Old 06-23-2020, 03:22   #1 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 603
Note 10+ sm-n975f cannot programm
HI DEAR TEAM I HAVE IN HANDS SAMSUNG NOTE 10 PLUS WITH SOME KIND OF MDM
I NEED TO RESET AND DELETE SOME PARTITIONS FOR MAKE THE JOB
I AM USING IC FRIENDS SOCKET AND THE BGA SEEMS TO BE A BGA 153 UFS 3.0 THE UFS PACKAGE IS " KLUEG8UHDB-C2D1 "
CAN YOU CONFIRM IF BGA TYPE IS ALREADY SUPPORTED CAUSE I HAVE
Can't open link, Code: -507, Reason: UIC: Link initialization fail WHEN TRY TO READ / WRITE
Old 06-24-2020, 07:16   #2 (permalink)
Member: 103024
Thanks Meter: 603
no answer from support , whats going on ?
Old 06-24-2020, 11:14   #3 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,173
Hello, this chip is supprted. But seems something bad with UFS link.
For more clear understanding of problem could you provide full log, including box firmware and software version ?
Old 06-29-2020, 10:47   #4 (permalink)
Member: 1654760
Thanks Meter: 21
EasyJtag v3.7.0.11 cannot connect via IPS Note 10 N975F
Pls help, EasyJtag v3.7.0.11 cannot connect via IPS Note 10 N975F
Old 06-29-2020, 11:18   #5 (permalink)
Member: 1972033
Thanks Meter: 28
have u tried with easy tool plus
Old 06-29-2020, 12:46   #6 (permalink)
Member: 1654760
Thanks Meter: 21
same problem bro .
Old 06-29-2020, 16:00   #7 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,417
Easy JTAG plus 2.51 firmware is speed optimized firmware.
May be Moorc socket have problem with it
Try to this patch to Moork sockets
it's my photo
https://www.facebook.com/Mipitester/...pe=3&__tn__=-R
Old 06-30-2020, 03:58   #8 (permalink)
Member: 103024
Thanks Meter: 603
the complete log is on my first post , nothing more happend , just
i will try tomorrow with the lastest update and lastest box firmware and let you know , thanks for answer
Old 06-30-2020, 04:24   #9 (permalink)
Member: 1654760
Thanks Meter: 21
it's my photo
no bro, IPS
not this
Old 06-30-2020, 09:43   #10 (permalink)
Member: 1654760
Thanks Meter: 21
@blang !!
Please provide downgrade version, or fix in the next version.
Old 06-30-2020, 11:14   #11 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,417
We make some fixes to UFS core at next version. It's may be help
If you want to use old Classic software - run it with "Left Ctrl" pressed
Old 07-01-2020, 00:40   #12 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,417
Moorc socket can't have correctly ISP pins
The Following User Says Thank You to layder For This Useful Post:
Old 07-01-2020, 10:39   #13 (permalink)
Member: 1654760
Thanks Meter: 21
I did a lot from Moorc sockets
Old 07-06-2020, 23:59   #14 (permalink)
ktienda's Avatar
Member: 309769
Thanks Meter: 44
I have two easy jtag, a few days ago I tried to update the fw of a box and after that it does not detect ufs n975f by ufs piount, but the other box with the old fw if it detects it, is there any possibility of dowgrade the fw of my box ?
tks
same problem,
test 1 easy jtag without update FW and connect OK,
other box with update fw, and not connect
PD.
i use UFS BGA-153 adapter Z3X ...
Old 07-08-2020, 19:13   #15 (permalink)
ktienda's Avatar
Member: 309769
Thanks Meter: 44
Unhappy
Run old version with Left Ctrl pressed
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.900)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial =
Card Serial = AAC96A09
EasyJTAG Box Firmware = 2.52
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting interface to EasyJtag2/UFS
UFS Init Failed, error: 0
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20847 seconds with 8 queries
