Old 06-02-2022, 16:28   #1 (permalink)
Member: 1391134
Thanks Meter: 47
a605g change emmc and boot repair done but phone is not working
Z3X EasyJtag Software ver. 3.7.0.23
Skip loading eMMC Addon Firmware
CMD Pullup Level:2000 mV
CMD Active Level:2526 mV
Input file : C:\New folder (6)\A600G\EMMC_RH64AB_ROM1_000000000000_0000400000 00.bin
Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM)
Done, time taken: 266 sec. Average Write Speed: 4024 kB/s
Input file : C:\New folder (6)\A600G\EMMC_RH64AB_ROM2_000000000000_0000004000 00.bin
Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 4 sec. Average Write Speed: 854 kB/s
Input file : C:\New folder (6)\A600G\EMMC_RH64AB_ROM3_000000000000_0000004000 00.bin
Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Done, time taken: 4 sec. Average Write Speed: 868 kB/s
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0A00E013F603DAEE, ,FW Ver.: 01.63
CMD Pullup Level:1990 mV
CMD Active Level:2598 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100524836344D42054CB668AE84B6
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2017 Rev.0x5
eMMC NAME: RH64MB , S/N: 1287022766
eMMC NAME (HEX): 524836344D42
IC Name: Samsung , KMRH60014M-B614/64GB @BGA221 , Firmware is Updatable
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is not yet programmed (clear) or RPMB General failure
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: RH64MB_1287022766_20220602_1853.extcsd
Caution: invalid backup GPT header, but valid main header!
EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0015800000 (3.85GB)
Unable to mount SYSTEM , code : 95
Detected USERDATA USERDATA : 0x0123D00000 (53.681GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
Done.
eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021)
Microsoft Windows 10 (64 bit) build 16299 (10.0.16299.1480)
Looking for EasyJTAG box...
EasyJTAG API ver. 3403
EasyJTAG Box Serial = 0A00E013F603DAEE
Card Serial = AAEC997E
EasyJTAG Box Firmware = 1.6300
Changelog:
05.05.2021 (ver 1.6.6.0)
Add: New keys for Oppo unpack
Fix: Bugs that have been found through your crash report
05.05.2021 (ver 2.0.1.0)
Add: Vendor LG
Add: Mediatek Preloader Parser
Add: OnePlus Unpacker
Add: Xiaomi Custom EDL Authorization
Add: Xiaomi Remove Mi Account (only Qualcomm)
HiPower mode is ON
Setting frequence to 21 MHz
CMD Pullup Level: 1990 mV
CMD Active Level: 2598 mV
EMMC Device Information :
EMMC CID: 150100524836344D30051A0168AE84AE
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: RH64M0 , HEX: 524836344D30 , S/N: 1A0168AE , rev. 0x05
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Backup saved: RH64M0_1A0168AE_20220602_193543.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB)
Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB)
Partition: ddr, [000000500000 - 000000580000], size: 000000080000 (512. KB)
Partition: rpm, [000000580000 - 000000600000], size: 000000080000 (512. KB)
Partition: tz, [000000600000 - 000000800000], size: 000000200000 (2.00 MB)
Partition: aboot, [000000800000 - 000000A00000], size: 000000200000 (2.00 MB)
Partition: sec, [000000A00000 - 000000A40000], size: 000000040000 (256. KB)
Partition: lksecapp, [000000A40000 - 000000AC0000], size: 000000080000 (512. KB)
Partition: keymaster, [000000AC0000 - 000000B40000], size: 000000080000 (512. KB)
Partition: cmnlib, [000000B40000 - 000000B80000], size: 000000040000 (256. KB)
