12-04-2020, 12:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Write Problem from another spi chip Code: Auto identification. Info: Found Winbond flash chip "W25Q32.V" (4096 kB, SPI) on easyjtag2_spi. Info: Device is auto selected and confirmed. Code: Check Programmer Action: Check Device Action: Action start: Info: Unlock flash. Action: Read from flash. Info: Reading flash... done. Info: Action is SUCCESSFUL. Info: Time spent 0:09 Code: Check Programmer Action: Check Device Action: Action start: Info: Unlock flash. Info: Reading flash chip contents. Info: Reading flash... done. Info: Reading contents from file. Info: Chip content is identical to the requested image. Info: Action is SUCCESSFUL. Info: Time spent 0:09 Code: Check Programmer Action: Check Device Action: Action start: Info: Unlock flash. Info: Reading flash chip contents. Info: Reading flash... done. Info: Reading contents from file. Action: Write to flash. Info: Erasing and writing flash chip... Trying erase function 0... FAILED at 0x00000000! Expected=0xff, Found=0xe0, failed byte count from 0x00000000-0x00000fff: 0xff6 Error: ERASE FAILED! Info: Looking for another erase function. Error: FAILED at 0x00000000! Expected=0xff, Found=0xe0, failed byte count from 0x00000000-0x00007fff: 0x7fbc Error: ERASE FAILED! Info: Looking for another erase function. Error: FAILED at 0x00000000! Expected=0xff, Found=0xe0, failed byte count from 0x00000000-0x0000ffff: 0xff37 Error: ERASE FAILED! Info: Looking for another erase function. Error: FAILED at 0x00000000! Expected=0xff, Found=0xe0, failed byte count from 0x00000000-0x003fffff: 0x31610e Error: ERASE FAILED! Info: Looking for another erase function. Error: FAILED at 0x00000000! Expected=0xff, Found=0xe0, failed byte count from 0x00000000-0x003fffff: 0x31610e Error: ERASE FAILED! Info: Looking for another erase function. Info: Looking for another erase function. Info: Looking for another erase function. Info: No usable erase functions left. Error: FAILED! Error: Write failed. Info: Checking if anything has changed. Info: Reading current flash chip contents. Good, writing to the flash chip apparently didn't do anything. Error: Unexpected exception...Action is FAILED. Info: Time spent 0:38 |
