11-28-2019, 15:57 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1042338 Status: Offline Thanks Meter: 8 | fully encrypted emmc how solve it i need decrypt a memory from a emmc, but is fully encrypted, have anyone some solution? tanks eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 42062D4361FF9492 Card Serial = AAAA220E EasyJTAG Box Firmware = 2.48 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 14 MHz EMMC Device Information : EMMC CID: 150100525831424D4207093F6A8183DD EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: 093F6A81 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_093F6A81_20191128_163414.extcsd EMMC Init completed. Operation: File Explorer... Scan from: RX1BMB Vendor: Qualcomm Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [nvdata] successfully PartType: LINUX Mount [protect_f] successfully PartType: LINUX Mount [protect_s] successfully PartType: LINUX Mount [system] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [data] SKIPPED PartType: Full Disk Encryption Get firmware version Brand = Neffos Manufacturer = TP-Link Device = X1_Max Model = Neffos X1 Max Phone platform = mt6755 CPU Abi = arm64-v8a Mediatek platform = MT6755 Android release = 6.0 Firmware version = H10S100D00B20170407R1381 Firmware date = Fri Apr 7 20:47:56 HKT 2017 |
07-03-2021, 13:46 | #3 (permalink) |
Junior Member Join Date: Jan 2007
Member: 428283 Status: Offline Thanks Meter: 4 | Emmc encrypt Hello everyone I would like to ask for help I have 2 samsung a750 of which one turns on and the other does not turn on I should recover the data of the one that does not turn on the question is if I copy the data from emmc and copy them on the working device with easy plus jtag rieco to see the data? Thank you |
07-04-2021, 05:46 | #4 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
you can only move CPU+eMMC(UFS) to another PCB for start device | |
The Following User Says Thank You to layder For This Useful Post: |
