04-02-2022, 13:20 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | oppo a3s bootloop fixed by reset option via easy jtag Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0500801DBB914D6B, ,FW Ver.: 01.63 CMD Pullup Level:2103 mV CMD Active Level:3176 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A484147346132A509D48010A59A eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0xA5 eMMC NAME: HAG4a2 , S/N: 164921360 eMMC NAME (HEX): 484147346132 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 280579 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HAG4a2_ 164921360_20220402_1209.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found ------ Detected 65 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB P9 (FSC) [0x8305000 0x400] Size: 1.0KB P10 (SSD) [0x8306000 0x2000] Size: 8.0KB P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB P12 (RPM) [0x8388000 0x80000] Size: 512.0KB P13 (TZ) [0x8408000 0x200000] Size: 2.0MB P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB P20 (DDR) [0xa000000 0x8000] Size: 32.0KB P21 (FSG) [0xa008000 0x180000] Size: 1.500MB P22 (SEC) [0xa188000 0x4000] Size: 16.0KB P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB P41 (DIP) [0x30880000 0x100000] Size: 1.0MB P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB P53 (APDP) [0x33800000 0x40000] Size: 256.0KB P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB P55 (DPO) [0x33880000 0x2000] Size: 8.0KB P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB P59 (HYP) [0x38800000 0x800000] Size: 8.0MB P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB P64 (USERDATA) [0x158000000 0x2533fbe00] Size: 9.299GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2020-07-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20200710.012336 release-keys Backup saved: BuildProp_20220402_1209.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.299GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: CA8F5090 555C3BA3 6B8F39A8 4EDA465B 0210BE70 8E1B4F87 34CC51EF 53F7E278 Ê.P.U\;£k.9¨NÚF[..¾pŽ.O‡4ÌQïS÷âx; 5C5D356B 3B908352 712B35E3 4DF25FCA EAA30DF6 6F5A617A 57817A8D 6EF28B79 \]5k;.ƒRq+5ãMò_Êê£.öoZazW.z.nò‹y; 81891FFD CB09E9DB 8A799EC3 1BAE9189 07CFC77A A85C017F B933B697 9A65D078 .‰.ýË éÛŠyžÃ.®‘‰.ÏÇz¨\..¹3¶—šeÐx; 85A206FB F9E3C5E8 CAD1EF94 AC7BE5F8 E9B129F4 43C9F59B EE8460BB EA084F7D …¢.ûùãÅèÊÑ{åøé±)ôCÉõ›î„`»ê.O}; 780A4EE7 01256DB7 5E4C1431 C0D914FC 3E56D666 891BC466 A8119B77 AA3E8840 x.Nç.%m·^L.1ÀÙ.ü>VÖf‰.Äf¨.›wª>.@; 42050833 94DF7B24 B154C02A 5926222D 1E50FE69 479B2986 1E5279D1 11CC94A5 B..3”ß{$±TÀ*Y&"-.PþiG›)†.RyÑ.Ì”¥; F6CEA78D 1AABD30F C8C2DFC0 23443C32 A46B581E DF449231 7F12DC02 C1108EC3 öΧ..«Ó.ÈÂßÀ#D<2¤kX.ßD’1..Ü.Á.ŽÃ; E7C9C398 6FA8443A 494B21E9 59F1AEED D36D59C0 FA4C122B EE2ACA49 4D44AC8B çÉÃ.o¨D:IK!éYñ®íÓmYÀúL.+î*ÊIMD¬‹; Done. Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0500801DBB914D6B, ,FW Ver.: 01.63 CMD Pullup Level:2103 mV CMD Active Level:3165 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A484147346132A509D48010A59A eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0xA5 eMMC NAME: HAG4a2 , S/N: 164921360 eMMC NAME (HEX): 484147346132 EMMC ROM1 (Main User Data) Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 280579 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. |
