06-11-2022, 14:19 | #1 (permalink) |
Freak Poster Join Date: Dec 2017 Location: Uganda
Member: 2793734 Status: Offline Thanks Meter: 22 | Nokia 1.4 unbrick, dead, stuck on powered by android done EasyJtag Suite Classic ver.: 3.7.0.24 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AADD-E0C9 , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM27 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM27) COM8 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM8) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 3D358578033FFFDB, ,FW Ver.: 02.53 CMD Pullup Level:2121 mV CMD Active Level:2473 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100515836334142036FC9F41CC7D9 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2020 Rev.0x3 eMMC NAME: QX63AB , S/N: 1875506204 eMMC NAME (HEX): 515836334142 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 37616 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QX63AB_1875506204_20220611_1557.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 55 partitions ------ P0 (MODEM) [0x4000000 0x5400000] Size: 84.0MB P1 (DDR) [0x9400000 0x8000] Size: 32.0KB P2 (FSGCOMBINE) [0x9408000 0x400000] Size: 4.0MB P3 (FSG) [0x9808000 0x180000] Size: 1.500MB P4 (SEC) [0x9988000 0x4000] Size: 16.0KB P5 (ABOOT) [0x998c000 0x100000] Size: 1.0MB P6 (ABOOTBAK) [0x9a8c000 0x100000] Size: 1.0MB P7 (DTBO) [0x9b8c000 0x800000] Size: 8.0MB P8 (DTBOBAK) [0xa38c000 0x800000] Size: 8.0MB P9 (VBMETA) [0xab8c000 0x10000] Size: 64.0KB P10 (VBMETABAK) [0xab9c000 0x10000] Size: 64.0KB P11 (BOOT) [0xabac000 0x2000000] Size: 32.0MB P12 (RECOVERY) [0xcbac000 0x3000000] Size: 48.0MB P13 (DEVINFO) [0xfbac000 0x100000] Size: 1.0MB P14 (SUPER) [0xfcac000 0x99800000] Size: 2.398GB sp (SUPER_metadata) [0xfcac000 0x3400] Size: 13.0KB sp (system) [0xfdac000 0x2800f000] Size: 640.58MB sp (product) [0x37eac000 0x4386a000] Size: 1.54GB sp (vendor) [0x7b7ac000 0xf717000] Size: 247.89MB sp (carrier) [0x8afac000 0x1b8a7000] Size: 440.652MB P15 (VBMETA_SYSTEM) [0xa94ac000 0x10000] Size: 64.0KB P16 (LIMITS) [0xa94bc000 0x8000] Size: 32.0KB P17 (CMNLIB) [0xa94c4000 0x100000] Size: 1.0MB P18 (CMNLIBBAK) [0xa95c4000 0x100000] Size: 1.0MB P19 (CMNLIB64) [0xa96c4000 0x100000] Size: 1.0MB P20 (CMNLIB64BAK) [0xa97c4000 0x100000] Size: 1.0MB P21 (KEYMASTER) [0xa98c4000 0x80000] Size: 512.0KB P22 (KEYMASTERBAK) [0xa9944000 0x80000] Size: 512.0KB P23 (FSC) [0xac000000 0x400] Size: 1.0KB P24 (SSD) [0xac001000 0x2000] Size: 8.0KB P25 (SBL1) [0xac003000 0x80000] Size: 512.0KB P26 (SBL1BAK) [0xac083000 0x80000] Size: 512.0KB P27 (RPM) [0xac103000 0x80000] Size: 512.0KB P28 (RPMBAK) [0xac183000 0x80000] Size: 512.0KB P29 (TZ) [0xac203000 0x200000] Size: 2.0MB P30 (TZBAK) [0xac403000 0x200000] Size: 2.0MB P31 (DEVCFG) [0xac603000 0x40000] Size: 256.0KB P32 (DEVCFGBAK) [0xac643000 0x40000] Size: 256.0KB P33 (DSP) [0xac683000 0x1000000] Size: 16.0MB P34 (MODEMST1) [0xad683000 0x180000] Size: 1.500MB P35 (MODEMST2) [0xad803000 0x180000] Size: 1.500MB P36 (SPLASH) [0xad983000 0xb00000] Size: 11.0MB P37 (CACHE) [0xae483000 0x6e00000] Size: 110.0MB P38 (PERSIST) [0xb5283000 0x2000000] Size: 32.0MB P39 (METADATA) [0xb7283000 0x1000000] Size: 16.0MB P40 (MISC) [0xb8283000 0x100000] Size: 1.0MB P41 (KEYSTORE) [0xb8383000 0x80000] Size: 512.0KB P42 (CONFIG) [0xb8403000 0x8000] Size: 32.0KB P43 (OEM) [0xb840b000 0x800000] Size: 8.0MB P44 (BTUI) [0xb8c0b000 0x500000] Size: 5.0MB P45 (MOTA) [0xb910b000 0x80000] Size: 512.0KB P46 (DIP) [0xb918b000 0x100000] Size: 1.0MB P47 (MDTP) [0xb928b000 0x2000000] Size: 32.0MB P48 (SYSCFG) [0xbb28b000 0x80000] Size: 512.0KB P49 (MCFG) [0xbb30b000 0x400000] Size: 4.0MB P50 (APDP) [0xbb70b000 0x40000] Size: 256.0KB P51 (MSADP) [0xbb74b000 0x40000] Size: 256.0KB P52 (DPO) [0xbb78b000 0x2000] Size: 8.0KB P53 (ELABEL) [0xbc000000 0x1400000] Size: 20.0MB P54 (USERDATA) [0xc0000000 0x687bfbe00] Size: 26.120GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) system : 0x000FDAC000 (640.58MB) Short EXT fs info: Size: 629.875MB Block size: 4.0KB Inode size: 256 Inodes: 3040 Short Android info: Device Brand: Nokia Device Name B: CBL Device Manufacturer: HMD Global Device Model: Nokia 1.4 Device Name A: Cable_00WW Build ID: QKQ1.200809.002 Display Build ID: 00WW_1_120_SP01 Release Incremental ID: 00WW_1_12A Release Base ID: 10 Security Path: 2021-07-05 Architecture ABI: armeabi-v7a Backup saved: BuildProp_20220611_1557.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00C0000000 (26.120GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. |
The Following User Says Thank You to Ashim Ashram For This Useful Post: |
