Old 12-02-2020, 12:30   #1 (permalink)
Member: 1269161
Thanks Meter: 119
help in oppo a31 2020 cph2015 stuck in mediatek usb port !!!
hi
any help to repair this oppo cph2015 after reset password i have phone dead and connected in usb show mediatek usb port
info with emmc :
Z3X EasyJtag Software ver. 3.7.0.11
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 04040B05853D1B89, ,FW Ver.: 01.63
CMD Pullup Level:2000 mV
CMD Active Level:2619 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 15010044483644414202C236685457C2
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 05/2020  Rev.0x2
eMMC NAME: DH6DAB , S/N: 3258345556
eMMC NAME (HEX): 444836444142
EMMC ROM1 (Main User Data)   Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 735 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x02 , width 8bits  , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: DH6DAB_3258345556_20201202_1221.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0081000000 (6.0GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 387072
Short Android info:
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x021C800000 (49.738GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000     ................................;
Done.
i have rom in ofp
thx
Old 12-02-2020, 16:23   #2 (permalink)
Member: 1269161
Thanks Meter: 119
how flash oppo cph2015 via isp pinout?
hi
any help to flash oppo a31 2020 cph2015(Mediatek MT6765V/CB Helio P35 ) via isp pinout with easyjtag or easyjtagplus !!
or flash only boot file !
i have rom in .ofp
thx
plz admin delete first threat thx
Old 12-02-2020, 17:21   #3 (permalink)
Member: 1269161
Thanks Meter: 119
this is info read by emmc file manager
Source: EasyJtag Port [EMMC/SD/MMC]
Generation: PMT [MTK GENERIC]
Box Voltage set to: 2800 mV
Scanner Thread Created..
Config: 1011111111101111
Setup HiPower CLK: OFF
Connecting To EasyJtag Box: 2800mV/21MHz/1BIT
EasyJtag Box Found! Result: 0/OK
 CMD Pullup Level: 1990 mV
 CMD Active Level: 2557 mV
EasyJtag S/N: 04040B05853D1B89
EasyJtag Box FirmWare: 1.63
Box Bus Width = 1 BIT
Box Hardware  = EasyJtag 1st Generation
Search EMMC Chip...
EMMC Chip Found! 0/OK
EMMC CID: 15010044483644414202C236685457C2
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC VENDOR: SAMSUNG
EMMC NAME: DH6DAB
EMMC SERIAL: C2366854
EMMC REVISION: 02
EMMC ROM1 Size: 122142720 Block(s)/59640 MB
EMMC ROM2/3 Size: 8192 Block(s)/4096 KB
EMMC RPMB Size: 32768 Block(s)/16384 KB
EMMC RPMB Counter: 735
EMMC RPMB Answer: 0/OK
Switch To ROM1 Part: 0/OK
EMMC REV: 1.8 (for MMC v5.1)
EMMC VER: MMC 5.1
EMMC DEV Life Time: 0x01 -> Normal
EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used
EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used
EMMC Boot Config: 0x00/0x02/0x01
ExtCSD Automatically Saved..
Scanning Data From EMMC. Please wait..
