01-10-2022, 09:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | NOKIA 5.4 │TA-1325│QC SM6115 SD662│HARD RESET│SCREEN│FRP LOCK REMOVE│FIRMWARE Backup Code: Z3X EasyJtag EMMC File Manager v 1.20 at 19/03/2021 Started.. Box API Version: 3403 FS Driver Version: 04012021 SQLite Version: 3.34.0 FSCK Engine Version: 04012021 ESE DB Version: 04012021 System Util Version: 04012021 System: Windows NT 6.1 (Build 7601, Service Pack 1) / 64 BIT CPU: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz Total RAM: 7.70 GB System Date: 1/4/2022 11:19:03 PM Official Site: http://efm.easy-jtag.com/ Telegram Support: https://t.me/z3xefm FRP Apps: http://efm.easy-jtag.com/frp/ Z3X Card Serial: AA42F346 EasyJtag Plus Box Found at: COM33 EasyJtag Plus Box Firmware: 2.53.1 Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 1800 mV Scanner Thread Created.. Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/36MHz/1BIT EasyJtag Plus Box Found! Result: 0/OK CMD Pullup Level: 2045 mV CMD Active Level: 2257 mV EasyJtag Plus S/N: 2782D60F58665178 EasyJtag Plus Box FirmWare: 2.53.1 Box Bus Width = 1 BIT Box Hardware = EasyJtag 2nd Generation Search Emmc Chip... EMMC Chip Found! 0/OK EMMC CID: 90014A68444561503303105E73D4A7F3 EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 EMMC VENDOR: SKHYNIX EMMC NAME: hDEaP3 EMMC DATE: 10/2020 EMMC SERIAL: 105E73D4 EMMC REVISION: 03 EMMC ROM1 Size: 244285440 Block(s)/119280 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 32768 Block(s)/16384 KB EMMC RPMB Counter: 17038, State: Dirty EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC SLC Life Time: 0x00 -> Not Defined EMMC Boot Config: 0x00/0x00/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 92 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: XBL_A [000004000000 - 000000380000] Size: 3.50 MB GPT: XBL_B [000004380000 - 000000380000] Size: 3.50 MB GPT: XBL_CONFIG_A [000008000000 - 000000020000] Size: 128.00 KB GPT: XBL_CONFIG_B [000008020000 - 000000020000] Size: 128.00 KB GPT: TZ_A [00000C000000 - 000000400000] Size: 4.00 MB GPT: TZ_B [000010000000 - 000000400000] Size: 4.00 MB GPT: RPM_A [000014000000 - 000000080000] Size: 512.00 KB GPT: RPM_B [000018000000 - 000000080000] Size: 512.00 KB GPT: HYP_A [00001C000000 - 000000080000] Size: 512.00 KB GPT: HYP_B [000020000000 - 000000080000] Size: 512.00 KB GPT: KEYMASTER_A [000024000000 - 000000080000] Size: 512.00 KB GPT: KEYMASTER_B [000024080000 - 000000080000] Size: 512.00 KB GPT: CMNLIB_A [000024100000 - 000000080000] Size: 512.00 KB GPT: CMNLIB64_A [000024180000 - 000000080000] Size: 512.00 KB GPT: CMNLIB_B [000024200000 - 000000080000] Size: 512.00 KB GPT: CMNLIB64_B [000024280000 - 000000080000] Size: 512.00 KB GPT: MDTPSECAPP_A [000024300000 - 000000400000] Size: 4.00 MB GPT: MDTPSECAPP_B [000024700000 - 000000400000] Size: 4.00 MB GPT: MDTP_A [000024B00000 - 000002000000] Size: 32.00 MB GPT: MDTP_B [000026B00000 - 000002000000] Size: 32.00 MB GPT: MODEM_A [000028B00000 - 00000B400000] Size: 180.00 MB GPT: MODEM_B [000033F00000 - 00000B400000] Size: 180.00 MB GPT: DSP_A [00003F300000 - 000002000000] Size: 32.00 MB GPT: DSP_B [000041300000 - 000002000000] Size: 32.00 MB GPT: ABL_A [000043300000 - 000000100000] Size: 