07-26-2021, 17:22 | #1 (permalink) |
Junior Member Join Date: May 2016
Member: 2570643 Status: Offline Thanks Meter: 4 | g610f emmc pinout emmc log Code: 7/25/2021 7:26:18 PM> 7/25/2021 7:26:18 PM> eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) 7/25/2021 7:26:21 PM> Microsoft Windows 10 (64 bit) build 10586 (10.0.10586.0) 7/25/2021 7:26:21 PM> 7/25/2021 7:26:21 PM> Looking for EasyJTAG box... 7/25/2021 7:26:21 PM> EasyJTAG API ver. 3403 7/25/2021 7:26:21 PM> OpenUSB returned = 0 7/25/2021 7:26:22 PM> EasyJTAG Box Serial = CA5932437A6673E3 7/25/2021 7:26:23 PM> Card Serial = AAC8171E 7/25/2021 7:26:23 PM> EasyJTAG Box Firmware = 2.5302 7/25/2021 7:26:23 PM> 7/25/2021 7:27:03 PM> Looking for EasyJTAG box... 7/25/2021 7:27:03 PM> EasyJTAG API ver. 3403 7/25/2021 7:27:03 PM> Setting IO Levels to 1.8V 7/25/2021 7:27:03 PM> Setting frequence to 24 MHz 7/25/2021 7:27:03 PM> EasyJTAG Box Serial = CA5932437A6673E3 7/25/2021 7:27:03 PM> EasyJTAG Box Firmware = 2.5302 7/25/2021 7:27:04 PM> Setting interface to EasyJtag2/ISP 7/25/2021 7:27:04 PM> Setting bus width to 1 Bit 7/25/2021 7:27:04 PM> Setting frequence to 24 MHz 7/25/2021 7:27:04 PM> CMD Pullup Level: 439 mV 7/25/2021 7:27:05 PM> CMD Active Level: 1165 mV 7/25/2021 7:27:05 PM> eMMC Init returned = 0 7/25/2021 7:27:05 PM> EMMC Device Information : 7/25/2021 7:27:05 PM> EMMC CID: 150100414A4E42335203F75DFAF97465 7/25/2021 7:27:05 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 7/25/2021 7:27:05 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: AJNB3R , HEX: 414A4E423352 , S/N: F75DFAF9 , rev. 0x03 7/25/2021 7:27:05 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 7/25/2021 7:27:05 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 7/25/2021 7:27:05 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 7/25/2021 7:27:05 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 7/25/2021 7:27:05 PM> EMMC Permanent Write Protection: No 7/25/2021 7:27:05 PM> EMMC Temporary Write Protection: No 7/25/2021 7:27:05 PM> Extended CSD Information : 7/25/2021 7:27:05 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 7/25/2021 7:27:05 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 7/25/2021 7:27:05 PM> Boot Bus Config: 0x01 , width 4bit 7/25/2021 7:27:05 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 7/25/2021 7:27:05 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 7/25/2021 7:27:05 PM> Device supports partitioning features 7/25/2021 7:27:05 PM> Device can have enhanced technological features in partitions and user data area 7/25/2021 7:27:05 PM> Device can have extended partitions attribute 7/25/2021 7:27:05 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 7/25/2021 7:27:05 PM> Backup saved: AJNB3R_F75DFAF9_20210725_192705.extcsd 7/25/2021 7:27:05 PM> EMMC Init completed. 