Old 11-29-2019, 07:50   #1 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Oppo a1k after frp / wipe user data dead only (mediatek usb port)
OPPO A1K AFTER FRP / WIPE USER DATA DEAD ONLY (MEDIATEK USB PORT)
The Following User Says Thank You to .::THE ROCK::. For This Useful Post:
Old 11-29-2019, 17:11   #2 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
No reply... Cant solve oppo a1k dead easy jtag
Old 11-29-2019, 17:40   #3 (permalink)
Member: 2924006
that problem is also in my mobile [oppo a83] then i will remove that component
Old 11-29-2019, 17:49   #4 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
BRO CAN ANY SOLVE DEAD A1K...component ANY POST OR LINK
Old 11-29-2019, 18:47   #5 (permalink)
Member: 704044
Thanks Meter: 212
Just remove clk resister and short your mobile will be alive
Old 11-29-2019, 19:15   #6 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 2,080
remove bga then reprogram problem solved oppo a1k
http://www.youtube.com/watch?v=k1fUY1o9pEw
The Following 2 Users Say Thank You to raisalina For This Useful Post:
Old 11-29-2019, 19:19   #7 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Bro it's no clk resistor oppo a1k check pinout only point bord
Old 11-29-2019, 19:30   #8 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Bro phone dead pinout method via JTAG why need boot repair via remove emmc
pinout ok jtag full identify... usb ok
Old 11-29-2019, 19:37   #9 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 2,080
Easy jtag always write flash error bro......
Old 11-30-2019, 04:54   #10 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Other forum with dump solved.... https://www.********************/thr...670/post-45897
Old 11-30-2019, 06:01   #11 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Originally Posted by .::THE ROCK::. View Post
OTHER FORUM WRITE DUMP PIC I HAVE NO DUMP
Old 11-30-2019, 06:04   #12 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Reply.... Team cant solve via easy jtag
Old 11-30-2019, 10:12   #13 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
detect info yet
Z3X EasyJtag Software ver. 3.6.1.17
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63
CMD Pullup Level:1980 mV
CMD Active Level:2145 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514436334D4203DDA4A869760C
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 07/2019  Rev.0x3
eMMC NAME: QD63MB , S/N: 3718555753
eMMC NAME (HEX): 514436334D42
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 361 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits  , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QD63MB_3718555753_20191130_1440.extcsd
Caution: invalid main GPT header, but valid a backup header!
Warning: Invalid CRC on main header data; loaded backup partition table.
Warning! Main and backup partition tables differ!
Warning! Main partition table CRC mismatch! Loaded backup
Warning! One or more CRCs don't match. You should repair the disk!
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Detected 42 partitions ------
P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB
P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB
P2 (PARA) [0x2108000 0x80000] Size: 512.0KB
P3 (OPPORESERVE1) [0x2188000 0x800000] Size: 8.0MB
P4 (OPPORESERVE2) [0x2988000 0x4000000] Size: 64.0MB
P5 (OPPORESERVE3) [0x6988000 0x4000000] Size: 64.0MB
P6 (OPPO_CUSTOM) [0xa988000 0x100000] Size: 1.0MB
P7 (EXPDB) [0xaa88000 0x1400000] Size: 20.0MB
P8 (FRP) [0xbe88000 0x100000] Size: 1.0MB
P9 (VBMETA) [0xbf88000 0x800000] Size: 8.0MB
P10 (NVCFG) [0xc788000 0x2000000] Size: 32.0MB
P11 (NVDATA) [0xe788000 0x4000000] Size: 64.0MB
P12 (METADATA) [0x12788000 0x2000000] Size: 32.0MB
P13 (PROTECT1) [0x14788000 0x800000] Size: 8.0MB
P14 (PROTECT2) [0x14f88000 0x878000] Size: 8.468MB
P15 (SECCFG) [0x15800000 0x800000] Size: 8.0MB
P16 (PERSIST) [0x16000000 0x3000000] Size: 48.0MB
P17 (SEC1) [0x19000000 0x200000] Size: 2.0MB
P18 (PROINFO) [0x19200000 0x300000] Size: 3.0MB
P19 (MD1IMG) [0x19500000 0x6400000] Size: 100.0MB
P20 (SPMFW) [0x1f900000 0x100000] Size: 1.0MB
P21 (SCP1) [0x1fa00000 0x100000] Size: 1.0MB
P22 (SCP2) [0x1fb00000 0x100000] Size: 1.0MB
P23 (SSPM_1) [0x1fc00000 0x100000] Size: 1.0MB
P24 (SSPM_2) [0x1fd00000 0x100000] Size: 1.0MB
P25 (GZ1) [0x1fe00000 0x1000000] Size: 16.0MB
P26 (GZ2) [0x20e00000 0x1000000] Size: 16.0MB
P27 (NVRAM) [0x21e00000 0x4000000] Size: 64.0MB
P28 (LK) [0x25e00000 0x100000] Size: 1.0MB
P29 (LK2) [0x25f00000 0x100000] Size: 1.0MB
P30 (BOOT) [0x26000000 0x2000000] Size: 32.0MB
P31 (LOGO) [0x28000000 0x1000000] Size: 16.0MB
P32 (DTBO) [0x29000000 0x1000000] Size: 16.0MB
P33 (TEE1) [0x2a000000 0x500000] Size: 5.0MB
P34 (TEE2) [0x2a500000 0xb00000] Size: 11.0MB
P35 (ODM) [0x2b000000 0x10000000] Size: 256.0MB
P36 (VENDOR) [0x3b000000 0x39800000] Size: 920.0MB
P37 (SYSTEM) [0x74800000 0x12c000000] Size: 4.687GB
P38 (CACHE) [0x1a0800000 0x1b000000] Size: 432.0MB
P39 (USERDATA) [0x1bb800000 0x5888fbe00] Size: 22.132GB
P40 (OTP) [0x7440fbe00 0x2b00000] Size: 43.0MB
P41 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0074800000 (4.687GB)
Unable to read prop.plist , code : 2
Detected USERDATA USERDATA : 0x01BB800000 (22.132GB)
Unable to mount USERDATA , code : 95
Done.
Selected eMMC Interface
Old 11-30-2019, 10:18   #14 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 233
plz upload this dump. sgare with me
Old 11-30-2019, 10:27   #15 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Bro same me... need this dump
Page generated in 0.22296 seconds with 9 queries
