Old 08-03-2020, 17:41   #31 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
after write ofp firmware i write below back up i am right?
OPPO A3S CPH1803EX_11_A.17_Samsung eMMC_oppodycnvbk + oppostanvbk + modemst1 + modemst2 + fsg + sec + modem.7z
Old 08-03-2020, 22:55   #32 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
you need restore this partition from you backup
Old 08-04-2020, 08:19   #33 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
Originally Posted by layder View Post
at last operation - Write by vendor you need write backup only secure partition
If you write all partition - you restore you device to original state
you need:
1) backup secure partitioon only, or backup all without usedata, syste, cache
2) Write work dump or extracted ofp firmware
3) restore only secute partition if you write dump
i write my secure partition back up but still phone dead.but i made the secure partition back up when phone already in edl state.anyway to solve this?
Old 08-04-2020, 10:14   #34 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
Hi,
Pay attention, if you do have the Phone Secure Area data is backup, just erase the whole eMMC completely, then apply my method from the beginning.
After you do complete the recommended procedure if you get still EDL problem then it's hardware components are damaged by over hit soldering.
Just makes jumper one by one, 1'st makes CLK if still EDL, then also makes CMD.
Post result.
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Old 08-04-2020, 17:16   #35 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
ok thanks for the tips but just 2 questions : i made Phone Secure Area data backup but after phone already in edl mode will that back up work? if not going to work what can i do?
Old 08-06-2020, 07:19   #36 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
here is the info log
Setting frequence to 21 MHz
CMD Pullup Level: 1804 mV
CMD Active Level: 2062 mV
EMMC Device Information :
EMMC CID: 90014A484147346132A5C1E25D7BC5D2
EMMC CSD: D02701328F5903FFFFFFFFE78A400016
EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: C1E25D7B , rev. 0xA5
EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 34316 , Response: Not Clean
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Backup saved: HAG4a2_C1E25D7B_20200806_090427.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB)
Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB)
Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB)
Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB)
Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB)
Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB)
Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB)
Partition: reserve_exp1, [000007F05000 - 000008105000], size: 000000200000 (2.00 MB)
Partition: reserve_exp2, [000008105000 - 000008305000], size: 000000200000 (2.00 MB)
Partition: fsc, [000008305000 - 000008305400], size: 000000000400 (1.00 KB)
Partition: ssd, [000008306000 - 000008308000], size: 000000002000 (8.00 KB)
Partition: sbl1, [000008308000 - 000008388000], size: 000000080000 (512. KB)
Partition: rpm, [000008388000 - 000008408000], size: 000000080000 (512. KB)
Partition: tz, [000008408000 - 000008608000], size: 000000200000 (2.00 MB)
Partition: devcfg, [000008608000 - 000008648000], size: 000000040000 (256. KB)
Partition: sbl1bak, [000008648000 - 0000086C8000], size: 000000080000 (512. KB)
Partition: rpmbak, [0000086C8000 - 000008748000], size: 000000080000 (512. KB)
Partition: tzbak, [000008748000 - 000008948000], size: 000000200000 (2.00 MB)
Partition: devcfgbak, [000008948000 - 000008988000], size: 000000040000 (256. KB)
Partition: dsp, [000008988000 - 000009988000], size: 000001000000 (16.0 MB)
Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 (32.0 KB)
Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 (1.50 MB)
Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 (16.0 KB)
Partition: aboot, [00000A18C000 - 00000A28C000], size: 000000100000 (1.00 MB)
Partition: abootbak, [00000A28C000 - 00000A38C000], size: 000000100000 (1.00 MB)
Partition: modem, [00000A38C000 - 00001238C000], size: 000008000000 (128. MB)
Partition: dtbo, [00001238C000 - 000012B8C000], size: 000000800000 (8.00 MB)
Partition: vbmeta, [000012B8C000 - 000012B9C000], size: 000000010000 (64.0 KB)
Partition: boot, [000012B9C000 - 000016B9C000], size: 000004000000 (64.0 MB)
Partition: recovery, [000016B9C000 - 00001AB9C000], size: 000004000000 (64.0 MB)
Partition: devinfo, [00001AB9C000 - 00001AC9C000], size: 000000100000 (1.00 MB)
Partition: splash, [00001B000000 - 00001BB00000], size: 000000B00000 (11.0 MB)
Partition: LOGO, [00001BB00000 - 00001DB00000], size: 000002000000 (32.0 MB)
Partition: DRIVER, [00001DB00000 - 00001FB00000], size: 000002000000 (32.0 MB)
Partition: cache, [00001FB00000 - 00002FB00000], size: 000010000000 (256. MB)
Partition: misc, [00002FB00000 - 00002FC00000], size: 000000100000 (1.00 MB)
Partition: keystore, [00002FC00000 - 00002FC80000], size: 000000080000 (512. KB)
Partition: config, [00002FC80000 - 00002FC88000], size: 000000008000 (32.0 KB)
Partition: oem, [00002FC88000 - 00002FD88000], size: 000000100000 (1.00 MB)
Partition: limits, [000030000000 - 000030008000], size: 000000008000 (32.0 KB)
Partition: mota, [000030800000 - 000030880000], size: 000000080000 (512. KB)
