06-17-2018, 16:49 | #2 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | finaly done by this picture Z3X EasyJtag Software ver. 2.9.0.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0500C018EEB0D9C0, ,FW Ver.: 01.62 CMD Pullup Level:794 mV CMD Active Level:2536 mV Box IO Level:3300 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 110100303136473932309BCA8809B0E6 EMMC CSD : D00E00320F5903FFFFFFFFEF92400044 EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 11/2013 Rev.0x30 EMMC NAME: 016G92 , S/N: 2613741577 EMMC NAME (HEX): 30313647393200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 016G92_2613741577_20180617_0818.extcsd Done. |
The Following User Says Thank You to dereje For This Useful Post: |
06-17-2018, 17:48 | #3 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | What was you was missing? Way was not connecting Please explain Sent from my SM-A520F using Tapatalk |
The Following User Says Thank You to engcobocell For This Useful Post: |
06-18-2018, 19:03 | #5 (permalink) | |
Member: 449991 Status: Offline Thanks Meter: 933 | Quote:
12-13-2020, 14:28 | #7 (permalink) |
Freak Poster Join Date: Apr 2017 Location: kanpur
Member: 2707033 Status: Offline Thanks Meter: 26 | check isp jumper it is perfect no solve finaliy solve this problam change box harddware change no other solution this time bad team jtag no answser for this error may pepol is not happy new box perchasable box foult for box hardware not peerfect |
