01-26-2023, 15:59 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | nokia 1.4 unlocking Microsoft Windows 8.1 (64 bit) build 9600 (6.3.9600.17031) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = 0F00D01145720891 Card Serial = AA03CEFD EasyJTAG Box Firmware = 1.6300 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Setting frequence to 21 MHz CMD Pullup Level: 299 mV CMD Active Level: 2124 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 MHz CMD Pullup Level: 2072 mV CMD Active Level: 2629 mV EMMC Device Information : EMMC CID: 15010051583633414209BE28BC5EC744 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63AB , HEX: 515836334142 , S/N: BE28BC5E , rev. 0x09 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 56432 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63AB_BE28BC5E_20230126_172954.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB) Partition: DDR, [000009400000 - 000009408000], size: 000000008000 (32.0 KB) Partition: fsgcombine, [000009408000 - 000009808000], size: 000000400000 (4.00 MB) Partition: fsg, [000009808000 - 000009988000], size: 000000180000 (1.50 MB) Partition: sec, [000009988000 - 00000998C000], size: 000000004000 (16.0 KB) Partition: aboot, [00000998C000 - 000009A8C000], size: 000000100000 (1.00 MB) Partition: abootbak, [000009A8C000 - 000009B8C000], size: 000000100000 (1.00 MB) Partition: dtbo, [000009B8C000 - 00000A38C000], size: 000000800000 (8.00 MB) Partition: dtbobak, [00000A38C000 - 00000AB8C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [00000AB8C000 - 00000AB9C000], size: 000000010000 (64.0 KB) Partition: vbmetabak, [00000AB9C000 - 00000ABAC000], size: 000000010000 (64.0 KB) Partition: boot, [00000ABAC000 - 00000CBAC000], size: 000002000000 (32.0 MB) Partition: recovery, [00000CBAC000 - 00000FBAC000], size: 000003000000 (48.0 MB) Partition: devinfo, [00000FBAC000 - 00000FCAC000], size: 000000100000 (1.00 MB) Partition: super, [00000FCAC000 - 0000A94AC000], size: 000099800000 (2.40 GB) Partition: vbmeta_system, [0000A94AC000 - 0000A94BC000], size: 000000010000 (64.0 KB) Partition: limits, [0000A94BC000 - 0000A94C4000], size: 000000008000 (32.0 KB) Partition: cmnlib, [0000A94C4000 - 0000A95C4000], size: 000000100000 (1.00 MB) Partition: cmnlibbak, [0000A95C4000 - 0000A96C4000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [0000A96C4000 - 0000A97C4000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [0000A97C4000 - 0000A98C4000], size: 000000100000 (1.00 MB) Partition: keymaster, [0000A98C4000 - 0000A9944000], size: 000000080000 (512. KB) Partition: keymasterbak, [0000A9944000 - 0000A99C4000], size: 000000080000 (512. KB) Partition: fsc, [0000AC000000 - 0000AC000400], size: 000000000400 (1.00 KB) Partition: ssd, [0000AC001000 - 0000AC003000], size: 000000002000 (8.00 KB) Partition: sbl1, [0000AC003000 - 0000AC083000], size: 000000080000 (512. KB) Partition: sbl1bak, [0000AC083000 - 0000AC103000], size: 000000080000 (512. KB) Partition: rpm, [0000AC103000 - 0000AC183000], size: 000000080000 (512. KB) Partition: rpmbak, [0000AC183000 - 0000AC203000], size: 000000080000 (512. KB) Partition: tz, [0000AC203000 - 0000AC403000], size: 000000200000 (2.00 MB) Partition: tzbak, [0000AC403000 - 0000AC603000], size: 000000200000 (2.00 MB) Partition: devcfg, [0000AC603000 - 0000AC643000], size: 000000040000 (256. KB) Partition: devcfgbak, [0000AC643000 - 0000AC683000], size: 000000040000 (256. KB) Partition: dsp, [0000AC683000 - 0000AD683000], size: 000001000000 (16.0 MB) Partition: modemst1, [0000AD683000 - 0000AD803000], size: 000000180000 (1.50 MB) Partition: modemst2, [0000AD803000 - 0000AD983000], size: 000000180000 (1.50 MB) Partition: splash, [0000AD983000 - 0000AE483000], size: 000000B00000 (11.0 MB) Partition: cache, [0000AE483000 - 0000B5283000], size: 000006E00000 (110. MB) Partition: persist, [0000B5283000 - 0000B7283000], size: 000002000000 (32.0 MB) Partition: