11-23-2021, 08:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | NOKIA 1.4 TA-1322 WIPE DATA / SCREEN / FRP LOCK REMOVE and FULL FIRMWARE DUMPING Code: EasyJtag Suite Classic ver.: 3.7.0.20 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AA27-78BA , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 1 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM3) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.53 CMD Pullup Level:2135 mV CMD Active Level:2493 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501005158363341420945E2BC81C7AB eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2020 Rev.0x9 eMMC NAME: QX63AB , S/N: 1172487297 eMMC NAME (HEX): 515836334142 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 6038 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QX63AB_1172487297_20211122_2239.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 55 partitions ------ P0 (MODEM) [0x4000000 0x5400000] Size: 84.0MB P1 (DDR) [0x9400000 0x8000] Size: 32.0KB P2 (FSGCOMBINE) [0x9408000 0x400000] Size: 4.0MB P3 (FSG) [0x9808000 0x180000] Size: 1.500MB P4 (SEC) [0x9988000 0x4000] Size: 16.0KB P5 (ABOOT) [0x998c000 0x100000] Size: 1.0MB P6 (ABOOTBAK) [0x9a8c000 0x100000] Size: 1.0MB P7 (DTBO) [0x9b8c000 0x800000] Size: 8.0MB P8 (DTBOBAK) [0xa38c000 0x800000] Size: 8.0MB P9 (VBMETA) [0xab8c000 0x10000] Size: 64.0KB P10 (VBMETABAK) [0xab9c000 0x10000] Size: 64.0KB P11 (BOOT) [0xabac000 0x2000000] Size: 32.0MB P12 (RECOVERY) [0xcbac000 0x3000000] Size: 48.0MB P13 (DEVINFO) [0xfbac000 0x100000] Size: 1.0MB P14 (SUPER) [0xfcac000 0x99800000] Size: 2.398GB P15 (VBMETA_SYSTEM) [0xa94ac000 0x10000] Size: 64.0KB P16 (LIMITS) [0xa94bc000 0x8000] Size: 32.0KB P17 (CMNLIB) [0xa94c4000 0x100000] Size: 1.0MB P18 (CMNLIBBAK) [0xa95c4000 0x100000] Size: 1.0MB P19 (CMNLIB64) [0xa96c4000 0x100000] Size: 1.0MB P20 (CMNLIB64BAK) [0xa97c4000 0x100000] Size: 1.0MB P21 (KEYMASTER) [0xa98c4000 0x80000] Size: 512.0KB P22 (KEYMASTERBAK) [0xa9944000 0x80000] Size: 512.0KB P23 (FSC) [0xac000000 0x400] Size: 1.0KB P24 (SSD) [0xac001000 0x2000] Size: 8.0KB P25 (SBL1) [0xac003000 0x80000] Size: 512.0KB P26 (SBL1BAK) [0xac083000 0x80000] Size: 512.0KB P27 (RPM) [0xac103000 0x80000] Size: 512.0KB P28 (RPMBAK) [0xac183000 0x80000] Size: 512.0KB P29 (TZ) [0xac203000 0x200000] Size: 2.0MB P30 (TZBAK) [0xac403000 0x200000] Size: 2.0MB P31 (DEVCFG) [0xac603000 0x40000] Size: 256.0KB P32 (DEVCFGBAK) [0xac643000 0x40000] Size: 256.0KB P33 (DSP) [0xac683000 0x1000000] Size: 16.0MB P34 (MODEMST1) [0xad683000 0x180000] Size: 1.500MB P35 (MODEMST2) [0xad803000 0x180000] Size: 1.500MB P36 (SPLASH) [0xad983000 0xb00000] Size: 11.0MB P37 (CACHE) [0xae483000 0x6e00000] Size: 110.0MB P38 (PERSIST) [0xb5283000 0x2000000] Size: 32.0MB P39 (METADATA) [0xb7283000 0x1000000] Size: 16.0MB P40 (MISC) [0xb8283000 0x100000] Size: 1.0MB P41 (KEYSTORE) [0xb8383000 0x80000] Size: 512.0KB P42 (CONFIG) [0xb8403000 0x8000] Size: 32.0KB P43 (OEM) [0xb840b000 0x800000] Size: 8.0MB P44 (BTUI) [0xb8c0b000 0x500000] Size: 5.0MB P45 (MOTA) [0xb910b000 0x80000] Size: 512.0KB P46 (DIP) [0xb918b000 0x100000] Size: 1.0MB P47 (MDTP) [0xb928b000 0x2000000] Size: 32.0MB P48 (SYSCFG) [0xbb28b000 0x80000] Size: 512.0KB P49 (MCFG) [0xbb30b000 0x400000] Size: 4.0MB P50 (APDP) [0xbb70b000 0x40000] Size: 256.0KB P51 (MSADP) [0xbb74b000 0x40000] Size: 256.0KB P52 (DPO) [0xbb78b000 0x2000] Size: 8.0KB P53 (ELABEL) [0xbc000000 0x1400000] Size: 20.0MB P54 (USERDATA) [0xc0000000 0x687bfbe00] Size: 26.120GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SUPER : 0x000FCAC000 (2.398GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Detected USERDATA USERDATA : 0x00C0000000 (26.120GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.53 CMD Pullup Level:2135 mV CMD Active Level:2493 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501005158363341420945E2BC81C7AB eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2020 Rev.0x9 eMMC NAME: QX63AB , S/N: 1172487297 eMMC NAME (HEX): 515836334142 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 6038 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x00AE483000 (110.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x00B8403000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x00C0000000 (26.120GB) , formatting... Done. Done. Done. Checking security ... Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.53 CMD Pullup Level:2133 mV CMD Active Level:2506 mV Box IO Level:2800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501005158363341420945E2BC81C7AB eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2020 Rev.0x9 eMMC NAME: QX63AB , S/N: 1172487297 eMMC NAME (HEX): 515836334142 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 6038 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x00C0000000 (26.120GB) Mount EXT4 fs... Unable to mount USER , code : 95 --------------------------------------------- Done. eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = F6F272D292237F2E Card Serial = AA2778BA EasyJTAG Box Firmware = 2.5301 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2117 mV CMD Active Level: 2280 mV EMMC Device Information : EMMC CID: 1501005158363341420945E2BC81C7AB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX63AB , HEX: 515836334142 , S/N: 45E2BC81 , rev. 0x09 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 6038 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63AB_45E2BC81_20211123_054442.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB) Partition: DDR, [000009400000 - 000009408000], size: 000000008000 (32.0 KB) Partition: fsgcombine, [000009408000 - 000009808000], size: 000000400000 (4.00 MB) Partition: fsg, [000009808000 - 000009988000], size: 000000180000 (1.50 MB) Partition: sec, [000009988000 - 00000998C000], size: 000000004000 (16.0 KB) Partition: aboot, [00000998C000 - 000009A8C000], size: 000000100000 (1.00 MB) Partition: abootbak, [000009A8C000 - 000009B8C000], size: 000000100000 (1.00 MB) Partition: dtbo, [000009B8C000 - 00000A38C000], size: 000000800000 (8.00 MB) Partition: dtbobak, [00000A38C000 - 00000AB8C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [00000AB8C000 - 00000AB9C000], size: 000000010000 (64.0 KB) Partition: vbmetabak, [00000AB9C000 - 00000ABAC000], size: 000000010000 (64.0 KB) Partition: boot, [00000ABAC000 - 00000CBAC000], size: 000002000000 (32.0 MB) Partition: recovery, [00000CBAC000 - 00000FBAC000], size: 000003000000 (48.0 MB) Partition: devinfo, [00000FBAC000 - 00000FCAC000], size: 000000100000 (1.00 MB) Partition: super, [00000FCAC000 - 0000A94AC000], size: 000099800000 (2.40 GB) Partition: vbmeta_system, [0000A94AC000 - 0000A94BC000], size: 000000010000 (64.0 KB) Partition: limits, [0000A94BC000 - 0000A94C4000], size: 000000008000 (32.0 KB) Partition: cmnlib, [0000A94C4000 - 0000A95C4000], size: 000000100000 (1.00 MB) Partition: cmnlibbak, [0000A95C4000 - 0000A96C4000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [0000A96C4000 - 0000A97C4000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [0000A97C4000 - 0000A98C4000], size: 000000100000 (1.00 MB) Partition: keymaster, [0000A98C4000 - 0000A9944000], size: 000000080000 (512. KB) Partition: keymasterbak, [0000A9944000 - 0000A99C4000], size: 000000080000 (512. KB) Partition: fsc, [0000AC000000 - 0000AC000400], size: 000000000400 (1.00 KB) Partition: ssd, [0000AC001000 - 0000AC003000], size: 000000002000 (8.00 KB) Partition: sbl1, [0000AC003000 - 0000AC083000], size: 000000080000 (512. KB) Partition: sbl1bak, [0000AC083000 - 0000AC103000], size: 000000080000 (512. KB) Partition: rpm, [0000AC103000 - 0000AC183000], size: 000000080000 (512. KB) Partition: rpmbak, [0000AC183000 - 0000AC203000], size: 000000080000 (512. KB) Partition: tz, [0000AC203000 - 0000AC403000], size: 000000200000 (2.00 MB) Partition: tzbak, [0000AC403000 - 0000AC603000], size: 000000200000 (2.00 MB) Partition: devcfg, [0000AC603000 - 0000AC643000], size: 000000040000 (256. KB) Partition: devcfgbak, [0000AC643000 - 0000AC683000], size: 000000040000 (256. KB) Partition: dsp, [0000AC683000 - 0000AD683000], size: 000001000000 (16.0 MB) Partition: modemst1, [0000AD683000 - 0000AD803000], size: 000000180000 (1.50 MB) Partition: modemst2, [0000AD803000 - 0000AD983000], size: 000000180000 (1.50 MB) Partition: splash, [0000AD983000 - 0000AE483000], size: 000000B00000 (11.0 MB) Partition: cache, [0000AE483000 - 0000B5283000], size: 000006E00000 (110. MB) Partition: persist, [0000B5283000 - 0000B7283000], size: 000002000000 (32.0 MB) Partition: metadata, [0000B7283000 - 0000B8283000], size: 000001000000 (16.0 MB) Partition: misc, [0000B8283000 - 0000B8383000], size: 000000100000 (1.00 MB) Partition: keystore, [0000B8383000 - 0000B8403000], size: 