Partition: fsg, [000000B80000 - 000000F80000], size: 000000400000 (4.00 MB)
Partition: cmnlib64, [000000F80000 - 000000FC0000], size: 000000040000 (256. KB)
Partition: pad, [000000FC0000 - 000001000000], size: 000000040000 (256. KB)
Partition: modemst1, [000001000000 - 000001400000], size: 000000400000 (4.00 MB)
Partition: modemst2, [000001400000 - 000001800000], size: 000000400000 (4.00 MB)
Partition: efs, [000001C00000 - 000002C00000], size: 000001000000 (16.0 MB)
Partition: fsc, [000002C00000 - 000002F40000], size: 000000340000 (3.25 MB)
Partition: ssd, [000002F40000 - 000002F80000], size: 000000040000 (256. KB)
Partition: devcfg, [000002F80000 - 000002FC0000], size: 000000040000 (256. KB)
Partition: apdp, [000002FC0000 - 000002FE0000], size: 000000020000 (128. KB)
Partition: msadp, [000002FE0000 - 000003000000], size: 000000020000 (128. KB)
Partition: param, [000003000000 - 000003C00000], size: 000000C00000 (12.0 MB)
Partition: backup, [000003C00000 - 000004000000], size: 000000400000 (4.00 MB)
Partition: misc, [000004000000 - 000004100000], size: 000000100000 (1.00 MB)
Partition: boot, [000004100000 - 000006100000], size: 000002000000 (32.0 MB)
Partition: recovery, [000006100000 - 000008100000], size: 000002000000 (32.0 MB)
Partition: dtbo, [000008100000 - 000008300000], size: 000000200000 (2.00 MB)
Partition: bota, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB)
Partition: fota, [000008B00000 - 000008F00000], size: 000000400000 (4.00 MB)
Partition: nad_refer, [000008F00000 - 000009500000], size: 000000600000 (6.00 MB)
Partition: persist, [000009500000 - 00000B500000], size: 000002000000 (32.0 MB)
Partition: persistent, [00000B500000 - 00000B600000], size: 000000100000 (1.00 MB)
Partition: steady, [00000B600000 - 00000BA00000], size: 000000400000 (4.00 MB)
Partition: keystore, [00000BA00000 - 00000BB00000], size: 000000100000 (1.00 MB)
Partition: config, [00000BB00000 - 00000BC00000], size: 000000100000 (1.00 MB)
Partition: dsp, [00000BC00000 - 00000CC00000], size: 000001000000 (16.0 MB)
Partition: modem, [00000CC00000 - 000012C00000], size: 000006000000 (96.0 MB)
Partition: apnhlos, [000012C00000 - 000015000000], size: 000002400000 (36.0 MB)
Partition: debug, [000015000000 - 000015800000], size: 000000800000 (8.00 MB)
Partition: system, [000015800000 - 0000DB000000], size: 0000C5800000 (3.09 GB)
Partition: vendor, [0000DB000000 - 0000F9000000], size: 00001E000000 (480. MB)
Partition: odm, [0000F9000000 - 00010F800000], size: 000016800000 (360. MB)
Partition: cache, [00010F800000 - 000122400000], size: 000012C00000 (300. MB)
Partition: hidden, [000122400000 - 000122900000], size: 000000500000 (5.00 MB)
Partition: omr, [000122900000 - 000123D00000], size: 000001400000 (20.0 MB)
Partition: userdata, [000123D00000 - 000E8F7FB000], size: 000D6BAFB000 (53.6 GB)
GPT header successfully parsed
Get firmware version
Firmware info not found
HiPower mode is ON
Backup saved: RH64M0_1A0168AE_20220602_193603.extcsd
Opening file: A6PLTE_EUR_OPEN.pit
Pit: A6PLTE_EUR_OPEN.pit
Entry count: 51
The size of the last section has been updated
BL_A605GDXU9CVB1_CL23318745_QB48995193_REV00_user_ low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
aboot.mbn.lz4
sbl1.mbn.lz4
rpm.mbn.lz4
tz.mbn.lz4
devcfg.mbn.lz4
cmnlib.mbn.lz4
keymaster.mbn.lz4
apdp.mbn.lz4
msadp.mbn.lz4
non-hlos.bin.lz4
lksecapp.mbn.lz4
sec.dat.lz4
HiPower mode is ON
Backup saved: RH64M0_1A0168AE_20220602_193627.extcsd