7/25/2021 7:27:06 PM> 7/25/2021 7:27:17 PM> Warning: Health report is very BAD 7/25/2021 7:27:17 PM> 7/25/2021 7:27:17 PM> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 7/25/2021 7:27:17 PM> Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time 7/25/2021 7:27:17 PM> Pre EOL information [267]: 0x01 Normal and Code: 7/25/2021 7:39:18 PM> 7/25/2021 7:39:18 PM> eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) 7/25/2021 7:39:22 PM> Microsoft Windows 10 (64 bit) build 10586 (10.0.10586.0) 7/25/2021 7:39:22 PM> 7/25/2021 7:39:22 PM> Looking for EasyJTAG box... 7/25/2021 7:39:22 PM> EasyJTAG API ver. 3403 7/25/2021 7:39:24 PM> OpenUSB returned = 0 7/25/2021 7:39:24 PM> EasyJTAG Box Serial = CA5932437A6673E3 7/25/2021 7:39:25 PM> Card Serial = AAC8171E 7/25/2021 7:39:25 PM> EasyJTAG Box Firmware = 2.5302 7/25/2021 7:39:25 PM> 7/25/2021 7:39:48 PM> Looking for EasyJTAG box... 7/25/2021 7:39:48 PM> EasyJTAG API ver. 3403 7/25/2021 7:39:48 PM> Setting IO Levels to 1.8V 7/25/2021 7:39:48 PM> Setting frequence to 24 MHz 7/25/2021 7:39:48 PM> EasyJTAG Box Serial = CA5932437A6673E3 7/25/2021 7:39:48 PM> EasyJTAG Box Firmware = 2.5302 7/25/2021 7:39:50 PM> Setting interface to EasyJtag2/ISP 7/25/2021 7:39:50 PM> Setting bus width to 1 Bit 7/25/2021 7:39:50 PM> Setting frequence to 24 MHz 7/25/2021 7:39:50 PM> CMD Pullup Level: 437 mV 7/25/2021 7:39:50 PM> CMD Active Level: 1164 mV 7/25/2021 7:39:50 PM> eMMC Init returned = 0 7/25/2021 7:39:50 PM> EMMC Device Information : 7/25/2021 7:39:50 PM> EMMC CID: 150100414A4E4233520398A1E8DE437F 7/25/2021 7:39:50 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 7/25/2021 7:39:50 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: AJNB3R , HEX: 414A4E423352 , S/N: 98A1E8DE , rev. 0x03 7/25/2021 7:39:50 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2016 7/25/2021 7:39:50 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 7/25/2021 7:39:50 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 7/25/2021 7:39:50 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean 7/25/2021 7:39:50 PM> EMMC Permanent Write Protection: No 7/25/2021 7:39:50 PM> EMMC Temporary Write Protection: No 7/25/2021 7:39:50 PM> Extended CSD Information : 7/25/2021 7:39:50 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 7/25/2021 7:39:50 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 7/25/2021 7:39:50 PM> Boot Bus Config: 0x00 , width 1bit 7/25/2021 7:39:50 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 7/25/2021 7:39:50 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 7/25/2021 7:39:50 PM> Device supports partitioning features 7/25/2021 7:39:50 PM> Device can have enhanced technological features in partitions and user data area 7/25/2021 7:39:50 PM> Device can have extended partitions attribute 7/25/2021 7:39:50 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 7/25/2021 7:39:50 PM> Backup saved: AJNB3R_98A1E8DE_20210725_193950.extcsd 7/25/2021 7:39:50 PM> EMMC Init completed. 7/25/2021 7:39:50 PM> 7/25/2021 7:39:51 PM> Operation: Reading S.M.A.R.T Report ... 7/25/2021 7:39:51 PM> 7/25/2021 7:39:51 PM> Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used 7/25/2021 7:39:51 PM> Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used 7/25/2021 7:39:51 PM> Pre EOL information [267]: 0x01 Normal 7/25/2021 7:39:51 PM> 7/25/2021 7:39:51 PM> Optimal Read Size [266]: 0x00 Not defined 7/25/2021 7:39:51 PM> Optimal Write Size [265]: 0x08 32 KB 7/25/2021 7:39:51 PM> Optimal Trim Unit Size [264]: 0x01 4 KB Code: 7/25/2021 7:47:23 PM> Looking for EasyJTAG box... 7/25/2021 7:47:23 PM> EasyJTAG API ver. 3403 7/25/2021 7:47:23 