11-08-2020, 14:35 | #1 (permalink) |
Crazy Poster Join Date: Dec 2014 Location: Walling,syangja,nepal
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | nokia 6.1 plus emmc dead i want to reprogram this emmc i don't know emmc name i am new user if jtag Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 02000053444D30333290FFFFFFFF29BD EMMC CSD: 8C0F002A015981E9B6D9FC1F8A4040AB EMMC Manufacture : , EMMC NAME: SDM032 , HEX: 53444D303332 , S/N: FFFFFFFF , rev. 0x90 EMMC Manufacture ID: 0x02 , OEM ID: 0x00 , Device Type: Device (removable) , Date: 2/2006 EMMC ROM 1 (Main User Data) Capacity: 30 MB (000001E9C000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x00 Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: SDM032_FFFFFFFF_20201108_191720.extcsd EMMC Init completed. eMMC are unusable. |
11-08-2020, 16:31 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
11-08-2020, 18:27 | #3 (permalink) |
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | I know sir But how to find emmc combility My english is not good so o trying to explain my problem I don't know emmc number to find compability how can i Find emmc number then i will search on jtag |
11-08-2020, 18:30 | #4 (permalink) | |
I doun't know what eMMC you have and compatobolity for it If you use mtk device - you need use preloader parser at EasyJTAG Plus software - Utility - Preloader parser to view preloader known eMMC CID | |
11-09-2020, 05:22 | #5 (permalink) |
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | It's a qualcomm cpu And sandisk emmc How to know emmc name any tips or trick |
11-09-2020, 11:45 | #7 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | if you doun't good know English - use http://translate.google.com |
The Following User Says Thank You to layder For This Useful Post: |
11-09-2020, 17:53 | #8 (permalink) |
Member: 2308721 Status: Offline Sonork: [email protected] Thanks Meter: 12 | Ok thank you sir. I am new on so don't know about it. |