1.00 MB GPT: ABL_B [000043400000 - 000000100000] Size: 1.00 MB GPT: DDR [000043500000 - 000000100000] Size: 1.00 MB GPT: BLUETOOTH_A [000043600000 - 000000100000] Size: 1.00 MB GPT: BLUETOOTH_B [000043700000 - 000000100000] Size: 1.00 MB GPT: SSD [000044000000 - 000000002000] Size: 8.00 KB GPT: IMAGEFV_A [000044002000 - 000000200000] Size: 2.00 MB GPT: IMAGEFV_B [000044202000 - 000000200000] Size: 2.00 MB GPT: UEFISECAPP_A [000044402000 - 000000200000] Size: 2.00 MB GPT: UEFISECAPP_B [000044602000 - 000000200000] Size: 2.00 MB GPT: PERSIST [000044802000 - 000002000000] Size: 32.00 MB GPT: METADATA [000046802000 - 000001000000] Size: 16.00 MB GPT: MISC [000047802000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [000047902000 - 000000080000] Size: 512.00 KB GPT: DEVCFG_A [000047982000 - 000000020000] Size: 128.00 KB GPT: DEVCFG_B [0000479A2000 - 000000020000] Size: 128.00 KB GPT: FEATENABLER_A [0000479C2000 - 000000020000] Size: 128.00 KB GPT: FEATENABLER_B [0000479E2000 - 000000020000] Size: 128.00 KB GPT: QUPFW_A [000047A02000 - 000000010000] Size: 64.00 KB GPT: QUPFW_B [000047A12000 - 000000010000] Size: 64.00 KB GPT: FRP [000047A22000 - 000000080000] Size: 512.00 KB GPT: RAWDUMP [000047AA2000 - 000008000000] Size: 128.00 MB GPT: DIP [000050000000 - 000000100000] Size: 1.00 MB GPT: APDP [000054000000 - 000000040000] Size: 256.00 KB GPT: SPUNVM [000054040000 - 000000800000] Size: 8.00 MB GPT: SPLASH_A [000054840000 - 0000020A4000] Size: 32.64 MB GPT: SPLASH_B [0000568E4000 - 0000020A4000] Size: 32.64 MB GPT: LIMITS [00005C000000 - 000000001000] Size: 4.00 KB GPT: TOOLSFV [00005C001000 - 000000100000] Size: 1.00 MB GPT: LOGFS [000060000000 - 000000800000] Size: 8.00 MB GPT: CATELOADER [000060800000 - 000000200000] Size: 2.00 MB GPT: LOGDUMP [000060A00000 - 000004000000] Size: 64.00 MB GPT: VBMETA_A [000068000000 - 000000010000] Size: 64.00 KB GPT: VBMETA_B [000068010000 - 000000010000] Size: 64.00 KB GPT: STORSEC [000068020000 - 000000020000] Size: 128.00 KB GPT: MULTIIMGOEM [000068040000 - 000000008000] Size: 32.00 KB GPT: MULTIIMGQTI [000068048000 - 000000008000] Size: 32.00 KB GPT: SECDATA [000068050000 - 000000006400] Size: 25.00 KB GPT: CATEFV [000068057000 - 000000080000] Size: 512.00 KB GPT: CATECONTENTFV [0000680D7000 - 000000100000] Size: 1.00 MB GPT: UEFIVARSTORE [0000681D7000 - 000000080000] Size: 512.00 KB GPT: MODEMST1 [00006C000000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [00006C200000 - 000000200000] Size: 2.00 MB GPT: FSG [000070000000 - 000000200000] Size: 2.00 MB GPT: FSC [000074000000 - 000000020000] Size: 128.00 KB GPT: MSADP [000074020000 - 000000040000] Size: 256.00 KB GPT: PROINFO [000074060000 - 000000100000] Size: 1.00 MB GPT: FSGALL [000074160000 - 000000400000] Size: 4.00 MB GPT: PRIVATE [000074560000 - 000000100000] Size: 1.00 MB GPT: RESERVE [000074660000 - 000000100000] Size: 1.00 MB GPT: RESERVE2 [000074760000 - 000000100000] Size: 1.00 MB GPT: DEVINFO [000078000000 - 000000001000] Size: 4.00 KB GPT: ELABEL_A [00007C000000 - 000005000000] Size: 80.00 MB GPT: ELABEL_B [000081000000 - 000005000000] Size: 80.00 MB GPT: SIMLOCK [000086000000 - 000004000000] Size: 64.00 MB GPT: IMEILOCK [00008A000000 - 