000000080000 (512. KB) Partition: config, [0000B8403000 - 0000B840B000], size: 000000008000 (32.0 KB) Partition: oem, [0000B840B000 - 0000B8C0B000], size: 000000800000 (8.00 MB) Partition: btui, [0000B8C0B000 - 0000B910B000], size: 000000500000 (5.00 MB) Partition: mota, [0000B910B000 - 0000B918B000], size: 000000080000 (512. KB) Partition: dip, [0000B918B000 - 0000B928B000], size: 000000100000 (1.00 MB) Partition: mdtp, [0000B928B000 - 0000BB28B000], size: 000002000000 (32.0 MB) Partition: syscfg, [0000BB28B000 - 0000BB30B000], size: 000000080000 (512. KB) Partition: mcfg, [0000BB30B000 - 0000BB70B000], size: 000000400000 (4.00 MB) Partition: apdp, [0000BB70B000 - 0000BB74B000], size: 000000040000 (256. KB) Partition: msadp, [0000BB74B000 - 0000BB78B000], size: 000000040000 (256. KB) Partition: dpo, [0000BB78B000 - 0000BB78D000], size: 000000002000 (8.00 KB) Partition: elabel, [0000BC000000 - 0000BD400000], size: 000001400000 (20.0 MB) Partition: userdata, [0000C0000000 - 000747BFBE00], size: 000687BFBE00 (26.1 GB) GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2127 mV CMD Active Level: 2506 mV EMMC Device Information : EMMC CID: 1501005158363341420945E2BC81C7AB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX63AB , HEX: 515836334142 , S/N: 45E2BC81 , rev. 0x09 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 6038 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63AB_45E2BC81_20211123_054500.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Operation: Read by vendor... Destination dir: D:\Nokia HMD Dump\Nokia 1.4\All Partiton\ Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2130 mV CMD Active Level: 2504 mV EMMC Device Information : EMMC CID: 1501005158363341420945E2BC81C7AB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX63AB , HEX: 515836334142 , S/N: 45E2BC81 , rev. 0x09 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 6038 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63AB_45E2BC81_20211123_054602.extcsd EMMC Init completed. Backup partition: 8xxx_msimage Address: 000000004400, size: 000003FFBC00 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2834.40 Kb/s 8xxx image is blank. Skipped XML-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: modem Address: 000004000000, size: 000005400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2836.92 Kb/s Partition name: DDR Address: 000009400000, size: 000000008000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2201.34 Kb/s Partition name: fsgcombine Address: 000009408000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2843.01 Kb/s Partition name: fsg Address: 000009808000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2849.34 Kb/s Partition name: sec Address: 000009988000, size: 000000004000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1873.15 Kb/s Partition name: aboot Address: 00000998C000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2833.20 Kb/s Partition name: abootbak Address: 000009A8C000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2847.21 Kb/s Partition name: dtbo Address: 000009B8C000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2848.99 Kb/s Partition name: dtbobak Address: 00000A38C000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2843.08 Kb/s Partition name: vbmeta Address: 00000AB8C000, size: 000000010000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2490.64 Kb/s Partition name: vbmetabak Address: 00000AB9C000, size: 000000010000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1113.36 Kb/s Partition name: boot Address: 00000ABAC000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2845.20 Kb/s Partition name: recovery Address: 00000CBAC000, size: 000003000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2845.12 Kb/s Partition name: devinfo Address: 00000FBAC000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2841.93 Kb/s Partition name: super Address: 00000FCAC000, size: 000099800000 eMMC switching to ROM1 Reading partition... Converting to SparseImage... Done reading partition. Read speed: 2835.66 Kb/s Partition name: vbmeta_system Address: 0000A94AC000, size: 000000010000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2538.72 Kb/s Partition name: limits Address: 0000A94BC000, size: 000000008000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2305.80 Kb/s Partition name: cmnlib Address: 