06-23-2020, 12:55 | #1 (permalink) |
Crazy Poster Join Date: Dec 2006
Member: 417115 Status: Offline Thanks Meter: 0 | oppo a3s GPT header, but valid main header! __________________________________ Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 01FFE01784328975, ,FW Ver.: 01.63 CMD Pullup Level:1804 mV CMD Active Level:2609 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484147346132A5C06BC0441664 eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 01/2019 Rev.0xA5 eMMC NAME: HAG4a2 , S/N: 3228287044 eMMC NAME (HEX): 484147346132 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 3291 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HAG4a2_3228287044_20200623_1339.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBB sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777309 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.299GB) Unable to mount USERDATA , code : 95 Done. __________________________________________________ _____ Backup saved: HAG4a2_3228287044_20200623_1339.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. |
07-06-2020, 18:40 | #3 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | what is gpt header I m confuse in some very old model which dump file note available I write scatter file After write scatter show full information But show gpt header invalid Sometime set hang on logo Some set still dead I m very confused |
07-07-2020, 06:48 | #4 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
MTK devices have GPT after 6735 and latter CPU before it MTK devices have MBR partition table | |
The Following 3 Users Say Thank You to layder For This Useful Post: |