metadata, [0000B7283000 - 0000B8283000], size: 000001000000 (16.0 MB) Partition: misc, [0000B8283000 - 0000B8383000], size: 000000100000 (1.00 MB) Partition: keystore, [0000B8383000 - 0000B8403000], size: 000000080000 (512. KB) Partition: config, [0000B8403000 - 0000B840B000], size: 000000008000 (32.0 KB) Partition: oem, [0000B840B000 - 0000B8C0B000], size: 000000800000 (8.00 MB) Partition: btui, [0000B8C0B000 - 0000B910B000], size: 000000500000 (5.00 MB) Partition: mota, [0000B910B000 - 0000B918B000], size: 000000080000 (512. KB) Partition: dip, [0000B918B000 - 0000B928B000], size: 000000100000 (1.00 MB) Partition: mdtp, [0000B928B000 - 0000BB28B000], size: 000002000000 (32.0 MB) Partition: syscfg, [0000BB28B000 - 0000BB30B000], size: 000000080000 (512. KB) Partition: mcfg, [0000BB30B000 - 0000BB70B000], size: 000000400000 (4.00 MB) Partition: apdp, [0000BB70B000 - 0000BB74B000], size: 000000040000 (256. KB) Partition: msadp, [0000BB74B000 - 0000BB78B000], size: 000000040000 (256. KB) Partition: dpo, [0000BB78B000 - 0000BB78D000], size: 000000002000 (8.00 KB) Partition: elabel, [0000BC000000 - 0000BD400000], size: 000001400000 (20.0 MB) Partition: userdata, [0000C0000000 - 000747BFBE00], size: 000687BFBE00 (26.1 GB) GPT header successfully parsed Get firmware version Firmware info not found Setting frequence to 21 MHz CMD Pullup Level: 2072 mV CMD Active Level: 2701 mV EMMC Device Information : EMMC CID: 15010051583633414209BE28BC5EC744 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63AB , HEX: 515836334142 , S/N: BE28BC5E , rev. 0x09 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 56432 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63AB_BE28BC5E_20230126_173037.extcsd EMMC Init completed. Opening file: QX63AB_rawprogram0.xml The size of the last section has been updated Setting frequence to 21 MHz CMD Pullup Level: 2072 mV CMD Active Level: 2701 mV EMMC Device Information : EMMC CID: 15010051583633414209BE28BC5EC744 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX63AB , HEX: 515836334142 , S/N: BE28BC5E , rev. 0x09 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2020 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 56432 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX63AB_BE28BC5E_20230126_173053.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 GPT-partitioning done Partition name: devinfo Filename: devinfo.bin , Offset: 00000FBAC000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 311.56 KB/s Partition name: keystore Filename: keystore.bin , Offset: 0000B8383000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 480.04 KB/s Partition name: config Filename: config.bin , Offset: 0000B8403000 , filesize: 32768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 331.61 KB/s Partition name: oem Filename: oem.bin , Offset: 0000B840B000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 481.67 KB/s Partition name: mota Filename: mota.bin , Offset: 0000B910B000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 478.97 KB/s Partition name: dip Filename: dip.bin , Offset: 0000B918B000 , filesize: 1048576 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 480.25 KB/s Partition name: syscfg Filename: syscfg.bin , Offset: 0000BB28B000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 479.61 KB/s Partition name: mcfg Filename: mcfg.bin , Offset: 0000BB30B000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 481.40 KB/s Partition name: apdp Filename: apdp.bin , Offset: 0000BB70B000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 478.59 KB/s Partition name: msadp Filename: msadp.bin , Offset: 0000BB74B000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 478.00 KB/s Partition name: dpo Filename: dpo.bin , Offset: 0000BB78B000 , filesize: 8192 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 189.36 KB/s Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:01:33:332] |
