x84c0000 0xc0000] Size: 768.0KB P9 (PAD) [0x8580000 0x100000] Size: 1.0MB P10 (MODEMST1) [0x8680000 0x180000] Size: 1.500MB P11 (MODEMST2) [0x8800000 0x180000] Size: 1.500MB P12 (MISC) [0x8980000 0x100000] Size: 1.0MB P13 (FSC) [0x8a80000 0x400] Size: 1.0KB P14 (SSD) [0x8a80400 0x2000] Size: 8.0KB P15 (SPLASH) [0x8a82400 0xa00000] Size: 10.0MB P16 (DDR) [0xc000000 0x8000] Size: 32.0KB P17 (FSG) [0xc008000 0x180000] Size: 1.500MB P18 (SEC) [0xc188000 0x4000] Size: 16.0KB P19 (BOOT) [0xc18c000 0x2000000] Size: 32.0MB P20 (SYSTEM) [0xe18c000 0x32000000] Size: 800.0MB P21 (PERSIST) [0x4018c000 0x2000000] Size: 32.0MB P22 (USBMSC) [0x44000000 0x3e800000] Size: 1000.0MB P23 (CACHE) [0x84000000 0x10000000] Size: 256.0MB P24 (RECOVERY) [0x94000000 0x2000000] Size: 32.0MB P25 (DEVINFO) [0x96000000 0x100000] Size: 1.0MB P26 (KEYSTORE) [0x98000000 0x80000] Size: 512.0KB P27 (OEM) [0x98080000 0x4000000] Size: 64.0MB P28 (CONFIG) [0x9c080000 0x80000] Size: 512.0KB P29 (USERDATA) [0x9c100000 0x4cefbe00] Size: 1.201GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000E18C000 (800.0MB) Short EXT fs info: Size: 793.664MB Block size: 4.0KB Inode size: 256 Inodes: 50848 Short Android info: Build ID: MMB29M Display Build ID: LYF-F120B-001-02-16-080419 Release Incremental ID: LYF-F120B-001-02-16-080419 Release Base ID: 6.0.1 Security Path: xxxx-xx-xx Device Model: F120B Device Manufacturer: LYF Device Name A: F120B Device Name B: msm8909_512 Device Board Name: msm8909 Architecture ABI: armeabi-v7a Device manufacturer: Jio Device Platform: msm8909 Product ID: msm8909_512 Build Description: msm8909_512-user 6.0.1 MMB29M eng.mercury.20190408.123601 dev-keys FRP Partition Path: /dev/block/bootdevice/by-name/config FRP Partition Path: /dev/block/bootdevice/by-name/config Backup saved: BuildProp_20201014_1859.txt --------------------------------------------- Detected USERDATA USERDATA : 0x009C100000 (1.201GB) Short EXT fs info: Size: 1.201GB Block size: 4.0KB Inode size: 256 Inodes: 78880 Short userdata info: Unable to read gesture.key , code 2 Done. |