Scanning GUID Partition Table from ROM1
GUID Partition Table is Found. Max Parts: 128
GPT: GPT   [000000000000 - 000000004400] Size: 17,00 KB
GPT: BOOT_PARA   [000000008000 - 000000100000] Size: 1,00 MB
GPT: RECOVERY   [000000108000 - 000002000000] Size: 32,00 MB
GPT: PARA   [000002108000 - 000000080000] Size: 512,00 KB
GPT: OPPORESERVE1   [000002188000 - 000000800000] Size: 8,00 MB
GPT: OPPORESERVE2   [000002988000 - 000004000000] Size: 64,00 MB
GPT: OPPORESERVE3   [000006988000 - 000004000000] Size: 64,00 MB
GPT: OPPO_CUSTOM   [00000A988000 - 000000100000] Size: 1,00 MB
GPT: EXPDB   [00000AA88000 - 000001400000] Size: 20,00 MB
GPT: FRP   [00000BE88000 - 000000100000] Size: 1,00 MB
GPT: NVCFG   [00000BF88000 - 000002000000] Size: 32,00 MB
GPT: NVDATA   [00000DF88000 - 000004000000] Size: 64,00 MB
GPT: METADATA   [000011F88000 - 000002000000] Size: 32,00 MB
GPT: PROTECT1   [000013F88000 - 000000800000] Size: 8,00 MB
GPT: PROTECT2   [000014788000 - 000000878000] Size: 8,47 MB
GPT: SECCFG   [000015000000 - 000000800000] Size: 8,00 MB
GPT: PERSIST   [000015800000 - 000003000000] Size: 48,00 MB
GPT: SEC1   [000018800000 - 000000200000] Size: 2,00 MB
GPT: PROINFO   [000018A00000 - 000000300000] Size: 3,00 MB
GPT: MD1IMG   [000018D00000 - 000006400000] Size: 100,00 MB
GPT: SPMFW   [00001F100000 - 000000100000] Size: 1,00 MB
GPT: SCP1   [00001F200000 - 000000100000] Size: 1,00 MB
GPT: SCP2   [00001F300000 - 000000100000] Size: 1,00 MB
GPT: SSPM_1   [00001F400000 - 000000100000] Size: 1,00 MB
GPT: SSPM_2   [00001F500000 - 000000100000] Size: 1,00 MB
GPT: GZ1   [00001F600000 - 000001000000] Size: 16,00 MB
GPT: GZ2   [000020600000 - 000001000000] Size: 16,00 MB
GPT: NVRAM   [000021600000 - 000004000000] Size: 64,00 MB
GPT: LK   [000025600000 - 000000500000] Size: 5,00 MB
GPT: LK2   [000025B00000 - 000000500000] Size: 5,00 MB
GPT: BOOT   [000026000000 - 000002000000] Size: 32,00 MB
GPT: LOGO   [000028000000 - 000001000000] Size: 16,00 MB
GPT: DTBO   [000029000000 - 000001000000] Size: 16,00 MB
GPT: TEE1   [00002A000000 - 000000500000] Size: 5,00 MB
GPT: TEE2   [00002A500000 - 000000B00000] Size: 11,00 MB
GPT: ODM   [00002B000000 - 000010000000] Size: 256,00 MB
GPT: VENDOR   [00003B000000 - 000046000000] Size: 1,09 GB
GPT: SYSTEM   [000081000000 - 000180000000] Size: 6,00 GB
GPT: VBMETA   [000201000000 - 000000800000] Size: 8,00 MB
GPT: CACHE   [000201800000 - 00001B000000] Size: 432,00 MB
GPT: USERDATA   [00021C800000 - 000C6F4FBE00] Size: 49,74 GB
GPT: OTP   [000E8BCFBE00 - 000002B00000] Size: 43,00 MB
GPT: FLASHINFO   [000E8E7FBE00 - 000001000000] Size: 16,00 MB
GPT: BACKUP_GPT   [000E8F7FBE00 - 000000004200] Size: 16,50 KB
Reading Table Completed
Scanning GUID Partition Table from ROM2
GPT Signature Not Found. Break..
