07-17-2019, 10:58 | #1 (permalink) | ||
Freak Poster Join Date: Feb 2004 Location: Malaysia Age: 38
Member: 55800 Status: Offline Thanks Meter: 9 | Not Solve - EasyJtag Tool Unable To Detect EMMC THIS IS FROM EasyJtag Plus Quote:
but , problem still occured all the time . i have to restart countless time , reinstall . it works again , and it will not work again after sometime . i have 2 emmc reader so i dont think is emmc reader problems. it has been bothering me for days. anyone know why ? it actually happens after the new box firmware , can we roll back to try again ? | ||
07-17-2019, 18:12 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
it''s update box firmware | |
The Following 4 Users Say Thank You to layder For This Useful Post: |
07-18-2019, 08:48 | #4 (permalink) | |
try to install 3.6.1.13 http://forum.gsmhosting.com/vbb/f672.../#post13740311 | |
07-18-2019, 10:29 | #5 (permalink) | |
Member: 55800 Status: Offline Thanks Meter: 9 | Quote:
07-18-2019, 17:27 | #9 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | I doun't know what is a "easyjtag pro" but best way to check connection - check contacts and wires. if you work at board repair - you need know, how to check voltages at soket and mechanical and electric sokets components Last edited by layder; 07-18-2019 at 20:59. |
07-20-2019, 07:38 | #10 (permalink) | |
sometime is works . sometime it just never work. i dont understand what makes it works suddenly and once it doesnt work . it never works all the way . sometime i plug in and out many times to makes it works again . i try a few IC's , Different Socket 221 as well ... i dont know how to check emmc power at socket . | |
07-20-2019, 07:41 | #11 (permalink) | |
when it works , even bad ic will read at least . if i were to plug out the USB socket and put back once again , it might not work already . i even change a few USB cable . even PC , Win 32bit or Win 64bit . its works perfect and i never encounter this error before firmware upgrade .( i mean much earlier than 2.46 ) so i not sure if firmware related or not . | |
07-22-2019, 13:44 | #13 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 44
Member: 71526 Status: Offline Thanks Meter: 48 | I'm to facing this problem. Moorc U-socket , box easyjtag plus. When using c:\...\easyjtagplus\ "eMMC_tool.exe" - software detects emmc and working well. When I open c:\..\easyjtag\ "EasyJtag.exe" software say taht uses gen2 pinout, but does not detect emmc. (scan detects only clk pin) I have tried to select old box pinout from menu , then connect Moorc U-socket adapter "Easy Jtag In" port to box and connect external power from USB - this configuration connects emmc , but only one byte bus. I think that EasyJtag software not adapted to work with easyJtag plus interfaces (Does not powering adapter from box or smth) |
The Following User Says Thank You to ShadowmanX For This Useful Post: |
07-22-2019, 15:50 | #14 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | hehe old z3x easy jtag image Last edited by layder; 07-23-2019 at 17:27. Reason: i have mistake and edit user post instead of my post |
07-22-2019, 15:57 | #15 (permalink) | |
see http://forum.gsmhosting.com/vbb/f672...dates-2611607/ fot it (3.6.1.9, 3.6.1.13) | |