PM> Setting IO Levels to 1.8V 7/25/2021 7:47:23 PM> Setting frequence to 24 MHz 7/25/2021 7:47:23 PM> EasyJTAG Box Serial = CA5932437A6673E3 7/25/2021 7:47:23 PM> EasyJTAG Box Firmware = 2.5302 7/25/2021 7:47:25 PM> Setting interface to EasyJtag2/ISP 7/25/2021 7:47:25 PM> Setting bus width to 1 Bit 7/25/2021 7:47:25 PM> Setting frequence to 24 MHz 7/25/2021 7:47:25 PM> CMD Pullup Level: 438 mV 7/25/2021 7:47:25 PM> CMD Active Level: 1164 mV 7/25/2021 7:47:25 PM> eMMC Init returned = 0 7/25/2021 7:47:25 PM> EMMC Device Information : 7/25/2021 7:47:25 PM> EMMC CID: 150100414A4E4233520398A1E8DE437F 7/25/2021 7:47:25 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 7/25/2021 7:47:25 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: AJNB3R , HEX: 414A4E423352 , S/N: 98A1E8DE , rev. 0x03 7/25/2021 7:47:25 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2016 7/25/2021 7:47:25 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 7/25/2021 7:47:25 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 7/25/2021 7:47:25 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean 7/25/2021 7:47:25 PM> EMMC Permanent Write Protection: No 7/25/2021 7:47:25 PM> EMMC Temporary Write Protection: No 7/25/2021 7:47:25 PM> Extended CSD Information : 7/25/2021 7:47:25 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 7/25/2021 7:47:25 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 7/25/2021 7:47:25 PM> Boot Bus Config: 0x01 , width 4bit 7/25/2021 7:47:26 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 7/25/2021 7:47:26 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 7/25/2021 7:47:26 PM> Device supports partitioning features 7/25/2021 7:47:26 PM> Device can have enhanced technological features in partitions and user data area 7/25/2021 7:47:26 PM> Device can have extended partitions attribute 7/25/2021 7:47:26 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 7/25/2021 7:47:26 PM> Backup saved: AJNB3R_98A1E8DE_20210725_194726.extcsd 7/25/2021 7:47:26 PM> EMMC Init completed. 7/25/2021 7:47:26 PM> 7/25/2021 7:47:26 PM> Operation: Write by vendor (Samsung) 7/25/2021 7:47:26 PM> 7/25/2021 7:47:26 PM> Creating GPT-partitioninig 7/25/2021 7:47:26 PM> Writing PrimaryGPT at address: 000000000000 7/25/2021 7:47:26 PM> Writing BackupGPT at address: 0003AB3FBE00 7/25/2021 7:47:26 PM> Writing PIT at address: 000000004400 7/25/2021 7:47:26 PM> GPT-partitioning done 7/25/2021 7:47:26 PM> 7/25/2021 7:47:26 PM> Unpacking file: cm.bin 7/25/2021 7:47:26 PM> Unpacking Lz4: cm.bin.lz4 7/25/2021 7:47:27 PM> Unpacking file: sboot.bin 7/25/2021 7:47:27 PM> Unpacking Lz4: sboot.bin.lz4 7/25/2021 7:47:27 PM> Unpacking file: param.bin 7/25/2021 7:47:27 PM> Unpacking Lz4: param.bin.lz4 7/25/2021 7:47:27 PM> Unpacking file: boot.img 7/25/2021 7:47:27 PM> Unpacking Lz4: boot.img.lz4 7/25/2021 7:47:27 PM> Unpacking file: recovery.img 7/25/2021 7:47:27 PM> Unpacking Lz4: recovery.img.lz4 7/25/2021 7:47:27 PM> Unpacking file: modem.bin 7/25/2021 7:47:28 PM> Unpacking file: modem_debug.bin 7/25/2021 7:47:28 PM> 7/25/2021 7:47:28 PM> Partition name: CM 7/25/2021 7:47:28 PM> Filename: cm.bin , Offset: 000000000000 , filesize: 2445584 bytes 7/25/2021 7:47:28 PM> eMMC switching to ROM3 7/25/2021 7:47:28 PM> Erasing partition... 