Scanning GUID Partition Table from ROM3
Partition #9   mount as [/mnt/vendor/opporeserve] -> 64,00 MB
Partition #14   mount as [/mnt/vendor/nvcfg] -> 32,00 MB
Partition #15   mount as [/mnt/vendor/nvdata] -> 64,00 MB
Partition #17   mount as [/mnt/vendor/protect_f] -> 8,00 MB
Partition #18   mount as [/mnt/vendor/protect_s] -> 8,47 MB
Partition #20   mount as [/mnt/vendor/persist] -> 48,00 MB
Partition #39   mount as [/dev_39] -> 256,00 MB
Partition #40   mount as [/dev_40] -> 1,09 GB
Partition #41   mount as [/dev_41] -> 6,00 GB
EmptyCheck:
 EMPTY -> #11 - [EXPDB]
 EMPTY -> #12 - [FRP]
 EMPTY -> #15 - [METADATA]
 EMPTY -> #20 - [SEC1]
 EMPTY -> #28 - [GZ1]
 EMPTY -> #29 - [GZ2]
 EMPTY -> #42 - [CACHE]
 EMPTY -> #43 - [USERDATA]
 EMPTY -> #44 - [OTP]
EmptyCheck: Done
Android Info:
Platform        = mt6765
Android Info:
Vendor          = OPPO
CPU ABI         = arm64-v8a
Android Version = 9
Security Patch  = 2020-06-05
Android Info:
Brand           = OPPO
Device          = OP4C7D
Model           = CPH2015
Product         = CPH2015
Firm Version    = CPH2015EX_11_A.37
Inc. Version    = 1591774286
Firm Date       = Wed Jun 10 15:31:26 CST 2020
OPPO Name       = OPPO A31
Scanner Thread Terminated
Elapsed: 00:00:23:300
Found 47 Partition(s)..
Scan Done. Init Main Engine...
Resetting EasyJtag Box. Wait..
 CMD Pullup Level: 2000 mV
Reader Engine Initialized.. 0/OK
 Operation Done: [Init Engine], Elapsed: 00:00:02:052
and this is info of emmc
Read Emmc Info..
EMMC CID             : 15010044483644414202C236685457C2
EMMC CSD             : D02701320F5903FFF6DBFFEF8E40400C
EMMC Vendor ID       : 0x15
EMMC Vendor          : SAMSUNG
EMMC Name            : DH6DAB
EMMC Name HEX        : 444836444142
EMMC S/N             : C2366854
EMMC Revision        : 0x02
EMMC OEM ID          : 0x00
EMMC Dev Type        : BGA (Discrete embedded)
EMMC Version         : MMC 5.1
EMMC Date            : 5/2020
Temp WR Protect      : No
Perm WR Protect      : No
EMMC ROM 1 Size      : 59640 MB (0x000E8F800000)
EMMC ROM 2/3 Size    : 4096 KB (0x000000400000)
EMMC RPMB Size       : 16384 KB (0x000001000000)
EXTCSD REV           : Revision 1.8 (for MMC v5.1)
EMMC Boot Config     : 0x00/0x02/0x01
[PARTITION_CONFIG]   : 0x00
[PARTITION_ACCESS]   : No access to boot partition
[PARTITION_ENABLE]   : Device not boot enabled
[BOOT_ACK]           : No
[BOOT_BUS_WIDTH]     : x8 (sdr/ddr) bus width
H/W Reset Function   : 0x01, RST_n signal is permanently enabled
Partition Features   : 0x07
[PART SET_COMPLETED] : 0x00
Min GPx Size         : 8,00 MB
EMMC DEV Life Time   : 0x01 -> Normal
EMMC MLC Life Time   : 0x01 -> 0% - 10% Life Time Used
EMMC SLC Life Time   : 0x01 -> 0% - 10% Life Time Used
i think the problem is in red info !!
Old 12-02-2020, 21:23   #4 (permalink)
Member: 2465783
Thanks Meter: 49
Try write ext_csd backup.
The Following User Says Thank You to thedgd For This Useful Post:
Old 12-03-2020, 08:20   #5 (permalink)
Member: 1269161
Thanks Meter: 119
same think after write extcsd backup !
any help with extcsd from another phone !
thx
Old 12-03-2020, 10:17   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
MTK boot config you can set via emmc tool shuite (easyjtag plus software) via preset
Page generated in 0.18672 seconds with 8 queries
