08-12-2020, 22:42 | #32 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | 1. There is on support ISP schematic for this phone. Also, there is the video above that I believe to be genuine 2. Can you name the appropriate UFS adapter for N975F ? |
08-13-2020, 07:01 | #34 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.17 UFS Socket Info. Serial: 0123B31A4Axxxxx Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 02.04.20 Identify UFS Chip. UFS Chip Voltage: Low Check ISP connect. Can't init device, Code: -113, Reason: UTP: Failed to NOP request VCC: 3226mV VCCQ2: 1912mV last version cant detect N975F |
08-17-2020, 09:56 | #38 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Sec934 C2D1 KLUEG8UHDB My phone have mdm and cant access download,n975F Bit1 Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 02.04.20 Identify UFS Chip. UFS Chip Voltage: Low Check ISP connect. Can't init device, Code: -113, Reason: UTP: Failed to NOP request VCC: 3226mV VCCQ2: 1912mV |
08-17-2020, 22:31 | #39 (permalink) | |
Member: 120579 Status: Offline Thanks Meter: 182 | Quote:
I do not want other people to work, I just need a correct adapter to do the job. If anybody has used Easy Jtag with n975f, please tell me what adapter u used. | |
08-18-2020, 07:15 | #41 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Try you use latest version Check you connection, etc For UFS ISP connection you need power board from USB | |
02-07-2022, 04:30 | #42 (permalink) |
Junior Member Join Date: Apr 2020 Location: Philippines
Member: 2954168 Status: Offline Thanks Meter: 0 | Note10+ Can't Load Android System the issue of my note10+ before this happened is i cant use sim card cause its "Not Registered to a Network" Always Emergency Call only... Now while I was looking for an alternative software for MRT (cause we all know its not working) I found this KBB Tools and there is an option "Repair Emergency Calls Only (Exynos) Adb" so I tried it and then this happens... I've tried so many Flashing via Odin 3.14.4 and with Different firmwares still no lock... Please Help... TIA |
01-03-2023, 22:08 | #43 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Please how did you manage to connect it.. Because i have tried many attempts too.. I have both easyjtag bg256 adapter and moorc 3-in-1 adapter all working fine with other device except this stubborn phone.. Please tell me how you connects it |
