Old 05-03-2019, 09:03   #1 (permalink)
Crazy Poster
Member: 2128671
Thanks Meter: 47
how to remove mdm lock on j415f use easy jtag+
MDM does not allow factoryReset
use easy jtag plus for read and factory reset
link full
https://www.youtube.com/watch?v=78KShSh9mHQ&t=515s
The Following 3 Users Say Thank You to gsm.phutho For This Useful Post:
Old 05-03-2019, 12:32   #2 (permalink)
Member: 570373
Thanks Meter: 236
bro i was can not see format on easy jtag+ you only read video........
The Following User Says Thank You to naizer For This Useful Post:
Old 05-03-2019, 14:55   #3 (permalink)
Crazy Poster
Member: 2128671
Thanks Meter: 47
you need root or change imei for anti relock
The Following User Says Thank You to gsm.phutho For This Useful Post:
Old 05-03-2019, 19:06   #4 (permalink)
Member: 391038
Thanks Meter: 81
I have done many mdm phones via easy jtag
1. flash the combination firmware via easyjtag plus / write by vendor
2. Disconnect the phone
3. Now you will have the download mode
4. Put your in download mode connect usb,
Flash the latest firmware ( but do not complete the setup process, it will relock )
5. Now just root your phone. ( once knox is tripped, mdm will not relock and it will be removed.
The Following 8 Users Say Thank You to bbonnd007 For This Useful Post:
Old 05-17-2019, 00:25   #5 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
i never know about easy jtag so via veder it support combin file(.tar)?
Old 05-17-2019, 08:59   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
EasyJTAG Plus software support tar files many years
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 05-17-2019, 12:59   #7 (permalink)
Member: 2442914
Thanks Meter: 9
link full
em chào youtuber ....
Old 06-08-2019, 06:50   #8 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
what if oem and frp lock on ?
Old 06-11-2019, 07:06   #9 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
U Still Can..After Write Combination Remove FRP N Disable OEM 1st Then Follow Rest...
Old 06-11-2019, 08:12   #10 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
j415f oem disable in combination file
Old 06-13-2019, 13:34   #11 (permalink)
Member: 1834832
Thanks Meter: 1,450
Part Flashing After Combination Then Disable It
Old 11-01-2019, 15:24   #12 (permalink)
Member: 22054
Thanks Meter: 8
After watch video one doubt!
You read by vender, only this? Maybe you have cutoff the part shows us hou remove MDM!
Can you explain here? Thanks.
link full
Old 11-01-2019, 18:16   #13 (permalink)
Member: 1972033
Thanks Meter: 32
but do not complete the setup process, it will relock so wat files shouldnt flash ?
Page generated in 0.24142 seconds with 8 queries