Operation: Write by vendor (Samsung)
Unpacking file: sbl1.mbn
Unpacking Lz4: sbl1.mbn.lz4
Unpacking file: rpm.mbn
Unpacking Lz4: rpm.mbn.lz4
Unpacking file: tz.mbn
Unpacking Lz4: tz.mbn.lz4
Unpacking file: aboot.mbn
Unpacking Lz4: aboot.mbn.lz4
Unpacking file: sec.dat
Unpacking Lz4: sec.dat.lz4
Unpacking file: lksecapp.mbn
Unpacking Lz4: lksecapp.mbn.lz4
Unpacking file: keymaster.mbn
Unpacking Lz4: keymaster.mbn.lz4
Unpacking file: cmnlib.mbn
Unpacking Lz4: cmnlib.mbn.lz4
Unpacking file: devcfg.mbn
Unpacking Lz4: devcfg.mbn.lz4
Unpacking file: apdp.mbn
Unpacking Lz4: apdp.mbn.lz4
Unpacking file: msadp.mbn
Unpacking Lz4: msadp.mbn.lz4
Unpacking file: non-hlos.bin
Unpacking Lz4: non-hlos.bin.lz4
Partition name: SBL1
Filename: sbl1.mbn , Offset: 000000400000 , filesize: 374888 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 449.13 KB/s
Partition name: RPM
Filename: rpm.mbn , Offset: 000000580000 , filesize: 176124 bytes
Done writing partition. Write speed: 408.37 KB/s
Partition name: TZ
Filename: tz.mbn , Offset: 000000600000 , filesize: 1519360 bytes
Done writing partition. Write speed: 866.41 KB/s
Partition name: ABOOT
Filename: aboot.mbn , Offset: 000000800000 , filesize: 1581300 bytes
Done writing partition. Write speed: 855.35 KB/s
Partition name: SEC
Filename: sec.dat , Offset: 000000A00000 , filesize: 948 bytes
Done writing partition. Write speed: 75.54 KB/s
Partition name: LKSECAPP
Filename: lksecapp.mbn , Offset: 000000A40000 , filesize: 250728 bytes
Done writing partition. Write speed: 851.33 KB/s
Partition name: KEYMASTER
Filename: keymaster.mbn , Offset: 000000AC0000 , filesize: 230616 bytes
Done writing partition. Write speed: 842.07 KB/s
Partition name: CMNLIB
Filename: cmnlib.mbn , Offset: 000000B40000 , filesize: 205984 bytes
Done writing partition. Write speed: 853.25 KB/s
Partition name: DEVCFG
Filename: devcfg.mbn , Offset: 000002F80000 , filesize: 38748 bytes
Done writing partition. Write speed: 611.92 KB/s
Partition name: APDP
Filename: apdp.mbn , Offset: 000002FC0000 , filesize: 13760 bytes
Done writing partition. Write speed: 482.66 KB/s
Partition name: MSADP
Filename: msadp.mbn , Offset: 000002FE0000 , filesize: 13760 bytes
Done writing partition. Write speed: 498.11 KB/s
Partition name: APNHLOS
Filename: non-hlos.bin , Offset: 000012C00000 , filesize: 36378624 bytes
Done writing partition. Write speed: 860.84 KB/s
Partition CACHE : formatting as EXT4. Please wait ...
Formatting completed
Partition HIDDEN : formatting as EXT4. Please wait ...
Partition USERDATA : formatting as EXT4. Please wait ...
Check BootConfig for the selected vendor
All done time: [00:03:26:702]
now the phone is in download mode but show RPMB PROVISIONED,but HMAC mismatch error
i try to chanhe RPMB from 4 to 16 mib but failed this operation
any solution ?
tx z3x team
Old 06-13-2022, 12:02   #2 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 253
qualcom updates have to do i think in rpmb just theory..me and 1 guy also here have problem with qualcom samsung phone..he change emmc..me i just erase rpmb but we connot make the phone to work even if we have the full dump..flashing latest binary available also did not solve the problem..if you still have the old emmc try to read its rpmb..we try to write it back to the new emmc and check if any changes can be made this problem
Page generated in 0.19297 seconds with 9 queries