Partition: dip, [000030880000 - 000030980000], size: 000000100000 (1.00 MB)
Partition: mdtp, [000030980000 - 000032980000], size: 000002000000 (32.0 MB)
Partition: syscfg, [000032980000 - 000032A00000], size: 000000080000 (512. KB)
Partition: mcfg, [000032A00000 - 000032E00000], size: 000000400000 (4.00 MB)
Partition: lksecapp, [000033000000 - 000033020000], size: 000000020000 (128. KB)
Partition: cmnlib, [000033020000 - 000033120000], size: 000000100000 (1.00 MB)
Partition: cmnlib64, [000033120000 - 000033220000], size: 000000100000 (1.00 MB)
Partition: keymaster, [000033220000 - 000033320000], size: 000000100000 (1.00 MB)
Partition: lksecappbak, [000033320000 - 000033340000], size: 000000020000 (128. KB)
Partition: cmnlibbak, [000033340000 - 000033440000], size: 000000100000 (1.00 MB)
Partition: cmnlib64bak, [000033440000 - 000033540000], size: 000000100000 (1.00 MB)
Partition: keymasterbak, [000033540000 - 000033640000], size: 000000100000 (1.00 MB)
Partition: apdp, [000033800000 - 000033840000], size: 000000040000 (256. KB)
Partition: msadp, [000033840000 - 000033880000], size: 000000040000 (256. KB)
Partition: dpo, [000033880000 - 000033882000], size: 000000002000 (8.00 KB)
Partition: logdump, [000033882000 - 000037882000], size: 000004000000 (64.0 MB)
Partition: vm-kystore, [000037882000 - 000037982000], size: 000000100000 (1.00 MB)
Partition: vm-data, [000037982000 - 000038382000], size: 000000A00000 (10.0 MB)
Partition: hyp, [000038800000 - 000039000000], size: 000000800000 (8.00 MB)
Partition: vm-system, [000039000000 - 00003D000000], size: 000004000000 (64.0 MB)
Partition: vm-linux, [00003D000000 - 00003F000000], size: 000002000000 (32.0 MB)
Partition: system, [00003F000000 - 000115900000], size: 0000D6900000 (3.35 GB)
Partition: vendor, [000115900000 - 000157860000], size: 000041F60000 (1.03 GB)
Partition: userdata, [000158000000 - 0003AB3FBE00], size: 0002533FBE00 (9.30 GB)
GPT header successfully parsed
Old 08-06-2020, 08:16   #37 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
ok read info from easyjtag classic:
Z3X EasyJtag Software ver. 3.7.0.11
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: , ,FW Ver.: 01.63
CMD Pullup Level:1815 mV
CMD Active Level:2052 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A484147346132A5C1E25D7BC5D2
eMMC CSD : D02701328F5903FFFFFFFFE78A400016
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 12/2018 Rev.0xA5
eMMC NAME: HAG4a2 , S/N: 3252837755
eMMC NAME (HEX): 484147346132
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 34316 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HAG4a2_3252837755_20200806_1011.extcsd
Warning! Main and backup partition tables differ!
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB
Soft (Partitioned) Disk/Image size: 1D59FDA sectors 14.7 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 19,30777325
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Security Path: 2019-03-05
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys
Backup saved: BuildProp_20200806_1011.txt
Detected USERDATA USERDATA : 0x0158000000 (9.299GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 491520
Short userdata info:
Unable to read gesture.key , code 2
Done.
Old 08-07-2020, 08:29   #38 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
problem not solved who can help please?
Old 08-11-2020, 12:20   #39 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 204
EasyJtag Suite Classic ver.: 3.7.0.11 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights FAIL
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
EasyJTAG SPI Plugin ver:1.1.1.13
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
For more information press F1 to open local help or visit our wiki
Found 3 serial devices
COM1 ACPI\PNP0501 Communications Port (COM1)
COM17 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM17)
COM26 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM26)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Loading eMMC GEN1 Firmware... IO: 1850 mV
Box S/N: 1616120653F9FBE6, ,FW Ver.: 01.63
CMD Pullup Level:1907 mV
CMD Active Level:2062 mV
Box IO Level:1850 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Backup saved: HAG4a2_3252837755_20200811_1413.extcsd
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Backup saved: BuildProp_20200811_1413.txt
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 491520
Done.
Old 08-12-2020, 03:50   #40 (permalink)
Member: 1972033
Thanks Meter: 32
good work bro thanks alot
Old 08-27-2020, 09:22   #41 (permalink)
Registered User
Member: 572549
Thanks Meter: 175
do you have fulldump for skhynix emmc
Old 08-27-2020, 13:52   #42 (permalink)
Moderator
Member: 1162626
@ T0T0
I don't have it !!
Unfortunately the South African region did not seen the SKhynix eMMC Building Oppo A3S Phone.
__________________
Old 08-28-2020, 03:14   #43 (permalink)
Registered User
Member: 572549
Thanks Meter: 175
ok sir thanks i have 3 pcs a3s all skhynix emmc
Old 09-04-2020, 11:18   #44 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207(No More Use)
Thanks Meter: 706
very useful thread, Thanks for share
Old 09-04-2020, 17:28   #45 (permalink)
Member: 2957188
really it helps bro thanks for your hardwork
Page generated in 0.24820 seconds with 8 queries
