kothamamun | 12-25-2019 07:52 | oppo a3s dead recover done Code:
Setting frequence to 21 MHz
CMD Pullup Level: 1691 mV
CMD Active Level: 1753 mV
EMMC Device Information :
EMMC CID: 150100514536334D420692B49678A52A
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 92B49678 , rev. 0x06
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2018
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 17413 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_92B49678_20191225_030812.extcsd
EMMC Init completed.
Operation: Writing all eMMC Regions...
Operation: Writing BootConfig ...
Reg: 179 Value: 0x38
Reg: 177 Value: 0x00
Reg: 162 Value: 0x01
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_hB8aP_ROM2_000000000000_000000400000.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 340.85 KB/s
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_hB8aP_ROM3_000000000000_000000400000.bin
eMMC switching to ROM3
Done writing partition. Write speed: 340.89 KB/s
Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000
Filename: EMMC_hB8aP_ROM1_000000000000_000747C00000.bin
eMMC switching to ROM1
Done writing partition. Write speed: 512.98 KB/s
All done time: [00:34:30:194] Code:
CMD Pullup Level: 1680 mV
CMD Active Level: 1732 mV
Backup saved: QE63MB_92B49678_20191225_034256.extcsd
Scanning soft partitions
GPT header is found and is valid
Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB)
Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB)
Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB)
Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB)
Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB)
Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB)
Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB)
Partition: reserve_exp1, [000007F05000 - 000008105000], size: 000000200000 (2.00 MB)
Partition: reserve_exp2, [000008105000 - 000008305000], size: 000000200000 (2.00 MB)
Partition: fsc, [000008305000 - 000008305400], size: 000000000400 (1.00 KB)
Partition: ssd, [000008306000 - 000008308000], size: 000000002000 (8.00 KB)
Partition: sbl1, [000008308000 - 000008388000], size: 000000080000 (512. KB)
Partition: rpm, [000008388000 - 000008408000], size: 000000080000 (512. KB)
Partition: tz, [000008408000 - 000008608000], size: 000000200000 (2.00 MB)
Partition: devcfg, [000008608000 - 000008648000], size: 000000040000 (256. KB)
Partition: sbl1bak, [000008648000 - 0000086C8000], size: 000000080000 (512. KB)
Partition: rpmbak, [0000086C8000 - 000008748000], size: 000000080000 (512. KB)
Partition: tzbak, [000008748000 - 000008948000], size: 000000200000 (2.00 MB)
Partition: devcfgbak, [000008948000 - 000008988000], size: 000000040000 (256. KB)
Partition: dsp, [000008988000 - 000009988000], size: 000001000000 (16.0 MB)
Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 (32.0 KB)
Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 (1.50 MB)
Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 (16.0 KB)
Partition: aboot, [00000A18C000 - 00000A28C000], size: 000000100000 (1.00 MB)
Partition: abootbak, [00000A28C000 - 00000A38C000], size: 000000100000 (1.00 MB)
Partition: modem, [00000A38C000 - 00001238C000], size: 000008000000 (128. MB)
Partition: dtbo, [00001238C000 - 000012B8C000], size: 000000800000 (8.00 MB)
Partition: vbmeta, [000012B8C000 - 000012B9C000], size: 000000010000 (64.0 KB)
Partition: boot, [000012B9C000 - 000016B9C000], size: 000004000000 (64.0 MB)
Partition: recovery, [000016B9C000 - 00001AB9C000], size: 000004000000 (64.0 MB)
Partition: devinfo, [00001AB9C000 - 00001AC9C000], size: 000000100000 (1.00 MB)
Partition: splash, [00001B000000 - 00001BB00000], size: 000000B00000 (11.0 MB)
Partition: LOGO, [00001BB00000 - 00001DB00000], size: 000002000000 (32.0 MB)
Partition: DRIVER, [00001DB00000 - 00001FB00000], size: 000002000000 (32.0 MB)
Partition: cache, [00001FB00000 - 00002FB00000], size: 000010000000 (256. MB)
Partition: misc, [00002FB00000 - 00002FC00000], size: 000000100000 (1.00 MB)
Partition: keystore, [00002FC00000 - 00002FC80000], size: 000000080000 (512. KB)
Partition: config, [00002FC80000 - 00002FC88000], size: 000000008000 (32.0 KB)
Partition: oem, [00002FC88000 - 00002FD88000], size: 000000100000 (1.00 MB)
Partition: limits, [000030000000 - 000030008000], size: 000000008000 (32.0 KB)
Partition: mota, [000030800000 - 000030880000], size: 000000080000 (512. KB)
Partition: dip, [000030880000 - 000030980000], size: 000000100000 (1.00 MB)
Partition: mdtp, [000030980000 - 000032980000], size: 000002000000 (32.0 MB)
Partition: syscfg, [000032980000 - 000032A00000], size: 000000080000 (512. KB)
Partition: mcfg, [000032A00000 - 000032E00000], size: 000000400000 (4.00 MB)
Partition: lksecapp, [000033000000 - 000033020000], size: 000000020000 (128. KB)
Partition: cmnlib, [000033020000 - 000033120000], size: 000000100000 (1.00 MB)
Partition: cmnlib64, [000033120000 - 000033220000], size: 000000100000 (1.00 MB)
Partition: keymaster, [000033220000 - 000033320000], size: 000000100000 (1.00 MB)
Partition: lksecappbak, [000033320000 - 000033340000], size: 000000020000 (128. KB)
Partition: cmnlibbak, [000033340000 - 000033440000], size: 000000100000 (1.00 MB)
Partition: cmnlib64bak, [000033440000 - 000033540000], size: 000000100000 (1.00 MB)
Partition: keymasterbak, [000033540000 - 000033640000], size: 000000100000 (1.00 MB)
Partition: apdp, [000033800000 - 000033840000], size: 000000040000 (256. KB)
Partition: msadp, [000033840000 - 000033880000], size: 000000040000 (256. KB)
Partition: dpo, [000033880000 - 000033882000], size: 000000002000 (8.00 KB)
Partition: logdump, [000033882000 - 000037882000], size: 000004000000 (64.0 MB)
Partition: vm-kystore, [000037882000 - 000037982000], size: 000000100000 (1.00 MB)
Partition: vm-data, [000037982000 - 000038382000], size: 000000A00000 (10.0 MB)
Partition: hyp, [000038800000 - 000039000000], size: 000000800000 (8.00 MB)
Partition: vm-system, [000039000000 - 00003D000000], size: 000004000000 (64.0 MB)
Partition: vm-linux, [00003D000000 - 00003F000000], size: 000002000000 (32.0 MB)
Partition: system, [00003F000000 - 000115900000], size: 0000D6900000 (3.35 GB)
Partition: vendor, [000115900000 - 000157860000], size: 000041F60000 (1.03 GB)
Partition: userdata, [000158000000 - 000747BFBE00], size: 0005EFBFBE00 (23.7 GB)
GPT header successfully parsed