0000A94C4000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2841.46 Kb/s Partition name: cmnlibbak Address: 0000A95C4000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2847.97 Kb/s Partition name: cmnlib64 Address: 0000A96C4000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2847.00 Kb/s Partition name: cmnlib64bak Address: 0000A97C4000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2850.87 Kb/s Partition name: keymaster Address: 0000A98C4000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2850.23 Kb/s Partition name: keymasterbak Address: 0000A9944000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2839.60 Kb/s Partition name: fsc Address: 0000AC000000, size: 000000000400 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 107.67 Kb/s Partition name: ssd Address: 0000AC001000, size: 000000002000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1473.20 Kb/s Partition name: sbl1 Address: 0000AC003000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2853.68 Kb/s Partition name: sbl1bak Address: 0000AC083000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2844.64 Kb/s Partition name: rpm Address: 0000AC103000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2839.61 Kb/s Partition name: rpmbak Address: 0000AC183000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2849.32 Kb/s Partition name: tz Address: 0000AC203000, size: 000000200000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2827.02 Kb/s Partition name: tzbak Address: 0000AC403000, size: 000000200000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2825.64 Kb/s Partition name: devcfg Address: 0000AC603000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2802.41 Kb/s Partition name: devcfgbak Address: 0000AC643000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2786.90 Kb/s Partition name: dsp Address: 0000AC683000, size: 000001000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2836.54 Kb/s Partition name: modemst1 Address: 0000AD683000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2850.26 Kb/s Partition name: modemst2 Address: 0000AD803000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2845.16 Kb/s Partition name: splash Address: 0000AD983000, size: 000000B00000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2843.22 Kb/s Partition name: cache Address: 0000AE483000, size: 000006E00000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2836.40 Kb/s Partition name: persist Address: 0000B5283000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2833.19 Kb/s Partition name: metadata Address: 0000B7283000, size: 000001000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2827.94 Kb/s Partition name: misc Address: 0000B8283000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2847.48 Kb/s Partition name: keystore Address: 0000B8383000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2846.14 Kb/s Partition name: config Address: 0000B8403000, size: 000000008000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1414.55 Kb/s Partition name: oem Address: 0000B840B000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2848.14 Kb/s Partition name: btui Address: 0000B8C0B000, size: 000000500000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2837.09 Kb/s Partition name: mota Address: 0000B910B000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2844.81 Kb/s Partition name: dip Address: 0000B918B000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2846.87 Kb/s Partition name: mdtp Address: 0000B928B000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2842.06 Kb/s Partition name: syscfg Address: 0000BB28B000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2846.53 Kb/s Partition name: mcfg Address: 0000BB30B000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2851.04 Kb/s Partition name: apdp Address: 0000BB70B000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2823.07 Kb/s Partition name: msadp Address: 0000BB74B000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2807.58 Kb/s Partition name: dpo Address: 0000BB78B000, size: 000000002000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1216.08 Kb/s Partition name: elabel Address: 0000BC000000, size: 000001400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2849.22 Kb/s All done time: [00:21:27:694] |
The Following 2 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
