Old 08-22-2018, 01:33   #1 (permalink)
iArkAt8's Avatar
Member: 1744310
Sonork: 100.1617232
Thanks Meter: 43
Lenovo yoga yt2-830lc
HI
lenovo yoga yt2-830lc dead by wrrong firmware and coud not detect any driver by pc.
i created 3 type of dump from alive board.
1: read by vendor xml file, Vendor Intel(GPT)
2: read emmc Rom1-1gb Rom2-4mb Rom3-4mb. Maybe wrong
3: read full dump by another soft
at this time i dont have this alive board to create Right Dump
while write by vendor from xml Error: First create a GP1 partition
while write by vendor from image (readed full dump by another soft):
Section GP1 does not exist on eMMC !!!
after write emmc Rom1,2,3 write complete but still dead
how to create GP1 partition or what is the size of GP1 partition?
after created GP1 partition cant write by vendor ,emmc size dont match with vendor file
after create GP1 partition and coud not repaire , i update emmc firmware and continued to repaire
log:
Running:SAMSUNG: eMMC firmware update...
Init OK...
EMMC NAME: AWMB3R
EMMC Part Number: KLMAG2WEMB-B031
Auto FW file for IC: C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KLMAG2WEMB-B031.bin
Z3X EasyJtag Software ver. 3.0.0.0
Skip loading eMMC Addon Firmware
Box S/N: 19FFE00D100EFD04, ,FW Ver.: 01.63
CMD Pullup Level:1711 mV
CMD Active Level:1794 mV
Box IO Level:1800 mV
CLK Rate:14000 kHz
Using firmware file : C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KLMAG2WEMB-B031.bin
Firmware EP Offset:00040000
Update Firmware ID Hash:3DBC084022F83292078D351C06C70E3E
Setup firmware update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]!
Do it until progress bar is moving (20 sec timeout)!
Success!
eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Setting frequence to 21 Mhz
CMD Pullup Level: 1711 mV
CMD Active Level: 1794 mV
EMMC Device Information :
EMMC CID: 15010041574D423352003D424C2131C8
EMMC CSD: D02701320F5903FFF6DBFFEF92404008
EMMC Manufacture : SAMSUNG , EMMC NAME: AWMB3R , HEX: 41574D423352 , S/N: 3D424C21 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2014
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: AWMB3R_3D424C21_20180822_042548.extcsd
EMMC Init completed.
Opening file: AWMB3R_rawprogram0.xml
Backup saved: AWMB3R_3D424C21_20180822_042738.extcsd
Opening file: Samsung eMMC AWMB3R_05_08_2018_15_06_16.bin
Analyzing Image: Samsung eMMC AWMB3R_05_08_2018_15_06_16.bin
Vendor: Intel
Searching GPT ...
GPT header is found and is valid
GPT header successfully parsed
The size of the last section has been updated
Old 08-22-2018, 08:17   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
I write some video (now without subtitles)
https://www.youtube.com/watch?v=wJNvxMSdocM
It may be help you
You backup you can write by vendor -Intel
The Following User Says Thank You to layder For This Useful Post:
Old 08-22-2018, 21:44   #3 (permalink)
iArkAt8's Avatar
Member: 1744310
Sonork: 100.1617232
Thanks Meter: 43
thanks for replay
problem here, readed by vendor and find partition table from alive YT2 bootloader_gp1.bin have 0b size!!!
see picture please http://tinypic.com/r/259y2wl/9
Old 08-23-2018, 09:14   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Originally Posted by iArkAt8 View Post
thanks for replay
Post read log, please. Originally phone without GP1?
Deselect gp1 from write
Old 03-06-2019, 07:20   #5 (permalink)
iArkAt8's Avatar
Member: 1744310
Sonork: 100.1617232
Thanks Meter: 43
founded another alive yt2-830l
CMD Pullup Level: 1722 mV
EMMC CID: 15010041574D4233520180F3EC5BA1E4
EMMC Manufacture : SAMSUNG , EMMC NAME: AWMB3R , HEX: 41574D423352 , S/N: 80F3EC5B , rev. 0x01
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2014
Backup saved: AWMB3R_80F3EC5B_20190306_094925.extcsd
Scanning soft partitions
Partition: reserved, [000000005000 - 000000805000], size: 000000800000 (8.00 MB)
Partition: ESP, [000000805000 - 000002905000], size: 000002100000 (33.0 MB)
Partition: boot, [000002905000 - 000003905000], size: 000001000000 (16.0 MB)
Partition: recovery, [000003905000 - 000004D05000], size: 000001400000 (20.0 MB)
Partition: fastboot, [000004D05000 - 000005D05000], size: 000001000000 (16.0 MB)
Partition: reserved_1, [000005D05000 - 000006505000], size: 000000800000 (8.00 MB)
Partition: panic, [000006505000 - 000008505000], size: 000002000000 (32.0 MB)
Partition: factory, [000008505000 - 000028505000], size: 000020000000 (512. MB)
Partition: misc, [000028505000 - 000028D05000], size: 000000800000 (8.00 MB)
Partition: config, [000028D05000 - 000030D05000], size: 000008000000 (128. MB)
Partition: cache, [000030D05000 - 000038D05000], size: 000008000000 (128. MB)
Partition: logs, [000038D05000 - 000048D05000], size: 000010000000 (256. MB)
Partition: system, [000048D05000 - 0000C8D05000], size: 000080000000 (2.00 GB)
Partition: data, [0000C8D05000 - 0003A3600000], size: 0002DA8FB000 (11.4 GB)
Get firmware version
Brand = Lenovo
Manufacturer = LENOVO
Device = YT2
Model = YOGA Tablet 2-830L
Phone platform = baytrail
CPU Abi = x86
Android release = 4.4.2
Firmware version = KOT49H.YT2-830L_USR_S000153_1501051824_WW21_ROW dev-keys
Firmware date = Mon Jan 5 18:35:03 CST 2015
CMD Pullup Level: 1701 mV
CMD Active Level: 1784 mV
Backup saved: AWMB3R_80F3EC5B_20190306_094941.extcsd
Operation: Try to read table from emmc
Vendor: Intel
Searching GPT ...
Checking for ROM2 ...
ROM2 is blank
Checking for ROM3 ...
ROM3 is blank
bootloader_gp1 on read by vendor 0b
Old 03-14-2019, 23:31   #6 (permalink)
Member: 2614573
Thanks Meter: 5
Hi
I have this problem too
my tablet not powered and i think this model (intel atom cpu) booted from bios [Winbond ic] .
During OTA update bios fw corrupted and device not powered .
We must find bios fw and update bios with SPI Flasher .
Page generated in 0.19853 seconds with 8 queries
