Old 03-20-2020, 20:31   #1 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Need Some Info About Samsung Downgrade Via ISP
Hi Friend I Am Having A Query About Samsung Downgrade I Need Some Info About Procedures Or Hint For My Case..
Problem :- I Have Samsung J610F J6+ Handset With U5 Binary Actually Phone Have Copy Touch With U5 Binary Touch Not Work Need To Downgrade...
History :- Phone Have All Things Working Some XYZ Technicians From Market Installed U5 Binary But U4 Binary Is Latest Till Now For My Region...After He Flash Volte N Touch Issue Arrive..
What I Try To Solve :- 1st Flashing With OEM N FRP OFF With U4 Binary Gets Fail With Error Phone Having U5...Not Even Combination Allow To Flash U4...U5 Combination Not Available For Now...
Now With ISP I Try To Full Flash Using Write By Vendor Handset Dead...Then I Again Write Backup (Which I Was Taken Before) Handset On Then I Write Only System To Change My Binary To U4 (Easy JTAG Show U4 Build In Info) But In Download Mode Still Showing U5 (Flashing Again Fail Via Download Mode) So I Try Erase Whole Chip N Flash With U4 File N Write Security...Now Again On DLOAD..
So I Wanna Know Few Things About This..What If I Erase N Write Factory File Only Not Security Sector Can I Repair Security Later Using Backup EFS Or Dump Or Anything Else...
2n How Can I Change Download Mode Binary Status As In Earlier Android Ver When U Write System It Allow To Flash...Phone Having Android 9.0...
3rd Can We Extract Cert Data From Dump For This Phone....
Any Guidance Or Help Will Be Appreciated...
Old 03-21-2020, 11:42   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Samsung device can't start with old boots (U5->U4, etc)
Old 03-21-2020, 11:54   #3 (permalink)
Member: 1834832
Thanks Meter: 1,450
What If I Erase Whole Chip N Write U4 Then Also It Won't Boot....?
Old 03-21-2020, 14:49   #4 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 307
only phone can boot up with lateat binaray if u used any old binaray the no:confuse d:
Old 03-22-2020, 10:35   #5 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
protection at CPU
erase can't help you
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 03-24-2020, 12:27   #6 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
As sir layder said, protection lies in CPU not only in eMMC.
There're some areas in SoC that has OTP specification which means it works like a Fuse and these areas are responsible for software images verification, specifically SBL (XBL).
For example, Xiaomi Redmi Note 5 (whyred) with Qualcomm CPU.
Antirollback (ARB) protection that prevents us from Downgrade, stored inside CPU in a specific area called QFPROM.
If device has ARB 3 that means not only eMMC knows about but also CPU.
And so, erasing eMMC and reprogramming it with a lower ARB won't help at all as CPU will always want ARB 3 firmware in order to boot.
The idea here is to access QFPROM and overwrite it's data or erase it and this is actually.... Impossible!.
for more information, read here and here
br, mshib0
The Following 5 Users Say Thank You to MiRoOo For This Useful Post:
Old 03-26-2020, 15:01   #7 (permalink)
Member: 2489055
Thanks Meter: 71
Untick repartition option while flashing be careful.downgrade will work
Old 03-26-2020, 15:04   #8 (permalink)
Member: 2489055
Thanks Meter: 71
first flash u4 combination by isp.be careful to untick repartition.if u dont untick phone will be dead.not need to erase chip
after flash .put phone in download mode and flash u4 combination by odin thats it.
The Following User Says Thank You to hardnsoft67 For This Useful Post:
Old 03-27-2020, 15:07   #9 (permalink)
yuresh's Avatar
Member: 1235816
Thanks Meter: 95
This solution has been researched?
Page generated in 0.19533 seconds with 8 queries