7/25/2021 7:47:33 PM> Writing partition... 7/25/2021 7:47:36 PM> Done writing partition. Write speed: 738.60 KB/s 7/25/2021 7:47:36 PM> Partition name: BOOTLOADER 7/25/2021 7:47:36 PM> Filename: sboot.bin , Offset: 000000000000 , filesize: 1728784 bytes 7/25/2021 7:47:36 PM> eMMC switching to ROM2 7/25/2021 7:47:36 PM> Erasing partition... 7/25/2021 7:47:42 PM> Writing partition... 7/25/2021 7:47:44 PM> Done writing partition. Write speed: 739.67 KB/s 7/25/2021 7:47:44 PM> Partition name: PARAM 7/25/2021 7:47:44 PM> Filename: param.bin , Offset: 000003500000 , filesize: 1341440 bytes 7/25/2021 7:47:45 PM> eMMC switching to ROM1 7/25/2021 7:47:45 PM> Erasing partition... 7/25/2021 7:47:47 PM> Writing partition... 7/25/2021 7:47:48 PM> Done writing partition. Write speed: 1333.86 KB/s 7/25/2021 7:47:48 PM> Partition name: BOOT 7/25/2021 7:47:48 PM> Filename: boot.img , Offset: 000003D00000 , filesize: 18948384 bytes 7/25/2021 7:47:48 PM> eMMC switching to ROM1 7/25/2021 7:47:48 PM> Erasing partition... 7/25/2021 7:47:49 PM> Writing partition... 7/25/2021 7:47:56 PM> Done writing partition. Write speed: 2599.48 KB/s 7/25/2021 7:47:56 PM> Partition name: RECOVERY 7/25/2021 7:47:56 PM> Filename: recovery.img , Offset: 000005D00000 , filesize: 25768224 bytes 7/25/2021 7:47:56 PM> eMMC switching to ROM1 7/25/2021 7:47:57 PM> Erasing partition... 7/25/2021 7:47:58 PM> Writing partition... 7/25/2021 7:48:08 PM> Done writing partition. Write speed: 2579.01 KB/s 7/25/2021 7:48:08 PM> Partition name: RADIO 7/25/2021 7:48:08 PM> Filename: modem.bin , Offset: 000008F00000 , filesize: 36364688 bytes 7/25/2021 7:48:08 PM> eMMC switching to ROM1 7/25/2021 7:48:08 PM> Erasing partition... 7/25/2021 7:48:11 PM> Writing partition... 7/25/2021 7:48:25 PM> Done writing partition. Write speed: 2579.88 KB/s 7/25/2021 7:48:25 PM> Partition name: CP_DEBUG 7/25/2021 7:48:25 PM> Filename: modem_debug.bin , Offset: 0000DB400000 , filesize: 5242880 bytes 7/25/2021 7:48:25 PM> eMMC switching to ROM1 7/25/2021 7:48:25 PM> Erasing partition... 7/25/2021 7:48:26 PM> Writing partition... 7/25/2021 7:48:27 PM> Done writing partition. Write speed: 2705.25 KB/s 7/25/2021 7:50:47 PM> 7/25/2021 7:50:47 PM> Partition EFS : formatting as EXT4. Please wait ... 7/25/2021 7:50:48 PM> Formatting completed 7/25/2021 7:50:48 PM> 7/25/2021 7:50:48 PM> Partition CACHE : formatting as EXT4. Please wait ... 7/25/2021 7:50:49 PM> Formatting completed 7/25/2021 7:50:49 PM> Partition HIDDEN : formatting as EXT4. Please wait ... 7/25/2021 7:50:50 PM> Formatting completed 7/25/2021 7:50:57 PM> 7/25/2021 7:50:57 PM> Check BootConfig for the selected vendor 7/25/2021 7:50:57 PM> 7/25/2021 7:50:57 PM> All done time: [00:03:29:432] in device manage only show cpu ????? |
08-06-2021, 03:29 | #2 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Annaba, ALGERIA
Member: 1678953 Status: Offline Thanks Meter: 67 | Code: 7/25/2021 7:27:06 PM> 7/25/2021 7:27:17 PM> Warning: Health report is very BAD 7/25/2021 7:27:17 PM> 7/25/2021 7:27:17 PM> Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time 7/25/2021 7:27:17 PM> Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time |