000004000000] Size: 64.00 MB GPT: BOOT_A [00008E000000 - 000006000000] Size: 96.00 MB GPT: BOOT_B [000094000000 - 000006000000] Size: 96.00 MB GPT: DTBO_A [00009A000000 - 000001800000] Size: 24.00 MB GPT: DTBO_B [00009B800000 - 000001800000] Size: 24.00 MB GPT: VBMETA_SYSTEM_A [0000A0000000 - 000000010000] Size: 64.00 KB GPT: VBMETA_SYSTEM_B [0000A0010000 - 000000010000] Size: 64.00 KB GPT: RECOVERY_A [0000A0020000 - 000006000000] Size: 96.00 MB GPT: RECOVERY_B [0000A6020000 - 000006000000] Size: 96.00 MB GPT: SUPER [0000B0000000 - 000200000000] Size: 8.00 GB GPT: USERDATA [0002B0000000 - 001A6EFFBE00] Size: 105.73 GB GPT: BACKUP_GPT [001D1EFFBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Reading Initial Data. Please Wait.. Partition #22 - [MODEM_A] mount as [/MODEM_A] -> 180.00 MB, Type: FAT16 Partition #23 - [MODEM_B] mount as [/MODEM_B] -> 180.00 MB, Type: FAT16 Partition #24 - [DSP_A] mount as [/dev_23] -> 32.00 MB, Type: EXT4 Partition #25 - [DSP_B] mount as [/dev_24] -> 32.00 MB, Type: EXT4 Partition #29 - [BLUETOOTH_A] mount as [/BLUETOOTH_A] -> 1.00 MB, Type: FAT16 Partition #30 - [BLUETOOTH_B] mount as [/BLUETOOTH_B] -> 1.00 MB, Type: FAT16 Partition #36 - [PERSIST] mount as [/mnt/vendor/persist] -> 32.00 MB, Type: EXT4 Partition #37 - [METADATA] mount as [/metadata] -> 16.00 MB, Type: EXT4 Partition #55 - [LOGFS] mount as [/LOGFS] -> 8.00 MB, Type: FAT12 Partition #78 - [ELABEL_A] mount as [/elabel] -> 80.00 MB, Type: EXT4 Partition #79 - [ELABEL_B] mount as [/elabel] -> 80.00 MB, Type: EXT4 EmptyCheck: EMPTY -> ROM_1 -> Part #14 - [CMNLIB_A] EMPTY -> ROM_1 -> Part #15 - [CMNLIB64_A] EMPTY -> ROM_1 -> Part #16 - [CMNLIB_B] EMPTY -> ROM_1 -> Part #17 - [CMNLIB64_B] EMPTY -> ROM_1 -> Part #18 - [MDTPSECAPP_A] EMPTY -> ROM_1 -> Part #19 - [MDTPSECAPP_B] EMPTY -> ROM_1 -> Part #20 - [MDTP_A] EMPTY -> ROM_1 -> Part #21 - [MDTP_B] EMPTY -> ROM_1 -> Part #31 - [SSD] EMPTY -> ROM_1 -> Part #38 - [MISC] EMPTY -> ROM_1 -> Part #39 - [KEYSTORE] EMPTY -> ROM_1 -> Part #46 - [FRP] EMPTY -> ROM_1 -> Part #47 - [RAWDUMP] EMPTY -> ROM_1 -> Part #48 - [DIP] EMPTY -> ROM_1 -> Part #50 - [SPUNVM] EMPTY -> ROM_1 -> Part #51 - [SPLASH_A] EMPTY -> ROM_1 -> Part #52 - [SPLASH_B] EMPTY -> ROM_1 -> Part #53 - [LIMITS] EMPTY -> ROM_1 -> Part #54 - [TOOLSFV] EMPTY -> ROM_1 -> Part #56 - [CATELOADER] EMPTY -> ROM_1 -> Part #57 - [LOGDUMP] EMPTY -> ROM_1 -> Part #62 - [MULTIIMGQTI] EMPTY -> ROM_1 -> Part #64 - [CATEFV] EMPTY -> ROM_1 -> Part #65 - [CATECONTENTFV] EMPTY -> ROM_1 -> Part #66 - [UEFIVARSTORE] EMPTY -> ROM_1 -> Part #70 - [FSC] EMPTY -> ROM_1 -> Part #71 - [MSADP] EMPTY -> ROM_1 -> Part #75 - [RESERVE] EMPTY -> ROM_1 -> Part #76 - [RESERVE2] EMPTY -> ROM_1 -> Part #77 - [DEVINFO] EMPTY -> ROM_1 -> Part #80 - [SIMLOCK] EMPTY -> ROM_1 -> Part #91 - [USERDATA] EmptyCheck: Done Scanner Thread Terminated Elapsed: 00:00:08:975 Found 92 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2048 mV CMD Active Level: 2255 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1011111111101111 Bus Mode: 1BIT Operation Done: [Init Engine], Elapsed: 00:00:01:543 ISP PIN OUT Credit Goes To OG Poster. |
The Following 7 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
